Question about Vacuums
Windshield washer will not squirt - Vacuums
    President:
  • Vacuums Master
  • 1,922 Answers
First check that pump activates from the dash control and you can hear the small motor under the reservoir running, if still no fluid flow,then take compressed air( at very low pressure) and blow into reservoir hole on top of reservoir and force fluid thru hoses to windshield outlets,either you have an obstruction or pump is losing its prime
Posted on Nov 19, 2009
After replacing pump water comes out in short squirts. It seems to come out of pump in steady stream but short squirts at nozzles including hand held.
Check your filters. Flow Indicator Filter: Turn Flow Indicator Cap counter-clockwise to remove, lift rotor and filter out. Clean filter and replace in reverse order.
Sep 03, 2015 | Bissell 8920 ProHeat 2XTM Upright Vacuum
Machine w/not squirt
have you check the spray nozzle or spray line for s clog? only other thing you didn't list? let me know?
Aug 23, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Cannot remove the turbo head
Try squirting some WD40 around the button. It may have got jammed due to dirt getting in there. Give it a couple of minutes to work and squirt more on if necessary.
Feb 18, 2014 | Dyson DC07 Bagless Upright Cyclonic Vacuum
I love my floor cleaner n I would be lost without it. I use it once if not twice a week. But...when I went 2 use it this week it will not squirt the water out when I pull the trigger so I used a squirt...
Check that the bung that closes off the water outlet hole is not stuck in the outlet. Remove the water container and check the underside where the outlet is while operating the opening mechanism.
Jan 16, 2011 | Hoover H3030 FloorMate SpinScrub 500...
My bissell worked well cleaning my carpets it's only 1 year old when i stop'd it to refill water it would turn on put not spray what can ido to fix this problem
TAKE OFF THE CLEAN WATER TUB IF IT COMES OFF TO FILL AND LOOK FOR SCREENS OR FILTERS THAT COULD BE PLUGGED OR AT LEAST LOOK FOR THE LINE THAT CARRYS THE WATER TO THE PUMP AND AGAIN CHECK FOR LIKE HARD SOAP AND STICK LIKE A NEEDLE IN IT BUT CARFUL NOT PUNCTURE ANY TUBES THE WORST CASE IS THAT THE PUMP THAT MAKES THE WATER SQUIRT OUT IS BAD SAME AS IT BE IF YOURE CAR STOPPED HAVING WINDOW WASHER FLUID SQUIRT OUT
Jan 19, 2010 | Vacuums
THE STAIR HANDLE WILL NOT SQUIRT WATER AND/CLEANING SOLUTION
The hose or nozzle could be plugged. The hose can be disconnected at the machine end there is a clip on the bottom of the connection. The fluid is dispensed by a pump which could be bad. If you disconnect the hose and put a rag at the opening to catch the fluid, then turn the machine on briefly the fluid should squirt out if the pump is working.
Nov 12, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Solution won't squirt
Check to make sure pump is running, if not check relay. If so, then try to clean the nozzles with compressed air or a needle
Aug 04, 2009 | Vacuums
My power steamer will not squirt water. Seems to
it migh be that the formula you mixed together is notcreating enough pressure to force the mixture out is it the formula the company sells or did you pick up some other formula
Jul 10, 2009 | Bissell 1697-7 Powersteamer Pro Deluxe...
Model 1400 little green cleaner does not squirt fluid
its just the prime.if all the water is let out of the hoses it will need to be reprimed with water again.once water fills the hoses it will work fine
Dec 10, 2008 | Bissell 1400 Little Green Pro Canister...
No water spraying
Does water squirt out of the hose nozzle, if it does, then check the heater inside the handle asm. Make sure that where the tubes hook up to it are not clogged. If water doesn't squirt, check for the seal at the bottom of the tank, it needs to be on the tank, not in the hole, this is for the soap bottle also, there is a seal on the bottom of it as well. The flow indictor cap is leaking air or maybe is too tight. If you had the top cover off, make sure that the tubes are routed right so as not to get pinched when the cover is put back on, the smart mix knob should be in the water setting and that the piston is on the bottom of the smart mix knob. Pump is bad. Try running a mix of vinegar and water to see if that unclogs the lines. Is the top cover and the base tight together in the back, sometimes the top breaks loose and it will raise up and it can't spray, just re-fasten it down.
Aug 10, 2008 | Bissell Vacuums
Vacuums Logo
203 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
