Question about Bissell 3590 CleanView Bagless Upright Vacuum
Arrgh! I have an upright Bissell vacuum. Everytime I use it, it smells like a cloud of dust. I have made sure countless times that all the filters are clean and the hoses are intact, so I don't know what the problem is. Is this problem normal? Or am I somehow blowing dust everywhere? Any insight it much appreciated, thanks!!
  • 36 Answers
I believe you have a clogg in the suction pipe.
Posted on Nov 20, 2009
Throws dust all over. Missing hepa filter. Is that the problem?
Of course. The filter is there for a reason and it also maintains pressure. But also make sure that the seals to the container are good and that it is located correctly.
Apr 23, 2016 | Dirt Devil Ultra Vision Turbo Bagless...
Constant blockages
It could be a clog or obstruction somewhere restricting the airflow. If you can't find a restriction the problem could be the filters are now allowing adequate airflow. Filters should be cleaned frequently and replaced at least once per year for proper cleaning.
Jan 29, 2014 | Bissell 3130 Bagless Upright Vacuum
Bissell carpet cleaner does not suction
Hello, this is Ava with Think Crucial.
If the dust cup is too full, there is no space for the dirt to go when you are vacuuming. To fix this, remove the dust cup and empty the it. If your vacuum is still not picking up dirt after emptying the dust cup, there may be something blocking the airway. There are two places where you can check for a blockage: the dust cup air duct and the intake opening behind the brush roll. To check for a blockage in the dust cup air duct stand the vacuum upright and remove the dust cup. Now you can disconnect the super stretch hose and check for clogs in the air duct behind the dust cup. If that is not the case, to check for a clog near the roller brush lay the vacuum down. Next check the opening behind the brush roll for clogs. If there is debris, clean the opening with scissors, carefully cutting away any debris.
Uncleaned filters may also the reason why your vacuum has lost suction. To clean the foam and felt filters, remove the dust cup and pull out the two filters that are on the top of the motor base. Rinse the filters with lukewarm water until the water is running clear. Let the filters dry fully before putting them back into the vacuum. If your vacuum is still not picking up dirt, you may need to replace it.
Unfortunately, if none of the other solutions worked, your motor is going bad. Most of the time a new motor costs as much as the vacuum itself and it is not easy to replace the motor. It may be time for a new vacuum.
You can purchase a wide variety of high quality Bissell replacement parts for your Bissell vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/vendors?q=Bissell
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Jan 17, 2012 | Bissell 1699 ProHeat Clear View Upright...
My Bissell bagless vacuum does not seem to work anymore. It will start to with a suction and then instead of picking up the dirt, it appears to blow the dirt out almost in a cloud of dust and debris from...
this is caused by a dirty air filter and/or a blocked vacume hose ( most of the time the blockage is at the bend where the hose enters the floor sweeper area ) ---
remove and tap out and brush the filter ( or use a air compressor to blow out filter ).
then with the vacume on its side - remove the bottom plate ( like you were going to change the belt ) and use a coat hanger and clean out the hose between the floor sweeper and where the suction hoes attaches. this will restore your vacume to full operation.
c...
Jan 23, 2011 | Bissell 6595 Lift Off Bagless Upright...
No sucking the dust
Check the pipe up from the brush to the pump that it has not been blocked by an item too big to go through to the catcher
Jul 06, 2010 | Bissell 6594 PowerForce Bagless Upright...
No suction on Bissell Powerforce Bagless. Have thoroughly cleaned
Make sure you unplug before cleaning turn vaccum upside down check roller
for hair and strings wrapped around brush if this does not help clean out cylinder gently knocking dust out or use a duster to stick up inside lightly cleaning and check filter
Sep 30, 2009 | Bissell 6594 PowerForce Bagless Upright...
My vacuum puts out stinky air
We put small moth balls in our bag when we change it.
Jan 04, 2009 | Bissell 3522 PowerForce Bagged Upright...
Bissell Powerforce Bagless Vacuum
Either your hose is plugged, or the inlet by the brush roll is plugged. Another problem that can cause this is the the filters are clogged or may just need to be replaced. Most of these has a filter in the dust catch bucket, and also above the bucket. Make sure all filters are clean.
Jan 05, 2008 | Bissell 3594 CleanView PowerTrak Bagless...
Bissell vacuum problem
the motor as a cut out switch ,if the motor housing is full of dust , the motor will get hot and the switch will activate ,
Nov 20, 2007 | Bissell 3594 CleanView PowerTrak Bagless...
Bissell 3590 CleanView Bagless Upright Vacuum Logo
95 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
