Question about Proscan 20LA10CW 20 in. EDTV LCD Television
I hit a button on the side of the tlevision and no i have a message saying no signal all cables are plugged in
Figured out have to press the top side button chose tv then click the middle side button
Posted on Nov 19, 2009
Moved monitor to get to my modem. Buttons on bottom accidentally hit/sat on my fax machine. Now all I get is HDMI No Signal message then monitor goes immediately into sleep mode.
check hdmi cable in back of monitor and also in back of computer.
also try to restart monitor by taking out power cord and plug back in.
Mar 11, 2016 | ASUS Computers & Internet
Just got new Tv, worked great with color connectors husband wanted HDMI cable plugged into cable box now message says no signal..what to do?
change inputs on the tv by pressing the input button. sooner or later, you will find the hdmi input.
Mar 11, 2015 | Televison & Video
Samsung Syncmaster 2333
Check signal cables means there's no signal on input. If your PC still shows up on a different monitor then it's a time to replace a mainboard in your monitor.
Jun 03, 2017 | Samsung SyncMaster 2233BW 22" LCD Monitor
My tv is a hitachi hd ready flat screen plasma tv and i am using universal remote control The tv was working fine until i swtiched it off and hit one of the buttons on the remote - possibily the av...
What are u using for a signal source? Cable, Satellite, Over the air? My best guess is that you hit a wrong button such as the "source" button and the remote doesn't know what device you are wanting to opperate. Press volume up then down and see what light lights up?
If it is other than "TV" then you probably have the wrong device selected... Hope this helps... Sincerely HDTV GURU JAY
Mar 15, 2011 | Hitachi Televison & Video
Screen only displays a message that says, "no sync detected". This message is also displayed upside down. If I hit the 'menu' button on the remote, the menu is displayed on the screen upside down also.
Ur cable or satalite box it not getting the signal to ur tv.Unplug,replug the box about an hour,let ur boxes upgrade new software ur in comming tv broscast signal should return.
May 18, 2010 | Hisense TA42P-HDRA Television
"No Signal" on the TV
have you try to reprogram using menu setup/auto channel /before programming in tunner set upcoose cable
after reprogram select channel 3
hope that will helps
regards Alan
May 11, 2010 | Vizio L37 Television
Cable input is not working
Sounds like you mabe be on the wrong source. Try hitting the input button on the side of the set to change inputs. Input channel up or down find tv hit input again. If on the wrong input you will only get a blue screen and message no signal that will apear for a few seconds.
Sep 21, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
Will Not Find A Signal Polaroid HD 15" TV - Model TLA-01511C
same (tla-01911c) issue when trying to watch over the air brodcast try rescanning the channels that normally works for me
i got direct tv basic set on my S-video input so i only need over the air when the sat is down (i.e: storms, wind, snow, ...)
May 15, 2008 | Polaroid TLA-01911C TV
Going to Sleep
Due to the power surge, it is highly possible that the monitor was given a boot by your computer on it's way out.
This will short out a very small transistor inside the monitor on the video board and in turn, then monitor cannot see that there is a signal so goes to sleep.
If you get brave enough to venture inside the screen, then check near the cable input. The transistors are only around 3mm and have 3 legs (two one side and one in the middle on the other).
If you find anything like that burnt (get a magnifying glass) then replacing the board is the easiest option. Just don't be tempted to wipe the board before you look at everything very closely, you may wipe away the tiny bit of evidence you are looking for.
Hope it helps =)
Feb 12, 2008 | HP Pavilion F1903 19" Flat Panel LCD...
Frozen on a menu screen
Just fixed ours with the same problem. You need to hit the volume buttons on the remote during the time the screen goes black but BEFORE it gives you the "Connect cables" message.It should trick the TV into giving you a blank channel.
Sanyo TVs are made notoriously cheap, and have little glitches like this. Best of luck, space cowboy.
Oct 13, 2007 | Sanyo HT27546 TV
Proscan 20LA10CW 20 in. EDTV LCD Television Logo
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
