Question about RCA M4204 MP3 Player
Computer says device not found, went to RCA to download the driver, error message states player must be in msc mode, when plugged into computer the screen says usb connected
  • 26 Answers
There will be a setting somewhere on the player (usually in settings) that allows you to change the USB mode to MSC. The manual for your device should tell you how to do this. If you don't have the manual, here's a link. http://support.rcaaudiovideo.com/manual.aspx?product=392
Posted on Nov 19, 2009
Sansa e250 MP3 Player: The computer won't acknowledge that my Sansa E250 ...
Hope this helps. See the section about the hot fix first----- If you are using Windows XP: you need the following. Windows XP SP2 or higher Windows Media Player 10 or higher Download and install the latest Windows Media Player if it's not installed. If you are using Windows Vista: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player. Download the hotfix from-->>> http://support.microsoft.com/kb/939211. Run the hotfix. Refresh the players driver Connect the Sansa player to the PC The screen on your player should turn on, show 'Connected' and indicate the battery charging or full. If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub. - If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working. If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem. Check under Device Manager 1. Right-click My Computer, and select Manage. 2. Click Device Manager on the left pane. NOTE: Sansa MP3 Players can connect to your computer in MSC or MTP mode. Exceptions are Sansa Connect and Sansa Express which only use MTP mode. MTP mode is the recommended and default method for Sansa Players when used with Windows OS. The Sansa player will show up on Device Manager's right pane as: 1. USB Mass Storage device (if the player is set to MSC) 2. Portable Device (if the player is set to MTP mode) If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers. Refresh the drivers 1. Right-click the entry with the error mark, select Uninstall. 2. On the top menu, click Action then select Scan for hardware changes. NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem. Connect using MSC mode Connecting in MSC mode will help determine if there is a problem with MTP mode or with the Auto Detect mode feature of the player. You can use Forced MSC mode or switch the player settings to MSC. Instructions to connect in Forced MSC mode are listed here: http://kb.sandisk.com/app/answers/detail/a_id/61 Instructions to switch player to MSC mode are listed here: http://kb.sandisk.com/app/answers/detail/a_id/207 If the player is detected in MSC mode but not when set to MTP mode, try to update or reinstall the Sansa firmware NOTE: Sansa Express and Sansa Connect do not have MSC mode. For Sansa Connect you can try reinstalling the firmware using the Connect Recovery Mode. Additional troubleshooting notes: If you have replaced the Sansa Player and you still have problems getting it to recognize in the computer, then you may need to try some additional troubleshooting. - Try connecting on another computer. - Try using a different USB cable - Try connecting to the back USB ports which may supply better power. - If only MTP mode is not working, try reinstalling Windows Media Player For Windows XP try also download and install the MTP Porting Kit ......
May 16, 2010 | SanDisk Sansa e250 MP3 Player
Sansa e250 MP3 Player: won't play any music or change to any other format...
Hope this helps. See the section about the hot fix first----- If you are using Windows XP: you need the following. Windows XP SP2 or higher Windows Media Player 10 or higher Download and install the latest Windows Media Player if it's not installed. If you are using Windows Vista: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player. Download the hotfix from-->>> http://support.microsoft.com/kb/939211. Run the hotfix. Refresh the players driver Connect the Sansa player to the PC The screen on your player should turn on, show 'Connected' and indicate the battery charging or full. If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub. - If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working. If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem. Check under Device Manager 1. Right-click My Computer, and select Manage. 2. Click Device Manager on the left pane. NOTE: Sansa MP3 Players can connect to your computer in MSC or MTP mode. Exceptions are Sansa Connect and Sansa Express which only use MTP mode. MTP mode is the recommended and default method for Sansa Players when used with Windows OS. The Sansa player will show up on Device Manager's right pane as: 1. USB Mass Storage device (if the player is set to MSC) 2. Portable Device (if the player is set to MTP mode) If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers. Refresh the drivers 1. Right-click the entry with the error mark, select Uninstall. 2. On the top menu, click Action then select Scan for hardware changes. NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem. Connect using MSC mode Connecting in MSC mode will help determine if there is a problem with MTP mode or with the Auto Detect mode feature of the player. You can use Forced MSC mode or switch the player settings to MSC. Instructions to connect in Forced MSC mode are listed here: http://kb.sandisk.com/app/answers/detail/a_id/61 Instructions to switch player to MSC mode are listed here: http://kb.sandisk.com/app/answers/detail/a_id/207 If the player is detected in MSC mode but not when set to MTP mode, try to update or reinstall the Sansa firmware NOTE: Sansa Express and Sansa Connect do not have MSC mode. For Sansa Connect you can try reinstalling the firmware using the Connect Recovery Mode. Additional troubleshooting notes: If you have replaced the Sansa Player and you still have problems getting it to recognize in the computer, then you may need to try some additional troubleshooting. - Try connecting on another computer. - Try using a different USB cable - Try connecting to the back USB ports which may supply better power. - If only MTP mode is not working, try reinstalling Windows Media Player For Windows XP try also download and install the MTP Porting Kit ........
My Red Sansa Clip 4GB will not show on any computer i plug it into, It only charges and i have tried the auto detect, mtp, and msc settings. Any Suggestions?
May 17, 2010 | SanDisk Sansa Clip MP3 Player
Wont do nothin
Try and reset the player. Reset the player: 1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly. Then try this Connect the player to your computer. The screen on your player should turn on, show 'Connected' and indicate the battery charging or full. - If the player does not turn on try other USB ports or on another computer if one is available. Make sure you are connecting directly to the computer USB port and not to a USB hub. - If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the players screen is just not working. If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem. <<<<< BUT TRY THIS ALSO >>>>> Check the Device Manager 1. Right-click My Computer, and select -- > Manage. Click Device Manager on the left pane. NOTE: Sansa MP3 Players can connect to your computer in MSC or MTP mode. MTP mode is the recommended and default method for Sansa Players when used with Windows OS. *** See This Tip Posted here **** --> http://www.fixya.com/support/r3774047-solve_mp3_player_connection_problem <-- Copy this address into a new window. The Sansa player will show up on Device Manager's right pane as: 1. USB Mass Storage device (if the player is set to MSC) 2. Portable Device (if the player is set to MTP mode) If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers. Refresh the drivers 1. Right-click the entry with the error mark, select Uninstall. 2. On the top menu, click Action then select Scan for hardware changes. NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem. >>>> BUT TRY THIS <<<<<<< Connect using MSC mode Connecting in MSC mode will help determine if there is a problem with MTP mode or with the Auto Detect mode feature of the player. You can use Forced MSC mode or switch the player settings to MSC. Verifying and changing the USB mode of the device to MSC or MTP From the Main Menu, select Settings > USB Mode.
Mar 06, 2010 | SanDisk Sansa e260 MP3 Player
My mp3 player does not recognized by computer, i want to load some music. how do i solve it?
This may be caused by one of the following:
1. Minimum system requirements were not met.
2. Corrupted drivers.
3. Computer restrictions.
4. Power issue.
To resolve this issue, try the following solutions:
SOLUTION 1 - For brand new player or first time connecting to this computer.
For Windows XP users: verify the following operating system requirements are met.
- Windows XP SP2 or higher
- Windows Media Player 10 or higher
For Windows Vista users: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player.
- Download the hotfix from http://support.microsoft.com/kb/939211.
- Run the hotfix.
For MAC users, see Sansa player not recognized by a MAC OS
NOTE: If you are trying to connect to a Computer at work that is part of a network, there may be user right restrictions that are set to disable access to new hardware or stop any program installations. You may need to check with your IT administrator to see if this is causing the problem.
SOLUTION 2 - Refresh the driver
STEP 1 - Connect the Sansa player to the PC
- If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub.
STEP 2 - Check under Device Manager
STEP 3 - Refresh the drivers
SOLUTION 3 - Connect using MSC mode
for more answers at:
http://www.doremisoft.net/Sansa-Video-Converter-Mac/
or http://kb.sandisk.com/app/answers/list/
Mar 03, 2010 | SanDisk Sansa e250 MP3 Player
I have a sansa mp3 player and i put music on it the other day but when i plugged it in yesterday it said it had software that could be installed so i clicked on it and i didnt have the cd it came with so...
4. Power issue.
- Run the hotfix.
NOTE: If you are trying to connectto a Computer at work that is part of a network, there may be userright restrictions that are set to disable access to new hardware orstop any program installations. You may need to check with your ITadministrator to see if this is causing the problem.
- If the player does not turn on try other USB ports or on anothercomputer if one is readily available. Ensure you are connectingdirectly to the computer USB port and not to a USB hub.
- If there is nothing showing on the screen and the player does show upin as a storage device in an explorer window, then the screen is justnot working.
NOTE: Sansa MP3 Players canconnect to your computer in MSC or MTP mode. Exceptions are SansaConnect and Sansa Express which only use MTP mode. MTP mode is therecommended and default method for Sansa Players when used with WindowsOS.
NOTE: If a device with yellowexclamation point (!) continually appears and disappears, then theplayer is most likely failed. Additional troubleshooting is unlikely tocorrect the problem.
Connecting in MSC mode will help determine if there is a problem withMTP mode or with the Auto Detect mode feature of the player. You canuse Forced MSC mode or switch the player settings to MSC.
NOTE: Sansa Express and SansaConnect do not have MSC mode. For Sansa Connect you can tryreinstalling the firmware using the Connect Recovery Mode.
If you have replaced the Sansa Player and you still have problemsgetting it to recognize in the computer, then you may need to try someadditional troubleshooting.
If u have more questions, u can visit below sites:
http://www.doremisoft.net/Sansa-articles/Convert-video-to-Sansa-on-mac-osx/
Good luck.
Feb 25, 2010 | SanDisk Sansa e270 MP3 Player
My MP3 player is frozen and it dosent show up on the computer?
Reset the player:
Then try this
<<<<< BUT TRY THIS FIRST >>>>>
Solve your MP3 Player Connection Problem.
Refresh the drivers
Feb 22, 2010 | SanDisk Sansa e250 MP3 Player
HELP
Try configure your device as MSC mode first. To do so,
1. Go to Settings->USB mode
2. Choose MSC
The player will show up as a removable device once XP discover the device.
Apr 26, 2008 | SanDisk Sansa e250 MP3 Player
Deleting songs
i was having the same prob and trying to find a solution is a pain in the behind..... i decided to look up the manual and guess what i found... the reasoning to this very frustrating question...
The contents transferred in MSC mode will not be seen in the PC with MTP mode selected on your device.
The contents transferred in MTP mode will not be seen in the PC with MSC mode selected on your device.
now the solution step-by-step
1. turn on your player when not connected to your pc
2. press 'm' til you get to the menu
3. go into settings
4. go into advanced
5. this shows the protocol the player is currently using... hit your play/pause button and change it to the other protocol
6. turn off your mp3 player
7. connect to pc
now you can see all those songs you couldn't find and delete before...
i used windows explorer and there were all those songs i supposedly deleted.... i deleted them and guess what? instead of over 200 songs i now only have 77.... works perfectly... give it a try... this should work for everyone with this player...
Jan 12, 2008 | RCA H100 MP3 Player
RCA M4204  MP3 Player Logo
485 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
