Question about HP LaserJet Q2612A Printer
Why is my hp3030 printing light, enev with the
Why is my hp3030 printing light, even with the print darkness set to max. I'm using a new cartridge too.
  • 558 Answers
The Print head is dirty.Use the windows utlity or the hp utlity ro clean the head.
Good Luck
Posted on Nov 19, 2009
My Printer Prints Out Too Dark
go into printer properties and change the setting....you probably are using an after-market cartridge...they are notorious for being too dark....even if that is not the case, go to printer properties and change the setting....if there is no slide bar for heavy to light, then clik on toner saver, it should print lighter than it does now
Apr 27, 2012 | Samsung SCX 4600 multifunction Laser...
HP3030 won't print any image, even the test page comes out blank. Any ideas?
Dear Icare, If you are a technical person than only you can solve this problem otherwise you should take it to any technician. You printer's problem is not so major but doing this is major. There is a lens which situated in between the heater unit and the drum of your cartridge, when you set the cartridge. This lens only prints letters on drum and drum on paper. In your case there is some dust on your printers lens for which the lens can't print on drum and drum can't on paper. Hope it will solve your problem.
Sep 03, 2011 | HP LaserJet 3030 All-In-One Printer
Even though both the color & b/w cartridge are new my print job is very light
You can try setting that darkness in your menu for set up printing. That will make it darker. If this just happened after changing the ink clean the jets before setting the darkness.
Dec 17, 2009 | HP Photosmart C3180 All-In-One InkJet...
The black is not printing dark enough. It shows it
it is problem your printer black cartridge
you change it or
technicaly you drop your black cartridge in water withen two days after tow days you dry black cartridge and clean head printer maintai nence software then solve your problem
Jul 30, 2009 | HP DeskJet 5550 InkJet Printer
Used Office Max refill cartridges, leaked, now won't print color
The print driver on your computer maybe set to greyscale printing.
Jul 11, 2009 | HP Color LaserJet 2600n Printer
HP 1600 color laser printer--colors are out of sync
Check the following information please.
General print quality issues
Solving issues with color documents This section describes issues that can occur when you print in color. Color document issues Problem Cause Solution Only black is printing when the document should be printing in color.
c00659983.gif Color mode is not selected in your program or printer driver. Select color mode instead of grayscale mode. The correct printer driver might not be selected in the program. Select the correct printer driver. The device might not be correctly configured. Print a Configuration page.
One or more colors are not printing, or are inaccurate.
c00659984.gif Sealing tape might be on the print cartridges. Verify that the sealing tape has been completely removed from the print cartridges. The media might not meet HP specifications. Use a different paper, such as high-quality paper that is intended for color laser printers. The device might be operating in excessively humid conditions. Verify that the device environment is within humidity specifications. One or more print cartridges might be low. If you are using non-HP print cartridges, no messages appear on the device control panel or in the HP Toolbox. Replace any low print cartridges. The control panel is set for override. Replace low or empty print cartridges. A color is printing inconsistently after you load a new print cartridge.
c00659985.gif Another print cartridge might be low. If you are using a non-HP print cartridge, it might be low or empty but you will receive no indication. Remove the print cartridge for the color that is printing inconsistently and reinstall it. The control panel is set for override. Replace low or empty print cartridges. The colors on the printed page do not match the colors as they appear on the screen.
c00659986.gif The colors on your computer monitor might differ from the device output. Select Screen Match in the Color tab of the printer driver. If extremely light colors or extremely dark colors on screen are not printing, your software program might interpret extremely light colors as white or extremely dark colors as black. If possible, avoid using extremely light or extremely dark colors. The media might not meet HP specifications. Use a different paper, such as high-quality paper that is intended for color laser printers. The finish on the printed color page is inconsistent.
c00659987.gif The media might be too rough. Use a smooth paper or print media, such as a high-quality paper that is made for color laser printers. Generally, smoother media produces better results. Repetitive image defect ruler Use a repetitive image defect ruler to measure occurrences of repetitive image defects to help solve image quality problems. Place the ruler next to the first occurrence of the defect on the page. Find the distance between identical defects and see the Repetitive image defects table to identify the component that is causing the defect. Repetitive image defects Measurement Component 24.7 mm0.97 inch Developer sleeve 26.7 mm1.05 inches Charge roller 32.9 mm1.3 inches RS roller 37.7 mm1.48 inches Transfer roller 54.5 mm2.15 inches ETB rollers 56.6 mm2.22 inches Fuser sleeve 62.8 mm2.47 inches Pressure roller 75.4 mm2.97 inches OPC
Have a good evening
Jun 18, 2009 | HP LaserJet 1600 Printer
Printer prints very light
its may be happend due to the Dust in the LSU unit.
remove the LSU from machine and open. Then after clean all the mirrors and polygon .
after that your problem should be solved.
Mar 03, 2009 | Samsung SCX-6320F All-In-One Laser Printer
Print Cartridge Problems
i have an mp170 all in one and when you fill the cartriges they dont show up as full cannon put a chip in the cartridge to con people into buying new ones try siting the cartridges in warm water for a few hours then blot the cartridge with tisue paper if it dont blot out the ink the cartride is finnished and you need a new one .To align the cartridge you flick through the menu on the printer not pc screen look for alignment page print this off then you have to pick the dark boxes on the sheet shade the bit next to it and put on your scan bed and click ok it should scan the sheet and reset the alignment
Jul 19, 2008 | Canon PIXMA MP180 All-In-One InkJet...
LaserJet 6L Prints Outlook content too light
I also had the google maps print issue on my HP3030 and fixed it by setting the "Default Quality" under "Copy Setup" from the HP3030 menu to "Photo" from "Test".
That's a hardware setting on the HP 3030:
Menu/Enter > Copy Setup > Default Quality > Photo
Hope this helps.
Terry
Sep 30, 2007 | HP LaserJet 6Lxi Printer
HP LaserJet Q2612A Printer Logo
295 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
