Question about Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum
Brushes on Hoover steam vac dual v do not turn
    Scholar:
  • 190 Answers
(1) Assure the Brush Control on the hood is NOT set to the OFF position.
(2) Remove the brush assembly by pulling/unlatching it from base on each side.
(3) Does one of the brushes have the drive pin present? It should be about ¼ inch square, and two inches long. It attaches the brushes to the drive mechanism.
(4) Remove and clean the intake filter. One the base of the cleaner, behind the brushes, squeeze the two red abs together and pull the panel down to access the screen. Clean the hair/debris off the screen and reassemble.
Posted on Nov 20, 2009
Brushes stopped turning
check the drive peg that turn the brushes it may have broke and needs replaceing this link is for the manual it will show you how to get the brushes off.
http://hoover.com/file/670/
Aug 11, 2012 | Hoover Steam Vac Dual V w/ SpinScrub...
I have a Hoover Steam Vac Dual V and the brushes no longer turn. Can it it fixed? Model # F7431-900
your belt is probably brokan. underneath the machine you will see some screws carefully take them out writing down which screw went where. than you can pop the plate off and look in there and see if your belt is brokan. If it is the belt number is important to find in your book that came with the machine. hope this helps you.
Aug 16, 2011 | Hoover Steam Vac Dual V w/ SpinScrub...
How do we get at the drive belt? The cover seems to be sealed.
There is no belt in a Hoover SteamVac. The brushes are turned by an air driven turbine. If the brushes are not turning, it is usually because the turbine has seized up and may need replacement. Insert a screwdriver into the square hole that the pin on the brush assembly normally fits into and see if it turns. If it doesn't, you will need a new turbine.
Jun 21, 2011 | Hoover Steam Vac Dual V w/ SpinScrub...
The Hoover steam vac dual v does not spin its brushes and I dont know how to dismantel it to view the belt .
There is no belt on the steam vac - it operates on air flow. Remove the brush and insert a flat screwdriver into the square hole. If it does not turn, the turbine has seized up and must be replaced. Remember that the brush will not turn unless the lower tank is in place, and the handle is tilted back.
Jan 28, 2011 | Hoover SteamVac F5914-900 SpinScrub...
I have a hoover steam vac dual v. The brushes will not rotate
The brushe holder is not snapped in correctly. You have to push it in hard.
Aug 20, 2009 | Hoover F6213-900 SteamVac Agility...
The brushes on my steam vac won't spin
I used the suggestions found from a previous question found on your site.. thanks though. will recommend your site to all.
Aug 19, 2009 | Hoover Steam Vac Dual V w/ SpinScrub...
My Hoover steam vac has two small springs that have come loose.
How do I replace the turbine? How do I remove the casing to get to the turbine? I do not have the manual anymore.
Dec 10, 2008 | Hoover Steam Vac Dual V w/ SpinScrub...
Brushes not rotating on my Hoover Steam Vac Dual
The brushes are all connected to a single shaft. This square shaft is connected to 2 sets of gears and then another shaft which is turned by an impeller (suction from the vaccum pump is used to turn the impell and thus the brushes). There are 2 bearings that the impeller shaft turns on. It's likely these are rusted up and just need a bit of WD 40. Took me 30 min to take apart, lube, and put back together. Remember, its plastic. If things won't come apart, look for another screw. Mine was a brand new unit and the top bearing was rusted.
Sep 22, 2008 | Hoover Steam Vac Dual V w/ SpinScrub...
Hoover steam vac dual model F7425900
If you are talking about the brush block, take it out and see if the shaft that goes up into the turbine is broken off, if not, then the turbine has gone bad and will have to be replaced. The turbine is what turns the brushes.
Jan 20, 2008 | Vacuums
Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum Logo
137 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
