Question about Panasonic PT-47WX53 47" Rear Projection HDTV
Our Panasonic PT-47wx53g TV turns on for just a second and then clicks off ... do you have any suggestions on how to fix?
  • steveroberti Nov 25, 2009
    hay my indicator blink 3 time
  • SD Tech
    SD Tech May 11, 2010
    Does the power light on the front of the set stay on and then blink? If so, count the blinks--it will be an error code that may tell what the actual problem is. sd tech
    President:
  • 788 Answers
If you can not power on your set your symptom sounds like a damaged convergence IC.
You should be able to get a local service center to repair this at
your house for between $350.00 - $450.00, If you want to repair this set yourself, I have some instructions below that will be a help to you.
While it is not a very hard repair, this repair can be a bit tricky. If you have a 45W soldering iron, solder, solder wick, and
heat sink compound you can repair it yourself.
When you remove the old IC's, please be sure to remove all of the old
heat sink compound, as it can act as an insulation for the new IC's and cause them to overheat. I usually clean the heat sinks with alcohol and a small rag.
There are two and large IC’s that control the convergence in a big screen set. Some of the newer sets only have one. If you only have one, it is right in the middle of the set on the center
circuit board. They are secured to a very large aluminum heat sink. They will have a part number stamped on them that will start with an STKXXX-XXX, like STK392-110.
Along with the convergence IC’s there will also be some associated components that will need to be replaced as well. There are some resistors that are part of the convergence circuit that will be open and need to be replaced. Most likely these will appear charred in the center. If you have an Ohm Meter or a DVM, check all the resistors that are close to the IC’s and you should be looking for either ones that have opened or have changed values.
If one of the convergence IC’s are found to be bad, I would replace them both, if one has gone bad the other may go soon. I usually order my parts from Andrews
Electronics in California, they will have the OEM components that you will need.
Their site is
http://www.andrewselectronics.com/welcome.aspx
And their
phone number is a 24-Hour Order Desk: (800) 274-4666
I recommend the
phone order so you can talk to the person about the different types of IC’s that are available.
I would also advise that the convergence IC’s be OEM or better, just because they are cheap does not mean that they are a
good deal. I have seen the cheap IC’s fail after a short time, even though they look exactly like the OEM IC’s. I think that the bottom line is that you will get what you pay for when it comes to the parts.
You can also try
http://www.tvrepairkits.com/ , I have not tried them yet, but they do carry OEM or better parts.
I hope this
information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you cannot rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
If you need further assistance please comment to this post and I will try to help you further.
Thanks for using FixYa
asnowman
Posted on Dec 03, 2009
  • Panasonic Master
  • 8,617 Answers
Dies the power indicator blink/ If so let me know the number of blinks
Posted on Nov 20, 2009
Pt-47wx53g tv won't click over n than the power button will blink 5 times
IC4511 has failed on the DG board replaing the DG board as a unit i the only way to fix the issue. The DG board isnt serviceable
Jun 01, 2012 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic pt-47wx53g tv power light blinkcs 5 times and goes out.
Convergence problem...causing the TV to shut down. Goto www.TvRepairKits.com and get one of their fixes.
Jun 04, 2010 | Panasonic PT-47WX42 47" Rear Projection...
PT-47WX53G. TV got moved. Unable to move blue
The convergence ICs have failed which is very common when the set has been moved as a wek IC wont allow the color to be moved. You can get the PT52WX53G convergence repair kit from www.tvrepairworld.com which is the correct one for your model. The kit contains the parts and the CD with repair instructions.
Apr 10, 2010 | Panasonic PT-53TW53 53" Rear Projection...
Hi, We need solution for B-Ray connection to PT-47WX53G
We solved the problem with Sony experts from Vio. Thank you
Jan 03, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic PT-47WX53G
Leave a email at the following link, they can remanufacture your panasonic board and the carry a 6 month warranty. Heres the link.
http://servicemanuals.vstore.ca/
Aug 13, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic PT 47WX53G
Replace STK392-110 IC's ( both ) with PANASONIC part
# C5AA00000203.........DO NOT use generic IC's !
Terry.
Jul 22, 2008 | Panasonic PT-47WX53 47" Rear Projection...
How many times is it blinking? That is probably blinking a code because its shutting down. Let me know how many blinks its blinking and I will be able to tell you whats wrong with your TV
Apr 12, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic PT-47WX53 does not turn on
Yes, I did try to use the power button on the TV itself. That did not work too. Yes, there is blinking red light too. I searched through several sights and found out that it is an issue with the IC 4511. I could not find a place to buy the chip.
By the way, our local TV dealer asked for $400 to fix this issue. I had already spent $400 on a different repair on this TV, 6 months ago.
Any suggestion/advice would be very helpful. Thank you again for your response.
Feb 18, 2008 | Panasonic PT-47WX53 47" Rear Projection...
How to reset defaults Panasonic HD PT-47WX53G TV/picture
First of all are you sure you were in the factory menu this step requires alot of known how!!!!!! By using your hand unit only customer controls can be reached unless you know factory menu setup. Which starts like this ,make sure antenna to cable then go to menu set sleep timer to 30 mins exit out now enter ch 124 then press v- down on tv you should now see on top CHK ,also these sets have double convergence patterens.if you were in factory set up for more information look in www.freelists.org techassist/09-2005 .let me know if you still need help.
Nov 14, 2007 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic PT-47WX53 47" Rear Projection HDTV Logo
209 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
