Question about FixYa Computers & Internet
On a 2005 chevy colorado with a 3.5 i have been talking with you about a code po449. fixya told me that the evap purg soleniod sould take care of this problem. the chevy dealer says that there are two purge soleniods. one by the fuel tank and the other on the left side of the engine. would you know which one i sould start with
    Brigadier General:
  • 3,513 Answers
Here is an easy fix to your problem. You will need one single common screwdriver! Get under the vehicle after putting on the parking brake. The EVAP solenoid is easy to spot near the gas tank and it has one electric connector which disconnects by releasing the plastic clip and pulling the connector out. It also has one air line connected which goes to the charcoal canister which also can be removed with the one screwdriver. The whole EVAP solenoid and air can be removed with the screwdriver which makes it easier to unplug the electric and air line. Get a replacement from the dealer as they certainly are familiar with this part as they sell lots of them. Then just go under and plug the new one in and the problem is solved. Now if you do not have a tool to reset the codes, try the local parts places as most of them will do a reset for you.
Let us know if you want something else please accept the solution.
Thank You for contacting fixya.com
Posted on Apr 19, 2010
Is there a sensor on the top of the tank on a 2004 Colorado or just the one on the char-co canister and the one under the alt ? thanks
There is a pressure sensor on top of the tank , The sensor at the evap canister is not a sensor , it is a evap vent solenoid . The thing under the alternator is the purge soleniod . You would need to remove the fuel tank to replace the fuel pressure sensor . How to troubleshoot an EVAP Pressure Sensor problem P0452 GM
Apr 30, 2017 | 2004 Chevrolet Colorado
Location of evap purge valve solenoid on a 2004 chevy Colorado z71 4x4 3.5l looking from the front of truck
. .It's on the side of the engine under intake manifold in the middle between the starter and the alternator .
Evaporative Emission (EVAP) Canister Purge Solenoid
Left side of the engine below the intake in back of the alternator
Dec 31, 2016 | 2004 Chevrolet Colorado
How can I replace a canister vent solenoid for a 2006 Chevy Tahoe code 449/300
Google the location & a picture & replace yourself
Has to be near the fuel tank
PO449 is the Evap Vent Solenoid
PO 300 is random cylinder misfires maybe from the
extra air, when the evap purge runs
Aug 13, 2014 | Cars & Trucks
09 Chevy colorado code p449
PO449-- Evap Vent Valve/Solenoid Circuit Malfunction
PO441--Evap Purge Valve Incorrect Flow
PO 443,444,445 Purge Control Valve Issues
There was no reason to change the gas cap or
purge control valve
Didn't Google the code & use it correctly to diagnose
the problem
Mar 23, 2013 | 2009 Chevrolet Colorado Extended
Code po449 2009 cobalt
The PCM has determined that a malfunction exists in the electrical circuit for the vent valve/solenoid in the evaporative emission control system.
Definition:
EVAP (Evaporative Emission System) purge/vent solenoid circuit condition
Explanation:
The solenoids and system wiring are monitored for opens or shorts
Probable Causes
1- Purge or vent solenoids defective
2- Check connevtor and wiring
3- Fuel saturated vapor canister
4- Failed EVAP vent solenoid
Feb 17, 2013 | 2009 Chevrolet Cobalt
Po449 0n 2006 chevy cobalt
P0449 control vent valve/solenoid circuit malfunction, This code necessarilly deal with replacing the vent solenoid it about the circuit,the evap vent solenoid circuit may have rub through on the frame (located on the back of the fuel tank),it can also be the connector,the vent solenoid itself,or the connector
Mar 24, 2012 | 2005 Chevrolet Silverado
2005 chevy Z71 check engine code PO449 and PO455 5.3 Lt engine how do i fix them
get a new gas cap your evap sytem isnt working if the gas cap doesnt work then you might have a leak and check your EVAP purge valaves
Dec 07, 2011 | Cars & Trucks
Getting an error code of PO449 for a check engine light. this says it is the Evaporative Emissions Control System Vent Valve/Solenoid Circuit Malfunction. I keep looking for a replacement part of the vent...
You are right. You need the vent valve not the purge valve. The vent valve is a dealer item. Also this is a common problem and GM has released a bulletin on this that involves moving the location of the valve and running some new lines. It comes as a kit from GM, and it costs about a 100 bucks.
Dec 02, 2010 | 2005 Chevrolet Silverado
Chevy colorado code 420 and 496 whats the problem?
code 420= Catalyst system efficiency below threshold(bank 1) code 496=Evaporative emission system-high purge flow. Hope this helps if you need more help get back to me Thanks Ray
Feb 15, 2010 | 2005 Chevrolet Colorado
2005 chevy cobalt 37.000 miles engine light on. Code is obdIIpo449b any idea what it is the car runs great
CODE PO449 - EVAP VENT SOLENOID CONTROL CIRCUIT MALFUNCTION.SOUND LIKE EVAP VENT SOLENOID HAS FAILED OR A BLOWN EVAP VENT SOLENOID FUSE.
Aug 28, 2009 | 2005 Chevrolet Cobalt
Computers & Internet Logo
Top FixYa Computers & Internet Experts
Mark Magill
Mark Magill
Robin Hill
Robin Hill
Are you a FixYa Computer and Internet Expert? Answer questions, earn points and help others
