Question about liftmaster Chamberlain Garage Door Opener Transmitter 300MC
I pres the remot and the door goes up several feet and stops. The only way it goes up is if I hold the remote until completely up.
    Problem Solver:
  • 7 Answers
Sounds like the door is jamming or possibly needs WD-40 on the tracks and rollers. Also, it might need adjustment on the force on the way up. Be careful and just give it enough to do the job. Let me know if this works.
Cabinetman54
Posted on Nov 19, 2009
How do I change the frequency of a garage door opener 139.53930ODM?
Hi... You have to "erase all codes" (you can read that section of the manual and teach the opener to use the remote using a new code. You can get the manual at the Craftsman site, page 35. Essentially you do this: access the reset button n the back right of the motor, press and hold the 'learn' for 6 seconds or more,until the learn light goes off. TO reprogram it, press the learn button until the light goes on, then within 30 seconds, press and hold the desired button of the remote. Voila!
Dec 26, 2014 | Chamberlain Liftmaster 355LM 315MHz Garage...
How to programme remote for coromaster 2000 garage motor
To re-program the open and close limits do the following: Ensure that the door is open at least a couple of feet. Press the reset button once or twice Short out pushbutton and common and hold until close limit and then release. Door should stop at your new close limit. Wait 5 seconds. Short out pushbutton and common and door will open. Hold the short until open limit and then release. Limits should now be set.
Jun 14, 2011 | GPS
I used shift to us the remote control with the secondary TV. Now i cannot get it to correspond with the main tv. How do I fix the problem. Thanks
If u stil hve the manual, plz consult it. OR u press n hold shift, pres ur device button (tv), indicator light starts blinking, pres n release ur search/power button continuosly, whn u get response from ur tv, leave it 4 a few seconds, the light goes off n ur remote is set again.
Apr 10, 2011 | Universal Remote Control Dish Network...
What garage door opener is programable with a Mountaineer? I had an opener in my previous home that the sales rep programmed from the remote...my current door remote cannot be programmed. I am buying...
Press and hold the two outer buttons on the homelink system in the car until the led flashes rapidly or goes out. Then hold the programmed remote up to the homelink system and at the same time press the button on the remote and the button on the homelink until the led light blinks rapidly or goes out. It should take less than 30 seconds. ----- Then go to the motor head and press the colored learn button on the motor head and go back to the home link and press the homelink button 3 times to activate. If your opener has dip switches stop at -----. Thanks BB
Sep 17, 2010 | 2003 Mercury Mountaineer
I have sears opener #139.53989. Every once in a while I have a down problem. It goes down within an inch of the floor and reverses. Sometimes I can hold the wired remote button and it will go all the way...
If the main light flashes 10 times when the door reverses it is a sensor problem. Check them very closely. If they are just a little off one of them will be flickering but it is difficult to see. This can also cause the problem to be intermittent. Tweak them just a little.
It is normal for that light to blink randomly.
Jan 27, 2010 | Sears Craftsman LiftMaster Chamberlain...
How to program 2005 toyota sequoia garage door opener?
Hello.I will be glad to help you out.
Choose which of the 3 buttons you wish to use, on the car.
Take the remote transmitter, depress the actuator button, and continue to hold it until advised to release.
Depress the button, on the car, of your choice, and hold it down until advised to release.
Hold the garage door actuator (while holding the actuator button down) above the car's 3 buttons.
Rotate the door transmitter until the red light above the 3 buttons starts to flash slowly.
Stop moving the remote around when the light flashes slow.
Within several seconds, the same light n the car will now flash rapidly.
Release the car's button, release the transmitter button.
Verify that the door now operates..
Nov 29, 2009 | 2006 Toyota Sequoia
How do you set the garage door opener for a 2004 toyota 4runner LTD?
You hold the remote close to the three buttons on the vehicle. You choose which button you want the remote to transmit to, and you hold it down. With your other hand, depress the garage door remote opener, and hold it very close to the 3-button assembly. Wait for the red L.E.D. light to blink slowly. If it does not blink slow, continue moving the remote around, until it does blink slow. When it starts to blink slowly, stop moving the remote around. Wait until the light starts blinking rapidly. When the light blinks rapidly, the process is complete.
Oct 28, 2009 | 2004 Toyota 4Runner
Remote control codes needed
turn your device on, press device key(tv,dvd,etc) press and hold Setup (led blinks twice), pres 9-9-1(led blinks twice) press power key , press channel + repeatedly until device turns off, press setup untill device turns off. good luck
Mar 22, 2009 | Televison & Video
Chamberplain Garage Door Opener problem
IF U HAVE TWO EYE,SENSORS ON EACH SIDE OF THE DOOR SEE IF SOMETHING IS BLOCKING THE EYES OR SOETHING IS COVERING THEM, OR THEY ARE OUT OF ALIGNMENT, ONE SHOULD SHOW GREEN, AND ONE RED EYE, GOOD LOCK
Jan 25, 2009 | Sears Craftsman LiftMaster Chamberlain...
liftmaster Chamberlain Garage Door Opener Transmitter 300MC Logo
87 people viewed this question
Top liftmaster Electrical Supplies Experts
Vince Heuser
tamska1102
Level 1 Expert
ray gallant
Are you a liftmaster Electrical Supply Expert? Answer questions, earn points and help others
