Question about Compaq Presario R3000 Notebook
I took the keyboard out to clean under it.since i plugged it back in there is no more keyboard. it is a compaq presario r3000.both cablesconnected back
  • 458 Answers
Your cable is not seated correctly then... Disassemble and Double/Tripple check your connection...
Posted on Nov 19, 2009
Bad keyboard. Intyping the letters skip around. Can't pin it down to any specific letter. Can I replace the keyboard?
yes you can replace keyboard $13 on ebay
http://cgi.ebay.com/HP-Compaq-Presario-M2000-R3000-V2000-V5000-Keyboard-/180543589690?pt=PCA_Mice_Trackballs&hash=item2a093c8d3a
Sep 02, 2010 | Compaq Presario R3000 Notebook
Why does my Compaq laptop keyboard free up and not work? My laptop keyboard will not work, but the mouse will. i have to use an external keyboard.
You may try to update the driver software to see if works. Please take it to the repair shop to check if it is defective. If you need a new HP Compaq Presario R3000 keyboard?¼Œ you may go to http://www.newlaptopkeyboard.com to order a new one.
Feb 17, 2010 | HP Laptop Keyboard for HP Compaq Presario...
Where is the internal battery located?
The internal battery is on the upperside of the motherboard. To get to it you have disassemble the laptop. Here's a walkthrough on how to do it: http://www.takeitapart.net/archives/compaq-presario-r3000/ . Good luck.
Jan 03, 2010 | Compaq Presario R3240US Notebook
How do I remove the keyboard?
you will need to remove several screws on the bottom at the back and then gently pry off the cover around the back top of the laptop. under that will be three screws holding in the key board
Jun 27, 2009 | Compaq Presario R3000 Notebook
Compaq Presario R3000 dim screen but not dark
Sounds like the auto-dim in the BIOS is set too low. Fortunately the Compaq R3000 allows you to adjust the brightness right from the keyboard. Hold down the [FN] function key while tapping the [F8] key will brighten the screen, while [FN]-[F7] will dim it. The settings are different for running on AC power and battery, so you must do each individually.
Dec 31, 2008 | Compaq Presario 700 470024-192 Notebook
Presario r3000 too slow
I have a R3000 and after many years of usage many things happen and add to your hard drive. It can be a number of things from not enough hard drive space for your cache file to bad installed drivers.
I would suggest a full format and install using the backup disk that Compaq sent with the system. You should have the WinXP code on the bottom of the computer. This way you get a 100% clean system. You will have to reinstall any additional software such as MS Office or your virus scanner.
Hope this helps
Dec 13, 2008 | HP Laptop Keyboard for HP Compaq Presario...
Compaq Presario R3000 PC
Hi Tom,
It appears without looking at the laptop you have removed or dislogged the cable that goes between the motherboard and the screen. This is not hard to do they are very delicate. The only thing you can do is take it to a qualified service tech. i get these periodically in my shop too. Check the cable before you do so to see if you can reconnect it but be very carefull.
Be mucho blessed,
Mark
Jul 18, 2008 | Compaq Presario R3000 Notebook
COMPAQ PRESARIO R3000
Greetings Myname is Mark and I'll be glad to assist you.
I need some information so I can do some research for you.
1. What is the make and model of your laptop
2. Did you use a cleaner or water at any time.
3.What was the reason for removing the back panel.
Please let me know and I can follow up for you,
Be mucho blessed,
Mark
Jul 13, 2008 | Compaq Presario R3000 Notebook
Keyboard caps on compaq presario r3000
buy a deffective keyboard off ebay and just pull the caps that you need an plug it to your old keyboard. it should be pretty easy
Apr 07, 2008 | Compaq Presario R3000 Notebook
Compaq Presario R3000 Notebook Logo
80 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
