Question about Whirlpool Washing Machines
Awo5761 front loader washing machine tells me fog on the little screen please help
  • 276 Answers
AWO5761 is a correct model number.
From the Service Manual, F06 for this model means Tachometer failure (no motor movement detected). I'm not a washing machine repairer but just came across your question whilst looking for a picture of this model for a customer!
Posted on Nov 30, 2009
    Novelist:
  • 143 Answers
This model is incorrect...You should be able to locate the model and serial inside the door on a sticker or a plate. If it isn`t there it will be on the back of the unit. however what you are most likely seeing is the error code F06 not FOG. This error code basically means that there is an error occuring while in the spin cycle. The motor control board may have a problem as well as the motor wiring harness. I would have it properly tested by a technician to ensure a proper diagnoses.Hope this helps
Thanks
Posted on Nov 19, 2009
My washing machine fills with pieces of black matter. I have done machine clean washes and it still happens every time, covering my clothes in black pieces that look like cardboard. Please help my - the...
Hi mine does exactly the same! I have to call in my washing machine technician more often (he told me this would happen with a top loader as opposed to a front loader, boy was he right!!) and he cleans out the drum. Mostly it is the fabric softener which is too thick. I water mine down to 50/50 and I do another spin after my final wash. I also empty the filter of water at the side/bottom of the machine. This annoying problem is caused by the way the drum turns on a top loader as opposed to the front loader. My top loader cannot heat water automatically either like a front loader, and I think this also adds to the problem as hot/boiling water would dissolve all that soap/fabric softener. Hope this helps.
Jul 12, 2014 | Samsung SW62ASP Top Load Washer
I have a LG Front loader machine, WD-10485TP displaying CL error code. Please help.
CL means that your washing machine's CHILD LOCK is ON. You can find two buttons Temp and Options in the panel. Turn ON the machine, press these two buttons together for 3 seconds and that's it. It might have a little kids face above a lock key, in between the wash and rinse buttons, hold these for 3/5 seconds and it should work.
If problem remains unresolved, revert and i would tell you few more methods.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Aug 22, 2011 | LG WD-1280FHD Front Load Washer
Clothes smell mildewy after washing and drying
This is a common problem with front load washers. Mildew tends to grow in these washers due to it use of less water than top loaders, often leaves dirt and soap residue on the machine. To help prevent mildew, wipe the door gasket, leave door and detergent dispenser open after wash. Wash once a month empty, with hot water and vinegar to kill the mildew in the machine.
Jul 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
The cold water inlet is slow to fill machine but the hot water inlet works fine
Hi just read your posting.Could you please supply the model of your hoover and tell me if it is a front or top loader.The fault on your machine is due to a faulty cold water valve or dirty inlet filter.Turn the cold tap off and remove the cold water hose from the tap end and check to see if the little filter at the end of the hose is blocked.If it is, clean it and put back the hose to the tap and try a wash cycle.Please reply with additional information and to tell me how you got on with the filter.
Jun 29, 2010 | Washing Machines
Why is my washing machine leaking at the front?
It dpends on WHERE the leak is coming from and whether this is a FRONT LOADER, or a TOP LOADER.
This link explains how to inspect a FRONT LOADER for leaks:
http://www.fixya.com/support/r3576656-washer_leak__front_loader
This link explains how to inspect a TOP LOADER for leaks:
http://www.fixya.com/support/r3576648-washer_leak__top_loader
If you washer differs from the instructions I've provided, please post back with a BRAND NAME and MODEL NUMBER. This helps us properly diagnose problems. If you have addtional questions, please let me know.
Dec 24, 2009 | Washing Machines
My Frigidaire front loader (about 14 months old) won't drain. It hums (or buzzes) loudly and does nothing.
you really need to tell me a little more;is the drum turning does the machine wash other than this hum is everything else ok?I would say there might be a sock or simler stuck in your drain pump as i dont have enough information i cant really tell you anymore.adrian
Feb 18, 2009 | Frigidaire ATF6000ES Front Load Washer
Crosley Front Load Washing Machine
FL is a flood condition fault, too much water in unit. i would turn off water supply and try to spin water out. select spin button, should put 8 min on timer try startin that water should pump out then if not you got somethin stuck in pump (lint likely)
Feb 22, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
152 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
