Question about Cameras
I am trying to play old mini DV tapes on a JVC GR-DV1U and I keep getting EO3 messages after a second or so of playback. Please help, Thanks! Jon
  • 73 Answers
SOURCE: JVC GR-D33US Mini DV Digital Camcorder?
TAPE TRANSPORT PROBLEM.. GET ANEW ONE
Posted on Feb 23, 2008
StuartB
  • 807 Answers
SOURCE: Im trying to import videos
As it's a DV (Digital Video) camera you should use the IEEE 1394 Firewire socket if it has one. Then use a DV capture program.
If you dont have a Firewire port on your PC you can buy a card like this one which will connect you Camera to your PC.
http://www.amazon.com/D-Link-3-Port-IEEE-Firewire-Adapter/dp/B00004XRD3
Posted on Mar 13, 2008
SOURCE: JVC Mini DV Camera - Lens cap
Lens may be closed with a cover or with some kind of dust or dirt.
Aim at bright light subject. Get out of the house and try to capture in outdoor.
Posted on Apr 02, 2008
marked
  • 6487 Answers
SOURCE: I have a JVC GR-D30U
This is a mechanical problem with this JVC GR-D30U that alot of user are also having problem , what I can suggest you to do with this is to take it to JVC service center and hopefully they can fix it since alot of problem are reported with this type of device and it ended up being replace....
Good luck............
Posted on Sep 01, 2008
micromaster
  • 3614 Answers
SOURCE: JVC GR-D30U Digital Video Camera error E04
there was a hole under the tape deck.. u can try to force;y open it right there
JVC mini Dv GR-D720E has small squares on playback
Indeed it seems that there was a really stubborn bit of dirt on the heads. I had to use the cleaning tape several times to ultimately have a clear picture on record and playback.
thanks again ,but successive cleaning can help for an effective cleaning of the tape path and heads.
Feb 04, 2010 | JVC GR-D73E Mini DV Digital Camcorder
How to switch from sp to lp mode when playing back?
Did you try setting the rec mode to SP in the playback menu?
a54f98a.jpg This is from the D250 manual.
Dec 18, 2007 | JVC GR-D250 Mini DV Digital Camcorder
Gr-dvl-520u trying to record or playback tape it goes into safeguard mode within 5 seconds. alternatly pressing play and still every 3 seconds advanced the playback without it going into safeguard mod
According to http://www.techlore.com/article/10974/JVC-Camcorder-Stuck-in-Safe-Mode/,
"JVC notes that you are also given a malfunction code when the unit is placed into safeguard. If it displays code 01, 02, or 06 you should remove
the battery and powersupply and wait for a while. Code 03 and 04 indicate that you should eject and reinsert the tape.
If neither of these solutions work, your only alternative is to bring it to a shop or send it to JVC for diagnosis or repair. Unfortunately, there is no other way to clear the condition."
If you are getting E03 or E04 errors on every tape you try, it sounds like a servicing is required.
Apr 17, 2009 | JVC Cybercam GR-DV500US Mini DV Digital...
JVC Gr-DVL300 Won't playback
The heads are probably dirty. First you can try to let a tape run through from start to end and see if it cleans the head. then try running in reverse play scan. Next try a head cleaner tape if you have not yet. If these things do not get your picture back you should take it to a repair shop, I do not recomend taking camcorders apart for cleaning at home. Full size VCR's are ok to clean your self with instructions but not camcorders because they are vary easy to damage worse without experiance and proper tools.
Jul 09, 2008 | JVC GR-DVL300 Mini DV Digital Camcorder
E03
my jvc gr-DVX MINIDV PAL KEEPS GETTING ERROR CODE EO3 PLEASE HELP
Dec 04, 2007 | JVC GR-DVL20EG Mini DV Digital Camcorder
JVC GR-DVL120 Playback
hi
you should have the heads cleaning,
try to put a cleaning tape and run it for playback then try recording again
thx.
Nov 20, 2007 | JVC GR-DVL120 Mini DV Camcorder
GR-D72 Mini DV Digital Camcorder makes clicking sound when tape running
the clicking is from the capstain turning the tape -- and perhaps the metal cage holding the tape.. if it is bent then the movement of the capstain may be pushing it in an eccentric fashion.
send it in for repair.
Oct 15, 2007 | JVC Cybercam GR-D72 Mini DV Digital...
Bad playback
Please try to buy a head cleaning tape and put in your camera and play for three times..Then record a cassette and play,if you are not getting the picture replace the drum assy and check.
Oct 12, 2007 | JVC Cybercam GR-DVP9 Mini DV Digital...
JVC GR DVL 9000 digital video camera EO3 problem?
In the case no REEL FG is produced for 4 seconds
or more in the capstan rotation mode after
loading was complete, the mechanism mode
is shifted to STOP with the pinch roller set off.
This error is defined as [E03].
However, no REEL EMG is detected in the
SLOW/STILL mode.
1. The idler gear does not engage with the reel disk well.
2. Though the idler gear and reel disk are engaged with
each other, the tape is not wound because of overload
to the mechanism.
3. No FG pulse is output from the reel sensor.
4. No power is supplied to the reel sensor.
5. Tape transport operation takes place with a cassette
having no tape inside.
6. The tape slackens and no pulse is produced until the
slack is taken up and the tape comes into the normal
status.
Sep 16, 2007 | JVC GR-DVL9000 DV Digital Camcorder
Cameras Logo
12 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
