Question about Nikon Super Coolscan 4000 ED Film Scanner (35 mm)
Scanning When I attempt a scan after doing a preview scan the 4000 seems to start scanning [ "acquiring scan","performing scan"] but them interrupts itself and says "no scanning items". Any ideas? Help would be much appreciated.
  • megan674 Feb 15, 2008
    I found Nikon Service Dept to be extremely helpful. They suggested I try scanning a negative with the other adaptor - that worked - They gave me a site to download the software again plus an update, to no avail unfortunately. My problem was just with the slide scanning, suddenly started telling me no scanning items!
    I eventually sent it to Nikon (£20 incl insurance) Their estimate is £26.51 (unless they find something else wrong!) They are going to Check, test & clean equipment, perform test scan, check & test to Nikon standard,Service/adjust scan and film stage mechanism, and dismantle, clean & service optical system. I am especially impressed with their service (& telephone help) as my scanner was second hand.
    Hope yours is sorted soon.
  • 4 Answers
Sometimes the software works strangely, with no indication why. Usually it has to do with the many settings which seem to change periodically or when you try to modify settings and something unintended happens. Try resetting the "settings" to factory defaults, see if it makes any difference. If this does not work, try removing the software and re-installing.
Posted on Feb 04, 2008
I saw the error "an error occurred during preview. if the scanner is being used. please wait for it to complete the task.and then click preview" when iam attempting to preview the scanned pictur how c
If you continue to get this kind of error after restarting the computer, you may need to update the scanner's device drivers or reinstall the included software. You should also make sure only one program or application is attempting to use the scanner by closing all but the one program you are trying use with the scanner. One last note - always either let the program you are scanning to operate the scanner or let the scanner invoke its default application by pressing the scan, fax or copy buttons on the scanner. Do not for instance try and scan an image into a running program that initiates the scanning process itself while also invoking a scan from the scanner's control panel. The two operations will conflict.
Nov 19, 2014 | Office Equipment & Supplies
Nikon Coolscan 5000 ED not scanning
Have you tried resetting the scanner itself?
Jul 09, 2008 | Nikon COOLSCAN 5000 ED Film Scanner
How to scan channels
The TV user guide should provide the procedures of acquiring auto scan. For example, your TV may be acquiring functionality from satellites dishs or cable receiver devices. Performing an auto scan achievable with the remote control device with adjustment to settings on the channel buttons would produce a signal only with available transmitter stations. Performing a channel auto scan would display no signals without available receiver devices often acquired with susbscription from a provder either cable TV, sattelite or disk network, show on demand for example. However, performing an auto scan on a new Tv should simply display a count list of possible available channels on which signals could be display when any is provided. Good luck
Jan 08, 2011 | Toshiba 32AV502U 31.5 in. LCD HDTV
HP PSC 1510 The "start scanning" button on the all-in-one does not actually start the scanning. The power light flashes but then goes solid. An uninstall and reinstall of the software fixed the problem,...
Scan the scan using the scanning software, the printer buttons are useless.
For example in paint shop pro go to file, acquire, TWAIN, get page. The HP Scan software will start and make a preview of the page. Then press scan to get the page on the editing program.
Oct 28, 2009 | HP PSC 1510 All-In-One InkJet Printer
How do i scan multiple pages
Please perform the steps given below to scan multiple pages to a single PDF file.
NOTE: Before performing the steps please make sure that Adobe Reader is installed on your computer. If not installed then goto and install Adobe Reader.
  1. Open HP Solution Center.
  2. Click on Settings.
  3. Click on Scan Settings.
  4. Click on Scan Preferences and Select the option 'Prompt for additional scans when preview is turned off'.
  5. Click on OK to apply changes.
  6. Now Click on Home and click on scan Document
  7. Select Document to File under scan shortcuts.
  8. Uncheck the option Preview Scan at right bottom of the scan window.
  9. Now Click on scan to scan document.
  10. When prompted for additional scan place the another document on scanner glass or ADF and Click on Scan.
  11. After scanning is complete Click on Finish to save the scanned document
  12. To Locate the scanned document (PDF) goto My Documents folder and Open My scans folder.
Oct 12, 2009 | HP Officejet 6500 Wireless All-in-One...
After scanning one photo slide and storing it on my computer, I can't delete this first scan to scan another
It's not necessary to delete the previous scanned photo. To scan another slide, place it in the scanner and press the PREVIEW button.
Mar 02, 2009 | Nikon Super Coolscan 4000 ED Film Scanner...
Dont know hw tp get started with lexmark printer
First, I'm assuming you are using some flavor of windows, but if not this may not be completely accurate. I'm also going to use windows XP in any directions I give, but if you are using Vista, it will be pretty close.
There are a few ways to do scanning. If you have a favorite graphics application like photoshop or paint shop pro, you can scan directly into these apps using the "Acquire" option. This is usually done by going to File->Acquire in the application, and then selecting your scanner.
The printer also probably came with a software suite for scanning as well. If you go to Start->All Programs->Lexmark 5400 Series, you should see something along the lines of All in One Center (may be slightly differently named, but it's in this folder). Once you find this application, it should be pretty easy to scan.
As a third option, if you don't have a graphics application, I like to use, which is a free piece of software you can find at
Once you download, install it, and get it started, to scan a picture go to :
File->Acquire, and select "From Scanner or Camera"
It should present you with a selection dialog where you should see your lexmark AIO. Select it and it will bring up the scan dialog, where you can select Color Picture, Black and White, etc.
It is a good idea to hit the preview button first and let it find your picture. Then hit the Scan button and it will scan!
Hope this is helpful
Jan 28, 2009 | Lexmark X5470 All-In-One InkJet Printer
Negative Scanning Problem Using Epson Scan Software
Make sure the rectangular slots at either end of the film frame are not obstructed or covered in any way. When I attempted to scan color negatives I had the same darkness problem in the scanned image. When I cleared those rectangular slots, everything was fine. I hope this helps.
Sep 28, 2008 | Epson Perfection 1670 Flatbed Scanner
Lock Switch and IF cable
Mine was doing the same thing. When I get on the program, before I click "acquire" to preview and scan, I click OFF the toolbox and then everything seems to be okay and I can go ahead and scan.
Nov 27, 2007 | Canon CanoScan LiDE 25 Flatbed Scanner
Nikon Super Coolscan 4000 ED Film Scanner (35 mm) Logo
185 people viewed this question
Top Nikon Office Equipment & Supplies Experts
Jerry Greenberg
Jerry Greenberg
Tanvi Thakur
Are you a Nikon Office Equipment and Supply Expert? Answer questions, earn points and help others
