Question about PC Chips (M925G) Motherboard
I have PC Chips M925 v 1.1A, Chipset Via P4m 266. It had only SDRAM 384 MB and I changed by a Kingston PC 2300 1GB and opened the jumper for the DIMM voltage and it works, and faster. But I also have more crashes on all programs, specially with Age of empires, Firefox, I mesh but recently also with IE8 and MS Word. I got also some major crashes with these message error: STOP 0X000000EA(0X86B3964, 0X869AD308, 0X00000001) s3gnb Beggining dump of physical memory Physical memory dump cpmplete
  • 235 Answers
Changing ram is good to make your computer more faster but sometomes it do cause harm, before you change your system was working fine, but you have already upgrade to a higher ram but now you recieve more crashes unlike before, may its time to re install your windows or have it reformated sudden changes in a computer hardware cause these problems this is incompatibility issues between the hardware and software that causes these problems to appear
michael
Posted on Nov 19, 2009
Hi. I'm trying to get ahold of a manual for the pcchips m810dlu motherboard. I need to know what capacity of rams can be stored on the board; 2700, 3200, etc. Thank you
• 2 SDRAM DIMM Sockets
- Two 184-pin 2.5V DDR SDRAM (DDR200/266) or
- Two 168-pin DIMM Socket for SDRAM memory module
• Maximum: 1GB
Aug 07, 2010 | PC Chips M810DLU (M810DLUV75C) Motherboard
Upgrade PCChips M925
According to PCChips, the maximum CPU & memory supported for all three is the Intel P4 Northwood (HT) 3.06 GHz 512K,533FSB,Socket 478 and 2GB (2 x 1GB) DDR 266.
Be sure you have the latest BIOS version for your motherbaord.
M925ALU (V7.3) must have BIOS : 030703s
M925G (V8.0) and M925G (V9.1b) must have BIOS : 050510s
Hope this helps you out.
Jan 09, 2010 | PC Chips (M925G) Motherboard
Need Manual for Slot1 PIII Gateway Jabil Tabor III Motherboard.
The memory specifications for that motherboard are as follows:
  • 100-megahertz (MHz) Memory Bus Speed (FSB)
  • Three 64-bit or 72-bit Error Checking and Correction (ECC) 4-clock, 3.3V, unbuffered synchronous DRAM (SDRAM) Single or double-sided DIMMs in the following sizes: 8 MB, 16 MB, 32 MB, 64 MB, 128 MB
  • Expandable to 384 megabytes (MB) of SDRAM, CAS latency of 2, using 64-Mbit chips
  • DIMMs must adhere to the Intel 4-clock 100-MHz 64-bit unbuffered SDRAM DIMM specification, latest revision
  • Uses gold-plated DIMM socket
  • ECC signal and multiple bit detection, single bit correction, supported, using ECC DIMMs, can be enabled and disable in the BIOS Setup Utility
  • Jun 21, 2009 | Gateway Computers & Internet
    Wndows vista
    All the drivers for that motherboard can be download from the official site at http://www.asrock.com/mb/download.asp?Model=Wolfdale1333-GLAN/M&s=775
    Good luck
    Jun 20, 2009 | Computers & Internet
    P4VXASD-R VIA Apollo P4X266-new 1G DDR gets 3 beeps
    Well you said you used 256+128 and thats lower than 1gb. So try sticking in one of the stick and run it, see how it is. Then try the other, if both are working fine by themself then try cleaning your board with a nonscrathing cloth (or q-tip).
    Lastly, just double check if your motherboard runs that kingston type, the pc2100.
    As for your memory goes, os 2k can run up to 4gb of ram.
    Jun 11, 2009 | EliteGroup ECS P4VXASD2 VIA P4X266A...
    RAM cuantity
    The motherboard you mentioned supports DDR1 RAM.
    For windows xp and general application 512 MB is enough.
    But if you use memory intensive applications like image/video editing then you can opt for 1-2 GB RAM.
    Nov 24, 2008 | Intel D845EPI (INTELKD845EPILPAK10)...
    I NEED RAM
    Hi zouganeli,
    You can install one, two or three modules. Each memory module can hold a maximum capacity of 128 MB of standard SDRAM chips, or 256 MB of registered SDRAM chips so maximum memory capacity is 384 MB of standard SDRAM memory or 768 MB registered SDRAM memory.
    Hope that helps
    Take care,
    Michael
    Nov 14, 2008 | Computers & Internet
    P4vmm2 motherboard
    you can add up to 2 gb RAM using either 2 x 184 Pin DIMMs or 2 x 168 Pin SDRAM DIMMs. However that MB does support pc400. The supported RAM speeds are 100, 133, 200, and 266 MHz
    You can buy a pair of Kingston 256 MB DDR SDRAM PC2100 (266 MHz) from the kingston website for under $50
    part no: KVR266X64C25/256
    Kingston is a well known and respected manufacturer of memory.
    Dec 15, 2007 | EliteGroup P4VMM2 Motherboard
    PC Chips (M925G) Motherboard Logo
    244 people viewed this question
    Top PC Chips Computers & Internet Experts
    David
    David
    Alun Cox
    Jerry Umali
    Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
