Question about Hisense LCD1504 15 in. Television
Lost manual. can`t get many channels. - Hisense LCD1504 15 in. Television
  • 11,361 Answers
How do I restore channels lost on dynex flat tv?
Do an auto-tune function. Refer its user manual for details.
Oct 01, 2015 | Dynex Televison & Video
Lost ABC channels on retune, how do I regain reception
Try manually entering the channel number. Many TV's have, besides autoscan, a way to manually add or remove channels.
(Besides, what is worth watching on ABC? (;^D)
Oct 21, 2014 | Televison & Video
Some of my channels were lost after I TRIED RESCANNING I I LOST
Check your antenna direction (antennaweb.org or tvfool.com are good sources for signal direction). When I lose channels, it's a digital signal that came in with "bad signal" strength and my external antenna has rotated in the wind. (Oddly another TV in the house doesn't seem to lose the signal as easily even though they share an antenna.)
Also check the weather conditions and time of day. I've gained distant channels when scanning near sunrise or sunset and lost others during thunderstorms.
I hope this helps.
Jun 07, 2010 | Vizio L32 32 in. LCD HDTV
Lost manual and cannot program scanner bc145xl
Try these instructions from Wiki.answers
Turn on unit.
Press MANUAL button.
Press MANUAL button again to select the channel you want to program. Note the channel in the display. If there is a hyphenated symbol in the upper left corner the channel has been locked out. Press the LOCKOUT button once to remove the symbol or press the LOCKOUT button to lock a channel out. To find out if there is a frequency programed into that channel, press the PREVIEW button. Each digit of the frequency that is stored in memory will be displayed in the LED display. To program a new frequency into that channel, simply press the digits of the frequency you want, including the decimal point. Press the "E" keypad key to enter it into memory. If you get a "E" displayed in the LED display, the frequency was entered wrong, is not a valid frequency or is out of range for the scanner. Last but least, the scanner is not working properly. If the channel is active, (communications going over it) set SQUELCH to higher number, until you hear the communications or just noise. To set the SQUELCH, select a channel that has only noise and turn it down to the point the noise disappears. You make have to readjust it to your liking. Once you have the channels programed you can select the SCAN button to listen to all the channels or select the MANUAL button to listen to just one channel. If there are channels that you don't want to hear during the scan mode, go to MANUAL and select the channel you don't want to hear and press LOCKOUT button. Then press SCAN again it will only scan channels you want to hear.
Hope this helps.
Sep 07, 2009 | Radio Communications
I've lost channel's on my digi box ireland
If you have the manual then read up the procedure for doing a channel update, this will scan all of the channels available and put them into the box.
If there is a reset button do not push it unless you have the manual as there will be a startup code you must enter
Normally the digibox will offer to do an update on a regular basis
If you do not have a manual, post the details of the box (Make & Model etc ) onto this site and you will get directed to the makers site
Jun 12, 2009 | StarTech.com StarView SV211K 2-port KVM...
Direct TV ''Program not available'' but should be
Define "Lost." if you manually tune to the channel, whats there. By manually tune I mean punch in the channel number on the remote itself instead of using the guide or channel up/down buttons.
If the channel is there but not on the guide, you have set a custom guide and would need to go into your guide setup to change it back to "All Channels."
If you do not have apicture on the missing channel, reply back with the channel number and the error message at the bottom of the screen.
Mar 22, 2009 | Directv D12-300/100 DTV Receiver
Lost channels on proscan tv
Press the menu button on your remote.  That should give you the main menu where you can go into add/delete channels and do an autoscan to only save channels that are good.
Mar 04, 2009 | Proscan 26LA30Q 26 in. LCD Television
Uniden Bearcat Scanner Model# BC147XLT
The BC147XLT is too old to obtain a manual from Uniden, but here's how you program it:
Turn it on & press 'Manual', then enter the number of the channel you wish to program & press 'Manual' again. Now enter the frequency you want to put in that channel, example 155.550, and press "Enter'. Then press manual to go to the next channel or repeat the first procedure to select a different channel other than the next one. Repeat the programming procedure for each channel.
Sep 26, 2008 | Uniden BC244CLT Base Scanner
Missing manual for - sharp VC-A560 VHS
I lost my manual and the biggest issue of getting this set up is getting the vcr to the channel you need for play back either channel 3 or channel 4. To change the channel you hold the power button and the tv/vrc button at the same time till you get the channel you want. Three flashing lights is channel three, four flashing lights is channel 4. every time the power goes out mine resets to channel 3 and will not play videos until I reset to channel 4. Hope that helps.
May 24, 2007 | Sharp VC-A560U VHS VCR
Hisense LCD1504 15 in. Television Logo
126 people viewed this question
Top Hisense Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
