Question about HP Pavilion dv6000z Notebook
Screen stays dark
Power up computer & screens stays black.
  • 558 Answers
Do you have a blinking curser.If you do then your os is corrupted.Try removing the battery and the memory.Press and hold the power button down for twenty seconds.Replace the both and try to start it again.
Good luck
Posted on Nov 19, 2009
  • 458 Answers
Faulty Nvidia CHip...
You first need to see if you are listed on the HP Extended Service Warranty Service List...
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&lc=en&cc=us
If Not....
You will Need To Reflow The Graphics Chip... It is the process of Reflowing The Solder From the Connection Balls on the Underside of the Graphics Chip Back Down To The Motherboards Contact Pads...
The Graphics chip needs to be weighted down, You can use 8 Quarters.. You must insulate all parts on the board, Cover the CPU, Cover The RAM Slots, Cover Any Plastic Ports/Connectors...
Use A Heat Gun Set On Low.....
Hold 6 Inches From The Quarter Stack and Rotate around the Quarters Slowly Moving Closer And Pulling Back... THis Process Will Take Roughly 3 minutes... You Want to Heat It Hot Enough To Melt The Solder On The Underside Of The Graphics Chip, But DO NOT OVERHEAT... If Overheated, You Will Lose The Connection Forever and Render The Motherboard Useless.....
Other Option Is To Replace Your Motherboard.... Due To THe Fact That Your Video/GPU is integrated...
My screen is all black with the words no database what does this mean ?
When the following symptoms, the need for LCD inverter with a: No image on the screen, but the power light stays on
Dark display but still readable
Between the screen flashes on and off 1/2 to several seconds
Power light stays on, but no display and sound
No image on the screen, but LCD TV still has sound
Picture cycle on and off, as well as high-power LED lights
Aug 04, 2013 | Sceptre Computers & Internet
Acer 1912 stays dark
By that description sounds it sounds like you need a new monitor. Otherwise I would say if it was just a black screen to reset your CMOS by removing the side panel of your computer, locate the round battery and near the battery is a 3 pin 1 jumper setup most likely jumper on 1,2 but can be 2,3. Which ever the case, unplug the power cord, remove the jump from 1,2 and move it to 2,3 or vice versa remove from 2,3 and move to 2,1 for 1 minute then remove and replace in default position. Plug the power back and and start it up. As I said, wouldn't go through the trouble because your monitor sounds broken.
Aug 02, 2010 | Acer AL1912 19" LCD Monitor
My screen is darker then it was when i fist got it .
Apparently you can see something, as you were able to install a screen saver. In this case, go into the control panel and check the "power options" to see if by chance the screen is set to go to black in 5 minutes. If so, change the value.
If this is not the problem and you can't brighten the screen with the screen controls, try an external monitor to see if the video is OK.
If it is, then you are looking at the power supply or the flourescent bulb in the monitor being bad.
Sep 25, 2009 | Acer Aspire 5610-4648 Notebook
Replaced screen computer comes on, but screen stays black.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 22, 2009 | Dell Latitude D600 Notebook
Screen stays dark
How long have you had your computer? Mine has been doing this. The battery has died out over time, and now I think the adapter is too. It's kind of kinked near where it plugs into the computer (probably from the weight of the chord constantly being pulled down). It just gets a bad connection, a little less power, and goes dim like that. If I readjust the connection and turn off/turn back on the computer, it usually comes on bright again. But I ordered a new battery
Dec 17, 2008 | Dell Inspiron 1200 Notebook
Black screen
Hey... friend,
It's seems your backlight inverter is burnt out...need to replaced a new inverter. Visit this site @ www.3rd-rocks.com There's a replacement parts for your FP988D LCD. Have a nice day!
Aug 05, 2008 | Fuji FP-988D 19" Flat Panel LCD Monitor
HP Pavilion dv6000z Notebook Logo
123 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
