Question about InFocus LP 820 Multimedia Projector
I have an Infocus 820 and it starts up just fine and it shuts down after it has been on for 2 or more minutes, do you know why its doing this? And it has a green light, not red.
  • 2,237 Answers
Lamp or ballast is bad. if the lamp has bulges or black spots in the center, chances are it's the ballast/power supply.
Posted on Dec 02, 2009
Shutting down after about a minute of powering on
Sounds like a overheating issue. Clean your vents and filter (if it has a filter).
Mar 12, 2014 | InFocus IN1503 DLP Projector
Total shutdown after after a few minutes
This is a power supply failure.
infocus.dex.com
5E.13440.003 PCBA, POWER BD$78.90
Oct 31, 2013 | InFocus IN102 DLP Projector
IN104 automatic shutdown
Hello, my infocus in104 will power up for a while (1- 5 minutes) when connected to the power supply and turned on, after that it automatically shuts down. Power button does not light red when it automatically shuts down and need to be unplugged for a minute or more before red power button will light up again.
Mar 21, 2013 | InFocus IN104 Projector
The projector will power up and run for a minute and then powers back off. It will occasionally restart on it's own.
Maybe start with a good clean out first.
I tend to use those cans of air meant for computers but dont poke the nozzle in too far !
If it still has issues then its time to start opening her up to check the fan and such.
Aug 31, 2010 | InFocus LP 820 Multimedia Projector
Infocus lp820 i press power can not hear any fan moving lamp turn on with gray light after 10 sec lamp shut off and message says "fan stopped"
you need to replace the fans; they may have burned out. you could try to get one from an infocus service center or send it to them for repair, but know that this is an old machine and parts may not be available. you could try getting a used one on ebay that has a different problem and swap out the parts. if you do decide to send it in or find new parts, try av solutions in ny. they're really good. www.avsolutionsny.com
Nov 12, 2009 | InFocus LP 820 Multimedia Projector
LP120 : fan stopped error
you can purchase and replace the blower assembly- part # 505-1917-00. it's tricky, but you can do it. find an infocus authorized service center form their web site to buy it.
Jan 19, 2009 | InFocus LP120 / 1000 Lumens / XGA / DLP...
Infocus LP820 - Turns on for 30sec then shuts down
This could be one of two problems I have seen with another model Infocus projector (they are very good projectors though)
The first is the video input. Make sure it is attached correctly at both ends of the cable.
The second, remove the dust covers and blow them out. The problem can arrise if the temperature sensor detects the air inside the unit is getting too hot. If you can see the sensor when the dust covers are off (it will look like a little lump of goo on the end of a wire) then just give it a wipe as well. If dust settles on those it can cause incorrect temps to be reported.
Hope that solves your poblem =)
Apr 11, 2008 | InFocus LP 820 Multimedia Projector
InFocus LP725 light goes out after 10 minutes
The Projector will turn off after so many hours of running the same bulb module. The counter will turn on a replace bulb LED. Installing the new bulb module should reset the counter and turn off the LED.
Check the projector’s lamp to ensure that it is securely connected
in the lamp module. Make sure by removing it and reinserting it.
Check the cables for problems.
When testing, power up in this order. Projector, Computer monitor, Computer.
A minor power surge may cause the lamp to shut off. Turn the
projector off, wait at least 30 seconds, then turn it back on.
I hope these suggestions help
Feb 02, 2008 | InFocus LP725 and LP735 Replacement...
InFocus LP 820 Multimedia Projector Logo
196 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
