My md650scps just poped i replaced the 125v 10 amp fuse on the board but still shorts out is there a common problem?
    Scholar:
  • 174 Answers
Check out your processor or *********** board is short
Posted on Nov 19, 2009
Thank you but i do have the manual .i need the schematics for the xr 8600, or the site to download from
Internal fuse. Or fuse near the speaker connections.
Remove power. Remove back cover look for
125v clear or ceramic fuse.
125V 5x20mm Fast-Acting Glass Fuse
Dec 07, 2014 | Peavey Xr 8600 Xr8600 Powered Mixer...
How can i get a replacement 5 amp 125 volt fuse for a holmes twin widow fan
It's worth noting here that it's more about the physical size & shape of the Fuse thats needed to fit your Fan.
You don't have to use exactly a 5 amp @ 125v fuse.
Any fuse that Fits and is in the range of 5,6,7,8,10 Amp and even 230v is ok.
The fuse is like a piece of soft metal that will melt if too much current is being drawn by the device. The Amps & Volts only define approximately when the fuse link will melt (blow). But as the fan gets dirty and older the LOAD it draws might get slightly higher. Enough to cause the fuse to slowly melt. So a small to 6, 8, or 10 Amp should work just fine. A wiring short will still cause the 10 Amp fuse to blow thereby keeping things safe. The manufacturer uses a fuse that fits in the space he has allocated & allows the unit to run continuously without blowing on a slight load.
But it is only a safety device to protect the device from internal shorts.
It stops a shorted motor or shorted internal wiring from getting too hot and possibly causing a fire.
But a 20 or 30Amp fuse would still blow if it is shorted.
For example...If the 5 A fuse keeps blowing then you could try say an 8 or 10 Amp fuse. If that blows then their is definitely a problem with the circuit. Don't put anything larger than 10 Amp in.
It then needs to be looked at by a service technician.
The voltage rating on a household fuse isn't that critical.
It's actually the wattage it takes to melt the fuse link. It's based on the mathematics of Ohms Law (Watts =Volts x Amps)
But thats another story....
Cheers
Trevor
Jul 16, 2014 | Holmes Products Dryers
Mr. Peter I changed fuse 6.3 amp 125v from f board 6amp 125v from radio shake. is that make any difference.
you need to put fuse 6.3 amp to 6amp with same 125v if fuse not match or it will give problem
May 30, 2014 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Sony str dh520
If it's blowing the fuse, then there are probably shorted output transistors in the amp that need to be replaced.
Jul 10, 2013 | Audio Players & Recorders
I have a projectionTV Sony mod. KP48V75. During a storm the safety power fuse blew. It was 125V 6.5A. I replaced it with 125V 6A and so far everytime I plug the TV on it blows the fuse. I have been through...
Most likely the storm did damage to the power supply board (the G board in a Sony) which is part number A-1316-388-A for your TV. However the board is no longer available..It most likely has a bad regulator and possibly rectifiers on that board that are shorted. Complete board replacement would be the best solution.
Nov 03, 2009 | Sony KP48V85GRAY 48" Rear Projection...
3500 dully back up lights do not work numerous 10 amp fuses do not work some 15 also.seems to be no juice to the fuse ports
Are you poping fuses you got a short????
if fuse good check range switch on trans by linkage--NOTE SAFETY block wheels level ground ENG OFF- also check power & ground at bulbs
Aug 30, 2009 | 2000 Chevrolet 3500
Ba71f0f01042 power board blows fuse
I'm not too familar with this model, but to give you some pointers, you will find when you have this problem the fuse will go straight away as there will be some of the semi-conductors short circuited. Check your bridge rectifier diodes & also the chopper transistor in the power supply. As a general check, test most of the diodes & power transistors & replace any that read short circuit on your meter. Hope this may help you as a guide line.
Aug 01, 2009 | Emerson EWL3706 37 in. LCD Television
Portable DVD blowing fuses
Thankyou,
Hello, the fuse poping is definitely as you say, please let me give you some more insights of my idea. The fuse is poping because there is a by ~ pass, most likely before its power board, that by ~ pass also causes a shorting most likely in the cigarettes lighter wiring. That is why even if you turn it off, it still shorts, Try to see exactly what went out of place to give a better understanding of the error in the circuitry, once that has been archieved, you may kindly contact manufacturer/dealer for layout of the wiring and rectify the shorting. The shorting is delivering way too much power because of the by ~ pass that over rate the fuse rating. Or try a much higher fuse rating.
Thankyou, :)
Jun 24, 2009 | TruTech LMD-5702RT Portable DVD Player
No power up
C702 102k 2KV shorted, E994 2 amp fuse open. Replace w/102k 3KV Sony #1-161-754-00. Replace fuse w/AZ00104M or common 2 amp pico fuse. NOTE: bad cap may be covered with "glue".
Sep 23, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
