Question about Compaq Presario 5000 PC Desktop
OK... I have a problem with the something called the debugger... each time i try to download or open the web browser[s] it says debugger97? I also have another question what is the best website to get music on your ipod and stuff.. with no virus or highjaks. Also each time I boot up the comp.... it opens up programs randomly????? PLEASE HELP!
  • 558 Answers
Go to Internet Explorer select tools,select internet options go to the last tab reset internet explorer,Go to the General tab aswell select delete once completed click on apply then ok restart Internet Explorer.Well you may have spyware.Go to www.cnet.com in the search field type malwarebytes.Downlaad the free version install it and scan your computer.As far as music is concerned the best bet is to use a paying site where you can have unlimited download and its virus free.
Good Luck
Posted on Nov 19, 2009
Every time I try to open a web page on chrome I get this webpage is unavailable
Hi Judy
Use or download one of the many browser applications and see if that works OK.
Safari, FireFox, Internet Explorer etc.
Sep 13, 2015 | Google Chrome
Cannot view my own website. it reads: "Parse error: syntax error, unexpected $end..." in my index.php file. HELP
Syntax errors are the most common problem for developers. A single syntax error can cripple even the best applications and websites. You can correct syntax errors easily once you find them. Typical errors include missing commas, semicolons and parenthesis. Debuggers are available in many software development kits to aid you in the location of syntax errors. However, you can find and correct syntax errors manually as well. Learning how to correct syntax errors is an essential part of being a software developer.
Locate the syntax error manually. Step through each section of your code. Most code will be sectioned off into groups or functions. Carefully proof your code. Be sure to pay close attention to how lines are grouped. A common syntax mistake is incorrect grouping.
For instance, if you have an If Else statement embedded in another If Else statement, be sure the embedded statement is surrounded by a separate set of parenthesis or brackets, depending on your language. Double-check notes sections. Notes are only for the developer to see. However, if the syntax isn't correct, the notes may become part of your application, which may not agree with existing code. Ensure the syntax around your notes is correct. Run a debugger if possible. This will make locating errors much easier. A debugger will be found under a menu such as Debug, Run or Tools or as part of your SDK's toolbar. Allow the debugger to run. Errors will be listed at the bottom or right side of your screen. Many debuggers will highlight possible errors in your code as well. A line number, along with the possible error, will be listed in the error message. Locate your syntax error if the debugger isn't correct. Sometimes a debugger will show you where your application stopped working correctly. The syntax error itself may be above or below the line listed in the debugger message. Check all syntax within the surrounding area, especially within the line's function. Run your application after correcting the syntax error. Check every possible function of your application to ensure it works correctly. If you find a problem, double-check the syntax in your code that surrounds the problem area. For instance, if your application has a log-in screen that isn't accepting passwords correctly, check the code for the log-in screen. Remove Syntax Error syntax error typically occurs when the Web page you are loading causes a script error in the browser. This is caused by incorrect code that displays an error message or results in a Web page that does not load correctly. You can remove a syntax error by making a change to the settings of your Web browser. Common Web browsers that can experience this type of error include Internet Explorer, Mozilla Firefox and Safari.
Double-click the "Internet Explorer" icon to open the program. Click the "Tools" drop-down menu and select "Internet Options." This will display the Internet Options window. Go to the "Advanced" tab and scroll down to the "Browsing" section. Remove the check from the box for "Disable script debugging (Internet Explorer)," "Disable script debugging (Other)" and "Display a notification about every script error." Click the "Apply" button to save the changes. Click the "OK" button to close the Internet Options window. Close and restart the Internet Explorer browser for the changes you made to take effect. b> Mozilla Firefox b> Double-click the "Mozilla Firefox" icon to open the program. Type "about:config" into the address bar and press the "Enter" key. Type "dom.max_script_run_time" into the Filter text box and press the "Enter" key. Double-click "dom.max_script_run_time" to display the Enter Integer Value dialog box. Enter a value of "10" or "15" into the text box and click the "OK" button to save the change. Close and then restart the Firefox browser for the change to take effect. b> Safari b> Click the "Safari" icon to open the Web browser. Select the option for "Preferences" from the menu bar. Go to the Advanced tab and click the option for "Show Develop menu in menu bar." Click the option for "Develop" from the menu bar. Click the option for "Disable Runaway JavaScript Timer." Close and re-open the browser for the change to take effect.
b>
b>
Apr 06, 2013 | Computers & Internet
I keep getting a box on my screen every time i try to do anything. it says EvalInsandbox:SyntaxError:syntaxerror
Correct a Syntax Error Syntax errors are the most common problem for developers. A single syntax error can cripple even the best applications and websites. You can correct syntax errors easily once you find them. Typical errors include missing commas, semicolons and parenthesis. Debuggers are available in many software development kits to aid you in the location of syntax errors. However, you can find and correct syntax errors manually as well. Learning how to correct syntax errors is an essential part of being a software developer.
Double-click the "Internet Explorer" icon to open the program. Click the "Tools" drop-down menu and select "Internet Options." This will display the Internet Options window. Go to the "Advanced" tab and scroll down to the "Browsing" section. Remove the check from the box for "Disable script debugging (Internet Explorer)," "Disable script debugging (Other)" and "Display a notification about every script error." Click the "Apply" button to save the changes. Click the "OK" button to close the Internet Options window. Close and restart the Internet Explorer browser for the changes you made to take effect. b> Mozilla Firefox b> Double-click the "Mozilla Firefox" icon to open the program. Type "about:config" into the address bar and press the "Enter" key. Type "dom.max_script_run_time" into the Filter text box and press the "Enter" key. Double-click "dom.max_script_run_time" to display the Enter Integer Value dialog box. Enter a value of "10" or "15" into the text box and click the "OK" button to save the change. Close and then restart the Firefox browser for the change to take effect. b> Safari b> Click the "Safari" icon to open the Web browser. Select the option for "Preferences" from the menu bar. Go to the Advanced tab and click the option for "Show Develop menu in menu bar." Click the option for "Develop" from the menu bar. Click the option for "Disable Runaway JavaScript Timer." Close and re-open the browser for the change to take effect. Hope this helps.
b>
b>
Dec 06, 2012 | Mozilla Firefox
I have internet connection and also shown G but web browser not open website shown web browser time out? why tell me what problem
1) Try a system restore.
Go to start > all programs > accessories > system tools > system restore
Follow prompts to reset computer to a time when it was working correctly in the past.
All downloaded programs will be lost, but documents and photos should not be affected.
Suggest you back up anyway.
2) Try a work-around on your computer.
Go to Start > all programs > accessories > wordpad.
Open wordpad > click Help > select Help topics > box opens
In upper left corner of box is yellow question mark > click question mark > select 'jump to URL'
URL box opens
Fill in URL with the web address shown below
http://www.mozilla.com/en-US/firefox/
Download Firefox browser and see if it will work correctly
Or download Chrome browser, etc
Mar 02, 2011 | Garden
Running script error
Method 1: Disable script debugging loadTOCNode(3, 'whattotry'); If the only sign of a problem is the error message, and Web sites are working, you can probably ignore the error. Also, if the problem only happens on one or two Web pages, it might be a problem with those pages. If you decide to ignore the errors, you can disable script debugging.
Note If this problem occurs on more than one or two sites, do not disable script debugging. Go to method 2 now.
To turn off the Scripting Debugger in Internet Explorer 6, follow these steps:
  1. On the Tools menu, click Internet Options.
  2. On the Advanced tab, click to select the Disable script debugging check box. and then click OK .
To turn off notification about every script error in Internet Explorer 7, follow these steps:
  2. On the Advanced tab, click to clear the Display a notification about every script error check box, and then click OK.
Method 2: Test a Web page from another user account, another browser, and another computer loadTOCNode(3, 'whattotry'); Use another user account, another browser, or another computer to view the Web pages that triggered a script error to determine whether the problem persists. If the script error persists, there may be a problem with the way the Web page is written. You can probably ignore the error and disable script debugging as described in method 1.
If the script error does not occur when you view the Web page from another user account, browser, or computer, the problem may be caused by files or by settings on your computer. Go to method 3 to continue to troubleshoot. Method 3: Verify that Active Scripting, ActiveX, and Java are not being blocked by Internet Explorer loadTOCNode(3, 'whattotry'); Active scripting, ActiveX, and Java are all involved in shaping the way information displays on a Web page. If these are blocked on your computer, it may disrupt the display of the Web page. Reset the Internet Explorer security settings to make sure these are not blocked. To do this, follow these steps:
  1. Start Internet Explorer.
  2. On the Tools menu, click Internet Options.
  3. In the Internet Options dialog box, click the Security tab.
  4. Click Default Level.
  5. Click OK.
Note ActiveX controls and Java programs are turned off at the High security level in Internet Explorer.
Try to open a Web page where you previously received a scripting error. If you do not receive the error, the issue is resolved. If the issue persists, go to Method 4. Method 4: Remove all the temporary Internet-related files loadTOCNode(3, 'whattotry'); Every time that you open a browser to view a Web page, your computer stores a local copy of that Web page in a temporary file. If the size of the temporary Internet files folder becomes too large, some display problems may occur when you open Web pages. Periodically clearing the folder might help resolve the issue.
To remove all the temporary Internet-related files from your computer when you use Internet Explorer 6, follow these steps:
  3. Click the General tab.
  4. Under Temporary Internet files, click Settings.
  5. Click Delete Files, and then click OK.
  6. Click Delete Cookies, and then click OK.
  7. Under History, click Clear History, and then click Yes.
  8. Click OK.
To remove all the temporary Internet-related files from your computer when you use Internet Explorer 7, follow these steps:
  4. Under Browsing History, click Delete, and when you are prompted, click Yes to confirm.
  5. In the Delete Browsing History dialog box, under Temporary Internet Files, click Delete Files, and when you are prompted, click Yes to confirm.
  6. Under Cookies, click Delete Cookies, and when you are prompted, click Yes to confirm.
  7. Under History, click Delete History, and when you are prompted, click Yes to confirm.
  8. Click Close, and then click OK to close the Internet Options dialog box.
Try to open a Web page where you previously received a scripting error. If you do not receive the error, the issue is resolved. If the issue persists, go to method 5. Method 5: Install the latest service pack and software updates for Internet Explorer 6 or Internet Explorer 7 loadTOCNode(3, 'whattotry'); If you do not have the latest service pack or software upgrades for Internet Explorer 6 or 7, download and install them. They may contain updates that can help resolve the issue.
Jul 06, 2010 | Computers & Internet
Windows int. explorer keeps closing saying java script error
This article offers five methods that you can try to resolve the issue, and also presents some advanced troubleshooting tips that you can try. Try each method in the order presented until you resolve the issue. If one method does not work, try the next.
This article is intended for a beginning to intermediate computer user. You may find it easier to follow the steps if you print this article first.
  5. Click OK.
  8. Click OK.
To install Internet Explorer 6 Service Pack 1, visit the following Microsoft Web site:
http://www.microsoft.com/downloads/details.aspx?FamilyID=1e1550cb-5e5d-48f5-b02b-20b602228de6&displaylang=en (http://www.microsoft.com/downloads/details.aspx?FamilyID=1e1550cb-5e5d-48f5-b02b-20b602228de6&displaylang=en) Note Internet Explorer 6 Service Pack 1 is recommended for systems that are running versions of Windows earlier than Windows XP.
To install the most current software updates for Internet Explorer 6 or for Internet Explorer 7, visit the following Microsoft Web site:
http://windowsupdate.microsoft.com (http://windowsupdate.microsoft.com) Please leave me comment, if you need further assistance Thanks for using Fixya Please rate this solution Rnj VinodKumar
Dec 15, 2009 | Sun Java Desktop System
About blank
about:blank is a cheater way of opening a blank homepage when you open up a web browser. Apparently your web browser is set to open up a blank page. There is absolutely nothing wrong with that. I even use that on occasion as I normally do not want to go to a specific website every time I open up a browser window. You can change this at any time by changing the Internet Options (for IE) or using Tools -> Options in other web browsers.
By the way, some web browsers support other about: pages as well including configuration options in Firefox using about:config.
May 29, 2009 | Microsoft Windows XP Home Edition
Keep getting ads for a viagra type product on every web page i go to and i want it to go away
What you can do is in your web browser there will be an option called pop-up blocker, just enable it and you won't get any ads when you open the web browser.
OR
If you are using IE go to Tool -> Internet Options ->select Security Tab -> In that open "Restricted Sites" section, When ever you get those viagra ads copy those url and paste in this section and click on OK next time you won't get those ads.
Try both the ways it works....!
Mar 12, 2009 | HP Pavilion dv9000z Notebook
Running Debugger on Safe Mode and Internet Access
I would go to my start,run and type in msconfig and click ok and look at your services and start up programs and ether turn off all the things I think could be wrong or just turn all of them off and then close out and reboot. you cant hurt any thing here it is a tech tool. I turn off things one at a time to see if it fixes the problem.
Jan 02, 2008 | Acer Aspire 5500 5570-2609 Laptop
Downloading Problems
Try downloading a file and save it somewere else then you desktop..P.S What O.S are you running?
joe
Dec 21, 2007 | Computers & Internet
Compaq Presario 5000 PC Desktop Logo
43 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
