Question about Whirlpool Calypso GVW9959K Top Load Washer
Our calypso won't go through the full cycle it will either say, LD or ob? We tried evening the load then we took the close out and it still does it
  • 15,935 Answers
The OB indicates and out of balance condition has been detected by the motor control. You say this happens when the washer is empty also. One thing about the OB error is that the lid must be opened to clear the error and allow the washer to advance to the next part of the cycle. If the lid is not opened to adjust the clothes then the OB error will happen again.
If the OB error was cleared and the OB occurs with an empty load then the motor control has failed.
The drain pump must work. The image below shows how to run a diagnostic test to check the drain pump. Follow the instructions in the image below and check the drain pump operation. If the pump runs and the water does not drain then the sump is clogged. If the pump hums but does not run then the pump needs to be replaced.
http://media.fotki.com/1_p,wkktswgwqtqrbwfxgtqsskgwtqkq,vi/gftrgbbtfxfffgqskfk/1/1303472/5961857/image48348img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 21, 2010
Kenmore calypso washer will not spin the clothes ld or ob signal continue to show even after i have evenly distributed the clothes
May 15, 2010 | Kenmore 24032\24036 Top Load Washer
Gives codes ld and ob when in the spin cycle and wont complete the cycle even when load is redistributed. had a repairman here and he replaced an electrical part that was spendy. Still doesn't work....
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^#$%
Nov 15, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Calypso washer is not completeing "normal" was cycle
could be or you may have a problem with the lid switch ( Ld )
Aug 23, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore Elite flashing codes.
ob means out of balance and ld means lid not closed. so i would guess that you have a washer that is not draining or just needs the clothes moved around.
if you have a plugged pump it will do the same thing. make sure the pump will drain properly and then try it again. if it still goes out then try it with no clothes. that way you know its not hte clothes causing the problem.
recheck the pump and hoses. be sure it will drain the full tub or it wont work right.
Jan 06, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
LD and OB on Calypso
“Ld” flashes if it takes longer than 5 minutes to pump out water to a point where the operating
pressure switch resets.
Press STOP/CANCEL to clear the display.
OB:
If the motor controller detects an unrecoverable off-balance condition, the machine controller
will shut down and display an “ob” for off balance.
The lid switch must be opened at least once before restarting the cycle, if this condition
occurs. Opening the lid will allow the customer to view and redistribute the load.
Basically, it sounds like your drain pump is bad or clogged, and the extra water is throwing the spin cycle off balance
-Perry
800-Appliance San Diego
Dec 16, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Ld and ob error codes
hello.........
“LD” stands for “long drain,” meaning it took an excessively long time for water to drain out of the washer. Common causes for this are kinked drain hose or clothing, like panties or socks, caught in the pump suction hose. Why, I’ve even heard of bra wires coming loose and getting stuck in that hose, collecting all sorts of gookus and pinching off the flow of water to the pump. Can you imagine? Yea verily, as surely as the Sacred Suds doth eternally pass my lips, the “LD” error code springs forth from such anomalies.
Sep 07, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
What does ld mean on my washer?
op is probably ob, off balance, the ld is long discharge, most likely the pump is bad or full of junk, the origional pumps were updated to a better design so as not to get stopped up.
Aug 02, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Ld and ob codes
LD code means your pump is cloged with lint or small piece of clothing such as a sock. I had the same code on my washer and sure enough i found my pump cloged with lint from a blanket my wife washed. hope this helps. sorry I cant help on the other code.
Jan 03, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
HELP? ob & ld codes
Ld means long drain you probally have a bad water pump.Those models have a seperate motor for pump, the shaft on the motor is a star type and has probally stripped out the pump.Replace your water pump
Whirlpool Calypso GVW9959K Top Load Washer Logo
Dan Webster
Dan Webster
Sal De
