Question about Bosch WFMC 3200 Front Load Washer
Need the process to remove pump from bosch wfmc 3200 washer?
    Guru:
  • 1,738 Answers
Do a Internet search and type in the model and diagram.
Posted on Nov 19, 2009
Need instructions for moving -- have four bolts!
Hi.
Here the full set of instructions for the model Bosch WFMC 3200 posted in title:
WFMC3200UC/01 Manual 1
WFMC3200UC/01 Manual 2
Here repair manual available for $9.95.
Regards.
Ginko
Jun 07, 2011 | Bosch WFMC 3200 Front Load Washer
How do I replace cold water solenoid on Bosch WFMC 3200 washer...take off top or access from back panel?
take off the top and u will see the solinoid in front of you. just be sure to turn off the power and water b4 replacing.
Jan 02, 2011 | Bosch WFMC 3200 Front Load Washer
WFMC 3200 Front Load Washer: how do i unlock door? bosch washer was just deliv...
Hi, welcome to fixya. The emergency latch release is behind the small round panel below the main tub door. **Unplug the washer or turn off the breaker before attempting any suggestion given here please** To open the access door ( small round panel ) you'll require a small round needle shaped object or really narrow screwdriver. Put it in the small hole in the panel push in slightly and turn to about 6 o'clock...clockwise that is The small round cover should now come off and expose the pump with the string going through a hook on the pump housing. Be very careful as the edges are very sharp. A string will be threaded through the pump housing and you just need to pull it to open the main door. Let me know how you make out and also if you require further assistance with this problem. If you don't require further assistance and this indeed was helpful to you, please allow a moment to rate this solution I've given accordingly. Thank you for visiting "fixya" today and good luck. Macmarkus :)
May 18, 2010 | Bosch WFMC 3200 Front Load Washer
Need help installing a drain pump
look at the back , where the drain hose is, the pump is on the other side,then, just lay machine down on its side, you will see it
Jul 24, 2009 | Bosch WFMC 3200 Front Load Washer
Put front gasket back on
start on the door side of the appliance put the top of the circle in first this should allow you to stretch the spring a little to make it go on
its a pain and it kills the tips of your fingers try not to overstrech it because it will fall off all the time
Mar 12, 2009 | Bosch WFMC 3200 Front Load Washer
Wfmc 3200 fixed E04 problem, where does the gasket go?
Take the cap back off. Put some pipe thread sealent on it. Just some basic pipe thread tape should do the job.
Feb 13, 2009 | Bosch WFMC 3200 Front Load Washer
Bosch WFMC 3200 Front Load will not pump water out
the pump gears could be stripped or clogged with soap residue including the line from the pump to include the drain hose itself. I took the back of my machine off after cleaning the pump twice to find the reservoir full of a brown soap gunk/sludge. there is also a small rubber tube that runs from this reservoir back into the drum which was plugged shut with the same gunk. this thick soap residue can damage the pump motor or slow the drainage system to get the E 04 warning. I cleaned the gray drain hose out with the garden hose and was amazed at the sludge that game out. When the machine would run on the drain cycle we would also get a sewage smell that I thought was coming form the drain trap but turned out to be caused by the sludge in the pump. After cleaning the system and now using no more that a tablespoon of soap it works great & the cloths are clean.
Dec 18, 2008 | Bosch WFMC 3200 Front Load Washer
Wfmc how to put new seal
hard to explain easy to do. my advice is remove old one, but new on in reverse order its not easy first time ,but i have faith in you .motto do not give up. close ireland good luck
Nov 28, 2007 | Bosch WFMC 3200 Front Load Washer
No drain, no spin.
Maybe a small piece of clothing stuck in the waste pump. remove the rubber hose at the pump end and check inside the hose and inside the pump, make sure you can turn the pump spindle.
Sep 16, 2007 | Bosch WFMC 3200 Front Load Washer
Washer wont drain or spin
As long as the water is draining away okay,then it sounds like new carbon brushes for the motor are needed if belt is ok.Should cost 10 pounds or so for replacement.Turn off power via socket before removing belt and motor.Good luck...
Aug 27, 2007 | Bosch WFMC 3200 Front Load Washer
Bosch WFMC 3200 Front Load Washer Logo
161 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
