Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
It keeps saying LF in the middle of the rinse cycle.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 143 Answers
This error code means that the water valves are taking over 10 minutes to fully fill the desired water level. this could indicate that you may have a faulty water valve, and or a kinked hose that isnt allowing water to flow TO the valves. part number for your water valve is W10059320. And is a fairly complicated valve to replace, A faulty water valve can often happen if you water has alot of calcium or rust in it.Hope this helps.
Thanks.
Posted on Nov 19, 2009
2 Suggested Answers
emissionwiz
  • 76118 Answers
SOURCE: Regarding Kenmore Oasis mod. 110 27072600 Ser.
LF is a failed water inlet valve either hot or cold sets the code, try using just hot then just cold settings and see if the code goes away, if it does then the hot or cold water solenoid valve at the back of the washer is defective
Posted on Sep 16, 2010
Kenmore elite oasis model 110.27032600 LF error. had an issue with the washer cycling through all the lights, would turn it self on etc. Had the repair man come out and he replaced the computer board....
The LF error means Long Fill.
When you start a cycle the water should come into the dispensers. If you have a good flow through the dispenser the valves will be okay.
I recommend checking the inlet water screens on the back of the washer. The inlet screens are located on the water valve. To access the screens you will turn the water off and remove the inlet hoses. The screens prevent debris from entering the valve and sometimes over time mineral deposits build up on the screens. This can block the water or slow the water fills down to a trickle. You can pull the screens out and clean them if necessary. Flush the inlets thoroughly with water when replacing the screens. If debris gets past the screens, it can cause the valves to stick open and an overflow of water can result.
While you have the fill hoses disconnected, place the ends of the hoses in a bucket and briefly turn on the faucets to check for proper water pressure and flow from both hoses.
A common reason for an L F (long fill) error on this washer is the drain hose being stuck to far down the drain standpipe.
If the drain hose is to far down the standpipe then a siphon can occur which causes the washer to fill and drain at the same time. This will cause a long fill error.
Feb 02, 2011 | Kenmore Oasis HE 27082 Top Load Washer
Washing machine displays an LF error code. Started last week during whitest whites cycle in rinse. I cancelled and just did rinse to finish my load. All other cycles worked and yesterday all started...
LF = Long Fill
LF flashes when the water level does not change for a period of time after the valves are turned on OR water has disengaged the basket but control does not detect a water level change.
Is water supply connected and turned on?
Are hose screens plugged?
Is water entering the tub? If so check pressure hose connection to machine/motor control.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 07, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio: During a white load the machine stops at 38 min
lf means long fill check your fill hoses and make sure the water is comeing out. sounds like a problem with your inlet valve and/or your water from your house is not right.
May 31, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Stuck in cleaning mode?
Open the preground coffee lid, drop a cleaning tablet in it, let it do it's tablet cleaning cycle. After cycle empty water out of tray and clean.
May 16, 2010 | Jura Capresso Impressa Z5 Espresso/Coffee...
What does LF mean on the rinse cycle?
"LF" is a Long Fill error. If the fill time exceeds roughly 10 minutes, the fill valves are shut down and the error code is generated. If the error does not clear, or keeps reoccurring, it is recommended that you doublecheck to make sure your water taps are on all the way and check the hoses for kinks or clogs. If everything checks okay, check the screens on the fill valve for sediment build up. You may need to replace the valve. I hope this helps you.
Oct 23, 2009 | Kenmore Washing Machines
Just had electronic control panel replaced (due to manufacturer's
sounnds like you need them to come bback they may have left the hot water connection loose.
May 30, 2009 | Washing Machines
LF code
■ “LF” (Washer is taking too long to fill)
Check the following:
Are the water inlet hoses kinked or clogged?
Are the water inlet valve screens clear?
Press PAUSE/CANCEL to clear display.
Recalibration is not needed but, you will need to check the above hoses and valves for obstructions and kinks.
Please rate and god bless.
Mar 27, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
LF Code
Why not just clean the screens to increase the fill pressure and spend not 1 cent on the repair.
May 08, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
232 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
