Question about Sony PlayStation 2 (PS2) Console
Spinning graphics?? when i install a game....all the graphics spin around a center point of the screen and you can not stop the spinning??
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 64 Answers
Try pushing the av cable from both ends to make sure that they are perfectly fixed.......
Posted on Jan 18, 2008
Shakes like crazy spin
Your maytag washer tub and basket assembly sits on a base counter balanced by 6 springs. Is is possible to move the tub around by hand. The best test is to start a spin with the unit empty of cloths, allow the tub to reach speed for a few seconds, lift the lid and check the tub position after it stops, if the tub is off center with the lid opening, re center the tub and run spin again. If your tub returns to an off center stopped position you most likely will need the base kit replaced. The base kit replaces the entire bottom of the unit along with new springs, and snubber, if so packaged per your application. Maytag experienced a defective stamping dye when these bases were stamped, thus they were stamped crooked. This test is performed with the machine it's self relatively level on the floor. If the tub assy leans and favors any one direction while you are trying to center it with the lid open, you may have a rusted or broken counter spring in side the unit. Pleazer Appliance...
Apr 11, 2014 | Maytag Washing Machines
Need instructions for the sorry spin game
Hi Roxanne:
The goal is to get all four of your pawns around the board and into your home space. You move around the board by drawing cards and following the instructions on the card. If you land on the same space as another player's pawn, you send it back to start. The main difference in Sorry Spin is that the board is made up of 5 gears (a large center gear and 4 smaller home gears) and sometimes you draw a card or land on a space with allows you to "spin" the gears 1/4 of the way around. Doing this may move you closer to your home gear or send another player right past their home, making them go all the way around again.
Here is the instructional guide: GAMES/SORRY.html
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Dec 20, 2011 | Hasbro Sorry Spin Game
I need instructions for sorry spin
Nov 05, 2011 | Hasbro Sorry Spin Game
My dstt menu wont stop loading! my dstt use to work fine but today when i was going to play on my dstt, the menu wont stop loading! it stays on the same screen with that spinning thing at the bottom...
Backup all your save data then reformat your microsd card. Download the latest firmware for it and put that on the card. load your games again and they should be working
Mar 20, 2011 | Nintendo DS Lite Console
I need sorry spin instructions on how to play the game
Hi Tammy:
Jan 02, 2011 | Hasbro Sorry Spin Game
WHEN PLAYING GAMES A WHOLE LOT OF COLOURFUL LINES AND BLOBS POP UP WHAT COULD BE THE PROBLEM
your graphic card is low you need to upgrade in order to play games with higher graphics
Apr 27, 2010 | ASUS A9600GE/TD RADEON 9600, (128 MB)...
Changed power supply, everything is connected and
well you may have a bad video card or maybe even a monitor have you tried another monitor? if so, then you can purchase graphics cards at most electronics stores!
Dec 22, 2009 | Gateway GT5012 PC Desktop
New Video Card fan sometimes won't spin (in new self built pc)
I would RMA the card if the fan refused to come on. When it is not on and you begin testing the card, does the fan come on at that point? How do you make the fan come on other than turning on your computer? If the fan isn't on to begin with, but comes on when you start playing a graphics intensive game I would not RMA the card unless Nvidia support suggests it.
Apr 20, 2009 | MSI Computers & Internet
Disk wont spin?
If its still under warranty, and the seal hasn't been cracked, contact Microsoft.
Try what hijackthis1 suggested, if that doesn't fix it, try this.
Since you have the 360 apart, and the top cover off of the dvd drive, here we go...
There's a circular cut-out that's glued to the top cover that you removed from the dvd drive, right below the sticker with all of the drive information. I was able to pop out the cut-out. After that you now have (3) pieces in your hand, the cover, cut-out, and a plastic piece.
Connected the dvd drive back in the 360 with the top cover off.
Put a game or movie in the drive, don't hit the eject botton, just put the disc in the tray.
Now with the disc in the tray, put the plastic piece in the center of the disc. Its magnetic, so it should kind of lock in to place.
Connect the power/av cords in the 360 and turn her on.
You should see the disc try to spin. (It may spin once or a couple times around, but it will stop). When you see the disc start to spin, GENTLE, spin/turn the disc in the direction in wants to go. It should load the game or dvd with no problems.
Reassemble the cover and put back on the dvd drive.
Now use the eject botton, and try games and dvds.
If disc fails to spin, do process over again.
I've done this with one of my 360's with no problems.
The drive I used was an Hitachi 0059DJ.
Dec 24, 2007 | Microsoft Xbox 360 Console
Sony PlayStation 2 (PS2) Console Logo
24 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
