Question about Dell DimensionTM XPS 710 PC Desktop
Solid amber light. No power to the system just the fan runs.
  • 380 Answers
Solid amber light means the CPU is not being powered properly, that is USUALLY a bad power supply. Contact Dell and order another power supply. if that doesnt fix it, you have a bum board. (usually, you will see popped capacitors on the board if its bad). I will say, that in about 70% of these, its a bad power supply. power supplys arent cheap (unless you have a warranty of course) but they wont break the bank. a replacement is likely going to be about 40-70 dollars. I havent priced it, but you can ask dell at dell.com/chat. Good luck.
Posted on Nov 19, 2009
  • 59 Answers
The XPS? 710 system includes a variable-state power button LED. The LED can provide a wealth of information about the system's state. The LED indicates the progress of the system boot; it does not indicate the exact problem. In this case(Solid Amber) The system is able to get power and isdistributing that power to its internal components but cannot process data. To narrow down to the problem... 1) check the 4 diagnostic lights at the back. 2) Open the system Tower, reseat the Power connector to the Motherboard better known as ATX connector 3) Remove each Expansion Card one by one and try booting the system. 4) Reseat the CMOS battery and the Processor. Please check for the Quad lights(1-2-3-4) at the back Y = Yellow G = Green. 1) Y-Y-G-Y is A possible processor failure has occurred. Reinstall the processor and restart the computer 2) Y-Y-G-G is Memory modules are detected, but a memory failure has occurred. If you have two or more memory modules installed, remove the modules, reinstall one module, and then restart the computer. If the computer starts normally, reinstall an additional module. Continue until you have identified a faulty module or reinstalled all modules without error 3) Y-G-Y-G is A possible graphics card failure has occurred.If the computer has a graphics card, remove the card, reinstall it, and then restart the computer. 4) Y-G-G-Y is A possible floppy or hard drive failure has occurred. Reseat all power and data cables and restart the computer Source: Manuals at http://support.dell.com
Dell poweredge 2650 solid amber light
go here and enter the service tag of your server and download dell open manage server administrator managed node. once installed it will tell you exactly what the problem is. i believe the current version of OMSA is 7.1
Dec 10, 2012 | Dell PowerEdge Computers & Internet
Dell 1209S Projector, tries to turn on, and the fan comes on for 30 seconds and then goes off again. It tries this several times and then the light bulb icon comes off and it doesn't do antything else
Lamp is burned out or makes a popping sound.
When the lamp reaches its end of life, it may burn out and may make a loud popping sound.
If this occurs, the projector does not turn back on. To replace the lamp, see on page 38.
LAMP light is solid amber If the LAMP light is solid amber, replace the lamp.
LAMP light is blinking amber If the LAMP light and the Power light are blinking amber, the lamp driver has failed and the projector will automatically shut down.
If the LAMP light is blinking amber and Power light is solid blue, the color wheel has
Unplug the power cord after 3minutes then turn the display on again. If this problem
persists, contact Dell™.
TEMP light is solid amber The projector has overheated. The display automatically shuts down. Turn the display on again after the projector cools down. If the problem persists, contact Dell™.
TEMP light is blinking amber A projector fan has failed and the projector will automatically shut down. If the problem persists, contact Dell™.
Oct 23, 2011 | Dell 1209S DLP Projector
Dimension 3100 turns on the power button has a steady orange light there is also an orange light on motherboard cpu and power suplly fans working but wont bot up
Blinking amber (orange) indicates a problem with the power supply inside the computer. If the system cannot boot and there is a solid amber light, this could indicate a problem with the power connections for the CPU on the system board (see "Power Problems" in your Owner's Manual).
Mar 06, 2011 | Dell Dimension 3100 PC Desktop
Amber light solid. Replaced the power supply ad the cmos battery. removed the memory and reconnected. Plugged back in and I hear the fan running kind of loud (louder than before) Still solid amber light
most times i have seen amber light, if it is where the pwr light is on front of tower means ur mother board might be fried. check capacitors one by one and make sure none are extended or leaking. dell has had this issue before when they sent out a bad batch of capacitors. may last it job was mostly issues with this. good luck.
Dec 11, 2009 | Dell OptiPlex GX520 PC Desktop
Why did my xps 400 just quit, The only thing that works on it is, the cooling fan at high speed
The fans running full tilt are an indication of a NO POST failure with the motherboard.
The POWER LED on the tower, is it Solid Green? Solid Amber? Flashing Amber?
The diagnostic LEDs? (Numbered 1234) are any illuminated?
General trouble shooting is as follows:
  1. Power system off, disconnect all external connections except the power cord, turn the system on see if any change. If you get a change, reconnect items one at a time till you ID the failure. (Twice I've seen a bad mouse cause a no post, so don't assume items are good) If no change go to step 2
  2. If no change, then POWER LED is likely a solid amber. Open the tower, remove all PCI and PCI-E cards, see if the symptoms change. If they do, like before add items back one at a time till you ID the failure.
  3. Disconnect power to all drives, see if anything changes ....
  4. Remove the RAM, see if there is a change, if no change then replace the motherboard. If you get a change, try RAM modules individually see if one is faulty.
Dec 09, 2009 | Dell XPS 400 PC Desktop
Amber colored power light on eMachine W3503
The amber power light indicates that your computer has been "sleeping" or "hibernating" and usually all it takes to restart the computer is tapping a key on the keyboard. If this is not the case, try holding the Power switch down for 6-10 seconds to force the system off. Restart in Safe Mode and try to find the settings for Sleep/hibernate, open the control panel and open the Screen Saver. Select "Change Power Settings" and set it for "Never" on sleep and hybernate.
Nov 10, 2009 | E-Machines W3503 PC Desktop
Solid Amber light when starting the Inspiron 530 . Every time i start the Dell inspiron 530, the solid amber light comes on and it dont start. As per Dell user manual i have tried everything but of no use....
Amber led simplifies a start-up-error. This could be a number of things.
For example:
Check if HDD is connected properly
Check if RAM is connected properly / also if this is damaged your pc wont start.
Check your m/board for any loose capacitors an if they are not popped at the top.
Your LCD screen is properly plugged in to the m/board and if the cables aren't damaged they are very thin and fragile.
also could be the power supply...
Goodluck
Ryno Gerber
Jul 30, 2009 | Dell Inspiron 530 Desktop Computer
Dell GX270 won't boot up with solid amber light on Power button
Check motherboard for bad capacitors. I had the same problem and when i had bad capacitors replaced everything is ok.
Feb 14, 2009 | Dell OptiPlex GX270 PC Desktop
Motherboard change
jethro..
http://support.dell.com/support/edocs/systems/dimC521/en/SM_EN/tshoot.htm#wp1064555
check on system lights... what are the diagnostic lights telling you??
if the 4 lights are off you may have a problem with the led itself or the powersupply is just messing with your head.
Dec 02, 2008 | Dell Dimension C521 PC Desktop
Sold amber light/fan running
Hi, Does the system makes any beeping sound? Does it go to the boot up stage, which can be seen on the screen. Provide the model number with your reply. Thanks, Mike
Nov 01, 2008 | Computers & Internet
Dell DimensionTM XPS 710 PC Desktop Logo
1,605 people viewed this question
Alun Cox
