Question about Motu UltraLite FireWire Audio Interface with MIDI Sound Card
Fire wire interface died
I installed the drivers off the installation disk, shut down the computer, then connected the interface, waited until the interface was fully turned on, then started the computer back up, once the computer had booted up the fire wire interface turned off and no longer works. how do i fix this?
Downloaded latest driver from website
Posted on Nov 19, 2009
Panasonic IEEE 1284
Not sure what the question is. IEEE 1284 is a parallel cable interface, standard on most computers up until Windows XP for sure. http://en.wikipedia.org/wiki/IEEE_1284. This interface was substantially replaced by USB. If you have an older printer with this interface you can still connect this to a newer computer without the parallel interface by installing an interface card (into a desktop computer) or connecting via a Parallel to USB adapter.
http://www.pcfixup.ca/2010/03/connecting-parallel-port-printers-to.html
May 08, 2014 | Microsoft IEEE 1284.4 compatible printer
I have a medion pc. I rebooted it a while ago and now it doesnt even have an option to connect to a wireless network. Please help.
Your missing the driver for the wireless connection object possibly. You can check this by going to devices not sure what Operating System your using XP or Win 7 You can find devices in the control panel go and check for anything wireless. Also not sure what you meant by rebooted the computer? I assume you redid the System again not sure if you did that or just rebooted the computer. Either way if there is no wireless connection coming up for you a driver is missing for sure. Also not sure if your using a USB Wireless Connector or a LAN R-45 cable or DSL or Cable. So my answer is going to be speculation only. If your using a wireless LAN card with antenna PCI then shut down the computer. Ground yourself and touch the case before touching anything inside. Then take the card out of the computer reboot then shut it down. Unplug and reverse the install place back in and restart it should find the card, if you have a disk for that card have it handy if not let hope Windows will pick it up if not you will have to get a driver for that card from another computer and download it then insert it into your computer to install the driver files for that card.
Second if your using a USB Wireless Stick provide the software for your Sick do no install the USB wireless device first install the software first then wait until it tells you to insert your device.
Obviously your not using a LAN connection R-45 cabling. So in short you will have to find the driver disc or go online elsewhere and download the card or device for your computer.
Another option is to go to control panel and look for wireless connections then look for place icon on task bar see if you have wireless at least showing.
I hope that this gives you some idea of what to do. ......John
Apr 12, 2012 | Computers & Internet
How can I get a geforce 7600 gt graphics card to work in a el1333g-01w emachine
1) Did you install the drivers off of the installation CD disk, FIRST?
THEN physically install the graphics card?
If not you get a Driver Conflict.
When a device is installed, (Such as a graphics card, for one example), Windows breaks it's neck to find matching Drivers.
If you install the graphics card first, THEN the drivers, Windows will have already looked for THE drivers, and not found them.
Windows will then go through it's THOUSANDS of generic one size fit's all drivers, and match drivers up to the GeForce 7600GT graphics card.
This = No
Windows: "Which drivers do I use? These or THESE?"
Driver conflict.
IF, this is what has transpired you need to;
A) Computer on a table, computer unplugged from power, computer case open. FOLLOW Anti-Static Precautions. Unplug the monitor from the 7600GT. Remove the GeForce 7600GT.
B) Leave the case open.
Press, and hold the Power On button in for a count of 10 seconds. Let go.
Do this procedure 2 more times.
(IF,
1) You press the Power On button in, and the Power On LED light comes on, then after a few seconds goes out,...
2) And the same scenario happens again for the Second time, you press, and hold the Power On button in,....
3) See if it lights up again for the Third time. If so, hold the Power On button in again, until it goes out.
You are draining residual power. Don't worry about the CMOS Battery at present )
This action resets BIOS Setup back to the factory default settings.
In otherwords back to the Nvidia GeForce 6100 integrated graphics on the motherboard.
It also clears CMOS Error Codes.
C) Plug the monitor into the VGA port, in the I/O area at the back of the computer.
Plug the computer into power.
WAIT 1 minute, turn the computer on.
Windows should load. After Windows is fully loaded, put the Installation CD Disk in the optical drive, and load ALL software.
(Drivers, Graphics User Interface, etc)
Let the computer run for a few minutes.
Now turn the computer off normally. Unplug from power. Observe Anti-Static Precautions, and reinstall that GeForce 7600GT.
Plug the monitor into the 7600GT. Plug the computer into power.
Should get in the taskbar at the bottom, "Found new hardware", and perhaps another one, "Found GeForce 7600GT device"
Immediately go to the Nvidia graphics user interface, and open it up.
Set the graphics card to it's optimum performance.
(Also make SURE the Screen Resolution is set to what the monitor uses.
Right-click on empty area of desktop screen.
Left-click on Properties at the bottom of the list.
Left-click on the Settings tab.
Move the Screen resolution slider to the appropriate screen resolution.
Left-click on Apply.
Then left-click on OK.
Also make sure in the box under Color quality, that it states
Highest (32 bit) Use the blue down arrow to the right of the box, if it isn't. Left-click on Highest (32 bit)
For additional questions post in a Comment.
Would appreciate it if you would reply back in a Comment, as to your findings.
Regards,
joecoolvette
{To add;
Sometimes a computer has to be shut all the way down, after all of the above, and wait 60 seconds.
Then turn the computer on.
Sometimes you have to do this twice. Then Windows and BIOS catch on }
Jan 21, 2012 | AOpen GeForce 7600 GT, (256 MB) PCI...
Adding my printer back on my computer without the disk
Connecting the wires to the computer didn't work? Sometimes just connecting the wires and waiting for the computer to detect new hardware will automatically make it install the right drivers.
Jan 04, 2012 | Lexmark Z600 InkJet Printer
Hi there. I have just purchased a new ASUS Radeon 6770 graphics card. I have just installed the hardware. When I turn the PC on, I can't get any video signal output from either the onboard graphics, or...
Hi granttoolmad
Shut down computer and disconnect power plug . Extract new graphics . Reconnect and reboot computer , you should get video back . Install the driver with the cdrom you purchased with the card . Shut down . Install new card . and boot your machine . Wait for Windows to recognize the card . Shut down . Connect your monitor to new card . Reboot .
Best regards ,
fanaudi .
Jul 04, 2011 | ASUS Computers & Internet
How to install?
Turn your cable-modem (or DSL-modem) off.
Use an Ethernet cable to connect from the modem to the 'WAN' (or 'Internet') port on the router.
Use another Ethernet cable to connect from one of the 'LAN' (or 'network') ports on the router to the network-port on your computer.
Connect all the power-supplies.
Turn the modem on, and wait until it's fully restarted.
Turn the router on, and wait until it's fully restarted.
Restart your computer.
You should now have Internet access.
Nov 28, 2010 | Computers & Internet
When i attempt to install the driver included with the Tascam 122 interface it says "Your user account must have administrator privleges to install drivers" and I already do have an administrative account.
Boot normally and once you fully logged in, press the [Log Off] button instead of the [Shut Down] button. It will prompt you to log on. Select [Administrator] and go in as the Administrator and not someone who has Administrative privledged.
If that does not work, reboot the computer and press [F8] to get to the boot menu. Select "Safe" boot. Once in the safe boot mode install the device ans Administrator. Some items can not be installed this way but if all else fails, give it a try.
Oct 06, 2010 | Tascam US-122 USB Audio/MIDI Interface...
Ugrade Lenovo 8113 to GeForce 8500GT 512 -Problems?
Not a compatibility issues per se, but their could be a Driver conflict.
Install the Drivers FIRST, then power down, computer unplugged from power, observe Anti-Static precautions, and install the graphics card.
Plug the monitor into the graphics card, plug the computer into power, WAIT 1 minute, turn the computer on.
(The drivers are on the installation CD that comes with the Nvidia GeForce 8500GT graphics card. Just install the CD, and load the software. The drivers will automatically be loaded)
If you install a device first, (Such as a graphics card), Windows will break it's neck trying to find suitable drivers.
Windows will match up one of it's thousands of generic drivers.
Then you come along, and install THE drivers.
Driver conflict.
If you have already installed the graphics card, then powered the computer up, and installed the drivers, I suggest you do this;
Computer off, and unplugged from power. Open the computer case.
(I prefer to remove all cables to the computer, and lay it on it's side on a clean towel, on a table)
Observe Anti-Static precautions.
[Anti-Static Precautions:
Your body carries Static electricity.
Static WILL fry out (Short Circuit) the hardware components inside a computer.
You may not even see it, or feel it.
TOUCH the metal frame of the open computer case, BEFORE you reach inside the computer, or take a device out of it's anti-static bag.
Should you get up in the middle of working on your computer, and leave, upon your return Touch the metal frame again ]
Remove the GeForce 8500GT.
Plug the monitor into the Integrated Graphics of the motherboard.
(VGA port
http://en.wikipedia.org/wiki/VGA_connector
Press the Power On button in, and hold it in.
Hold it in for a count of Five seconds.
(And I mean at least Five. Count 1001, 1002, 1003, 1004, 1005)
Let go of the Power On button.
Do this procedure two more times.
What you are doing is clearing CMOS Error Codes, and resetting BIOS back to the factory default settings.
One of which is Integrated Graphics.
Computer case open, cables plugged back in, computer in normal position.
Plug the computer back into power.
When Windows has fully loaded, go to Start>Control Panel>Add/Remove Programs.
Remove anything you see associated with the GeForce 8500GT.
(DO NOT remove anything in the Windows files. It's a separate section you have to go into anyway, but thought I would warn you in advance, just in case)
Restart the computer. (Start>Turn Off Computer>Restart)
Once Windows has fully loaded again, install the software off of the CD disk, that comes with the GeForce 8500GT graphics card.
If you are asked to restart your computer - No.
Close all windows, go back to your desktop screen.
Shut your computer down normally.
(Start>Turn Off Computer>Turn Off)
Unplug your computer from power. Observe Anti-static precautions. Install the GeForce 8500GT.
Plug the monitor into the graphics card.
Wait 1 minute, turn the computer on.
Everything works okay, close the computer case.
Jun 14, 2010 | Lenovo ThinkCentre® M52 PC Desktop
My windows xp was reloaded and now when rehooking up my 7200 all in one, its not working. All wires are connected, original installation disk was used.
Did you install the printer software and drivers before you connected the printer to the computer by a USB cable? Uninstall any drivers that have already been installed then restart. You can get the drivers again from the web site, http://welcome.hp.com/country/us/en/support.html?pageDisplay=drivers . Wait until the software asks you to connect to the printer before connecting the USB cable. If you are connecting to a router for an ethernet connection, then that can be cabled together before installing the software.
If the drivers were installed correctly, start diagnosing a problem with the cables. Try new cables, changing ports, and a known working device on the port. When you reinstalled XP, did you include the motherboard drivers specific to your machine (that will have the USB and ethernet drivers)? If you missed those steps, you may need to uninstall the printer before doing that update and then restart.
I hope this helps.
Jan 29, 2010 | HP Office Equipment & Supplies
I have a mac book pro that has xp as the only os. I tried to reboot xp again and it wont install fully. My question is how do I remove xp a reinstall os x?
  1. Insert OS X disc
  2. shut down computer
  3. hold down the "c" key
  4. power on the computer
  5. wait for the computer to boot from the disc
  6. click install
  7. go to the top and choose Utilities
  8. open Disk Utilities
  9. ERASE the hard drive, choose Mac OS Journaled as file system.
  10. Go back to the install menu
  11. follow the prompts
  12. that's it! :)
Nov 20, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Computers & Internet Logo
234 people viewed this question
Top Motu Computers & Internet Experts
Jay Plesset
Terry Hair
Are you a Motu Computer and Internet Expert? Answer questions, earn points and help others
