Question about Sanyo VPC-T1060 Digital Camera
I have a Sanyo VPC-T1061 digital camera. My problem is that when i turn it on, it was blurry. I tried to reset the setting, but it did not work.I check all of the settings but there was no solution.please help.thank you
SOURCE: Help!! Sanyo VPC-E760 Digital Camera driver for Mac OSX
My Sanyo S6 is showing System error. What I do?
Posted on Jun 11, 2008
the driver is not separately available for Sanyo VPC-E760
Posted on Aug 06, 2008
Shadowmaru
  • 33 Answers
SOURCE: NO MANUAL OR DISC FOR MY CAMERA
Hello Carrmaher, here is a direct link to your camera's owners manual.
http://sanyoservice.com/pdf/images/VPC-S500.pdf
If you are unable to open it please go to www.adobe.com and download adobe acrobat reader.
Hope this helps you and please don't forget to rate my assistance.
Posted on Feb 13, 2009
dlundmark
  • 797 Answers
SOURCE: driver Sanyo Xacti VPC-T700 Digital Camera?
If you have problems with finding or installing drivers, don't use them, use a card reader instead.
But if you want the drivers and software, search on the Internet or go to the manufacturer's site and download what you need.
Use a card reader, and skip the use of software and drivers.
A card reader saves time and effort, especially if you have more than one kind of digital camera or device which uses a memory card.
\A card reader will show as a mass storage device. It will show up as another drive and can be accessed as a drive.
Posted on Oct 27, 2009
  • 11967 Answers
SOURCE: Hi! I have a sanyo
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jul 07, 2010
What does it mean when your Sanyo VPC-X1250 digital camera says "System error?"
try to reset your cammera settings to default
try to change memory card first.
try to format your memory card
Jun 05, 2011 | Sanyo VPC-X1250 Digital Camera
Sanyo vpc s1070 displays - lens error when turned
try these:-
  • connect it to pc and on it
  • vaccum the barrel of lens
  • changing mem. card and batt. for 2min.
  • shake it.
  • on and off in different positions
  • hit the part near lens softly with palm (trust me this made mine work)
Apr 18, 2010 | Sanyo Vpc-s1070w Digital Camera
Sanyo VPC-S1080 turns on and
See if the menu has a battery type setting. Some cameras have the ability to use different battery types (alkaline, Ni-Cad, Lithium, ect) and have power management presets to accurately indicate a low battery condition. If you are set to one type an install another, a false reading would result.
Jan 16, 2010 | Sanyo VPC-S1080 Digital Camera
I can take a picture but its blurry
Set your camera to auto and try again. The setting you are using determines what your picture will look like. If you want to use other settings you should know how they work so you can get what you want. Otherwise set your camera to auto. You will find this on the small dial with the different settings indicated on it. If you do this and your picture is still blurry, then when snapping your shot, press the button slightly down (not completely at first) wait a few seconds and then press it down completely to take your shot.
Sep 13, 2009 | Sanyo VPC-S500 Digital Camera
Why all my photos come out blurry?
Reset all the settings in the menu to default, then set to your liking.
Try the camera again.
Aug 31, 2009 | Sanyo VPC-S880 Digital Camera
The camera wont take pitures, every time you hit the button to take the picture it says Write ok! on the screen and wont take the picture. Sanyo VPC-E870 Digital Camera
hi try to reset ur camera...To do such reset, turn on the camera and hold the menu button down for longer than 5 seconds. A message should hopefully come up on your LCD asking if you want to reset the camera. Select Yes...
thank u!!!
rate me!!
Jul 15, 2009 | Sanyo DSC-SX500 / VPC-SX500 Digital Camera
My camera takes fuzzy pictures
Your lens may need adjusting. This info may help . Other People solved problem. Lots of Info on this link.
http://www.fixya.com/support/t102982-e_18_problem
Mar 23, 2009 | Sanyo VPC-S880 Digital Camera
My SANYO VPC-E760 camera won't turn on!
hi Latinababe.
not sure if you have the manual,but if you go to this link you will find it there.
Sanyo 7 Mega Pixels Digital Camera User Manual VPC E760 ManualsOnline com
this is all i could find,i can not find anything about not turning on.
so i hope this does help you out.
if not you could try this link.
SANYO VPC E760 camera won turn on Google Search
Nov 29, 2017 | Sanyo VPC-E760 Digital Camera
Sanyo vpc-e760 wont focus
try setting it on party mode. with flash always on. see if that helps
Jun 12, 2008 | Sanyo Xacti VPC-S60 Digital Camera
Sanyo VPC-T1060 Digital Camera Logo
46 people viewed this question
Top Sanyo Cameras Experts
teddyboy
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Sanyo Camera Expert? Answer questions, earn points and help others
