Question about Panasonic Matshita- | SR-8178-B | Slimline | DVD-ROM (SR8178B) Burner
Matshita dvd- rom sr8178 will not read any cd or dvds
The disk drive powers up the green light flashes but shuts down again. if you go into the system of the computer there is a yellow exclamation point on the matshita dvd-rom do you have a fix for me thank you
SOURCE: MATSHITA UJ-840D, has disappeared and I can't play cd's/dvd's.
Before you do this though export your current registry to the desktop by selecting export from the file menu. If this doesn’t work just double click on the exported on to restore it.
1. Start Registry Editor by typing regedit into the start search box in the bottom left hand corner of the start menu.
2. In Registry Editor, expand Computer, and then expand HKEY_LOCAL_MACHINE.
3. Expand SYSTEM, and then expand CurrentControlSet.
4. Expand Control, and then expand Class.
5. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}.
6. In the details pane of Registry Editor, on the right side, click UpperFilters.
7. Right click and select delete
8. Click Yes when you receive the following message: Are you sure you want to delete this value?
9. Now look for LowerFilters in the right hand panel.
10. Right click and select delete
11. Click Yes when you receive the following message: Are you sure you want to delete this value?
12. Exit Registry Editor
13. Restart the machine
It wit worked for me on Acer with UJ845D XP Good luck
Posted on Mar 25, 2009
  • 489 Answers
SOURCE: TEAC DW-28E DVD/CD-ROM not reading TDK DVR+R disk
ON a computer than can read the disk and has CD/DVD burning software installed on it, check the status of the media sessions. If this was writtien as a multi-session disk and the session has not been closed, many older drives will have difficulty reading it.
Posted on May 30, 2009
  • 1019 Answers
SOURCE: My Matshita UJ-840D DVD/CD-ROM Drive Stopped working
i,m assuming this is A laptop Computer ?
The only thing you can try is this:-
go to My Computer/Control Panel/ System/Device Manager.
see if there are any yellow triangles or exclamation marks by your problem device. if so click un-install. then at the top of that page, there is a refresh icon or similar. which will rescan the systems bus.
failing this try add new hardware wizard, in control panel.
finally ensure the device is connected correctly, unlock/remove and re-insert. update any device drivers for this.
Mike @ Compurepair.
Posted on Sep 05, 2009
  • 137 Answers
SOURCE: The cd/dvd drive installed in my laptop does not work.
Please read this post.
it has the same cd drive which you are talking about. the problem is only with the drive. they also do not provide any firmware to update it. there is no filters problem. the problem is mechanical which is something you cant fix. these are chinese made drives, just use and throw. so, its now time to throw. there is no point banging your head, becasue i already banged a lot for this issue, and please dont replace your drive with sony optirac, it will also give you the same problem. all the best.
the drive which you talked about is the same i had originally on my computer. i also tried myself to update the firmware of the drive but no go. it still did not work. so i checked the functionality of the dvd drive. what is the technology of dvd drive and i found there are 2 lenses in the drive to read cd and dvd. if one fails it will read only 1 type of cd or dvd then. presently my computer has 33rd optical drive which is again matishta. it is still working, i dont know how long will it work. but touchwood its working now. so all i can say after such a bad experience is that its just a luck. regarding which optical drive to get now? you can get any one. its just the name, technology remains the same. like a lot of different people. but blood remains the same. so name doesnot matter. But i strongly say drives with SONY OPTIRAC are the worst drive, Never buy that. other than that you can get anyone. hardly matters.
Posted on Oct 15, 2009
Testimonial: "I will replace the driver as per your instructions. Thanks."
  • 608 Answers
SOURCE: Is the Matshita UJDA775 DVD/CDRW a DVD Writer ?
Download this little program DISCinfo 1.6.1. When you run it it will give you all the info you need about all your drives. It's good, I use it. Get if from here []
Posted on Mar 19, 2010
SOURCE: DVD/CDRW drive not recognising any DVD's
Hi people!!
This fixed my problem. Give it a go, I have access and am using my burner once more.
Good luck!!
Note: The solution provided requires editing of the registry.
  1. To begin the process, start the Registry Editor.
    • Click Start, click Run, type regedit, and then click OK.
    • On Vista machines, Run is accessible through Accessories.
    • Click the plus sign (+) next to the following folders in the left side of the window pane:
    • SYSTEM
    • CurrentControlSet
    • Control
    • Class
    • {4D36E965-E325-11CE-BFC1-08002BE10318}
  2. Look for any of the following names in the right side of the window pane:
    • UpperFilters
    • LowerFilters
  3. If any of the items above are listed, right-click on the item and select Delete.
  4. Be sure to restart your computer after you have deleted the files in the registry.
  5. Open My Computer (XP) or Computer (Vista) and check to see if your CD or DVD drives have returned.
  6. In some cases, you may need to reinstall some programs such as CD or DVD burning software, iTunes, or Nero
Posted on May 17, 2010
0 characters
1 Points
Matshita DVD-RAM UJ8A2AS Fails to Read CDs/DVDs
You probably fubar'd the drive when you attempted to uninstall the bios. Only the hands of an experienced drive specialist can help you.
May 14, 2013 | CD & DVD Burners
I want to get region free a MATSHITA DVD-RAM UJ-850S.
click start control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
or if this is what you mean by region free
Any DVD Backup is DVD Decrypter and DVD copying software to copy entire DVD movie to hard disk, and removes all the CSS, RC, RCE, APS, UOPs and Sony ARccOS protections while copying. Combining powerful functionality with a straightforward interface, Any DVD Backup provides an easy way to transfer DVD information onto your hard drive.Any DVD Backup is FREEWARE that will circumvent the copy-protection schemes used on commercial DVDs and enable you to make copies of store-bought DVDs. With Any DVD Backup, you own the most efficient way to create backup copies of your DVD movie collection. These working copies allow you to play your DVDs on your computer hard disk without the need of any DVD players.This DVD to computer backup solution avoids the inevitable risk of getting your originals of your DVD movie discs scratched or damaged. You get disc protection with no loss of playback quality.Any DVD Backup is free software. You should never pay for Any DVD Backup.
hope this helps
Apr 26, 2011 | CD & DVD Burners
Dvd-r support on matshita ujda 730?
Apparently this model is only a CD writer/DVD-rom combo drive meaning it can read and write CD's ok but will only read DVD's not write them
Mar 30, 2010 | Panasonic UJDA730 CD-RW/DVD-ROM (Combo)...
I had this problem for about 5 months my lg dvd rom dint read dvds . i installed ffirmware and tried to update it but there was erreor and now dvd drive doesnt even work. no green blinking light. when i...
This is the inherent risk in updating firmware to optical drives.
Buy a new drive, power down the PC, install it and reboot the PC. If it is and IDE drive, or a SATA for that matter, before you buy a new drive make sure to disconnect and reconnect both ends of the cable prior to replacing it, just to be sure it wasn't an accidentally dislodged cable causing the problem.
Dec 28, 2009 | LG GCC4522B CD-RW/DVD-ROM Combo Drive
LG cd-rom crd 8482b Doesnt Read Dvd's
well if its new i would say return it, if not then i would suggest to use canned air and blow out the inside of it and try it again. if that don't work then i would recommend getting a new one.
Dec 04, 2009 | CD & DVD Burners
I can burn cd's but not dvd's
Hello Rfd832,
What I see from the description is that the drive is a combo drive. Combo drives are CD-RW and DVD-ROM drives means
CD-RW = Compact Disk-Read Write
DVD-ROM = Digital Versatile Disk - Read Only Memory
so these drives can read and write CDs but can only read DVDs (Cannot write or burn DVDs)
If you want to be able to burn DVDs then you need to have DVD RW drive (either DVD+RW or DVD-RW)
You said that you are able to burn DVDs on other computer so please check the label on the DVD drive.. it should be DVD-RW/DVD+RW drive
Hope that helps.. :)
Thanks and Regards,
Apr 12, 2009 | HP (dc197x) CD-RW/DVD-ROM Combo Drive
CD/DVD Rom suddenly not reading DVDs. I had iTunes installed and had deleted these files. Any connection and how do I fix my DVD player BA
DVDs demand a much higher precision to read a disk than do CDs and when they go down the tubes, the DVD is the first place it will show up. You can try using a cleaning disk but this is often not successful.
Mar 06, 2009 | HP (346789-001) CD-RW/DVD-ROM Combo Drive
Playing PC DVD roms problem
Dvd drives can read from both DVD and CD however due to technological limitations most DVD-ROM or RAM read up to slightly higher speeds for CDs than DVDs.
When burning DVDs professional companies that make prerecorded disks burn their disk at low speeds in an effort to achieve both compatibility and low errors, that is the reason their DVDs play on most DVD-ROMs. However DVDs me and you burn at home and work at high speeds are prone to errors and incompatibility with low reading speed drives.
As a result if your DVD-ROM has a low maximum reading speed then it can only read those prerecorded DVDs and only DVDs recorded at low speeds provided thre are not scratched.
I believe you managed to read those DVD movies if they were pre recorded.
Nov 29, 2007 | LG (GCC-4522BI) CD-RW/DVD-ROM (Combo)...
My dvdrom drive wont let me access the drive
ITs a dvd rom drive. It will not burn blank dvds
in order to burn, it has to cd-r/cd-rw/dvd-r/dvd-rw. If a drive cannot write to a blank disc, it will eject it. Rom drives read only (Read Only Memory), Combo drives- burn cd's only read dvd's, and super drives both read and write to cds and dvds.
Oct 23, 2007 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Reads all but DVD-Help PLEASE
When you say it won?t read are you trying to play commercial DVD movies or read DVD data disks? If you're trying to play movies then you need a couple of things the first being some type of player program. Real player works as does Windows media player but usually DVD drives come with a striped down version of PowerDVD or WinDVD. If you in fact have a player installed and when a DVD is inserted in your drive it doesn't play it may not be configured to automatically play DVDs. Try opening your player program and trying to manually play your DVD. Let us know if you have any success or if you need more assisted. If you do let us know what player program and operating system you have and any error messages that may appear.
Jan 01, 2007 | LG GCC 4320B CD-RW/DVD-ROM Burner
CD & DVD Burners Logo
445 people viewed this question
Top Panasonic CD & DVD Burners Experts
Brian Sullivan
Brian Sullivan
Gareth Cockram
Gareth Cockram
Jonathan Dator
Are you a Panasonic CD and DVD Burner Expert? Answer questions, earn points and help others
