Question about D-Link Dlink DI-514 Air Wireless 2.4 GHz Router (A0177337)
I have a macbook pro and the installation disk spins in the drive but that's all and then, it spits it out! I can't run the setup wizard.
  • 2,260 Answers
Are you trying to set up the router ?
Is there any other computer online ?
Or this the new set up. If your router is already set up then you don't need to run the disc to set up the router again. You just need to connect to network.
If you want to set up the router , you can do it without the CD also.
You can set up the router manually.
Click Here for more info about router set up
Posted on Nov 19, 2009
Copy windows 7 and apps to Parallels desktop
First you create bootable windows disk, and then you try it. Bootable Disk insert to DVD rom drive and follow instruction on setup.
More info please visit this link.
http://www.lgsolutions.com/ftgsoftware/downloads/Windows_XP_Installation_Guide.pdf
Thanks,
Apple Support
May 30, 2014 | Apple MacBook Pro Mac Desktop
My Macbook Pro running Mountain Lion does not recognise My Lacie D2 Quadra V2 (301442a) after upgrade from Snow leopard
Here's a good start.
Plug your Lacie drive into someone else Mac or PC using MacDrive Pro and see if it shows up.
Dec 02, 2017 | Computers & Internet
Lost install disk for Mac book pro My 13" Mac book
You will need some install disks to even begin working on your issue.
Your options:
  • Find someone with the same model MacBook Pro and borrow the disks.
  • Buy a copy of Leopard (10.5) or Snow Leopard (10.6) and use them. If you are going to buy a set you might as well update to Snow Leopard (10.6)
  • Check eBay for install disks but make sure they are for the same model MacBook Pro.
  • Contact an Apple service center and purchase a replacement set of install disks.
Once you have a install CD, I would recommend backing up your system by making a disk image of the hard drive to an external drive. Then doing a clean install and then using the Migration Assistant to restore your user files to the clean install on your hard drive.
Apr 23, 2011 | Apple Computers & Internet
Mac laptop screen froze with message stating must turn off laptop
font.f1 { font: 12px Helvetica; } Thanks for asking your question with Fixya Support. I will be glad to assist you.
What you are experiencing is what is called a Kernel Panic.
A Kernel Panic, is a internal fatal error, detected by your system from which it
cannot recover from safely. Such an error can be the result of a software
function or operation failing to execute as it normally does, or halting without
warning, or even a hardware component, suddenly ceasing to operating
or simply shutting down. In either scenario, the system will display the frozen
black and white screen with the languages text listed.
Normally a simple reboot of your Macbook Pro will resolve the issue, but in some cases it can take a specific procedure to correct and prevent a kernel panic from occurring again.
So here are a few procedures you can use to resolve and prevent further kernel panics:
• First, hold in your power button for approximately 10 seconds to do a hard shutdown, if your Macbook Pro is still turned on.
• Once your Mac is shutdown, you will need to perform what is called a PRAM reset (Parameter RAM)
• Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously .
• Turn on the Macbook Pro.
• Press and hold the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
• Now, hold the keys down until the computer restarts and you hear the start up sound for the third time.
• Release the keys and allow the Macbook Pro to start up.
If your Macbook Pro starts up normally and does not go into another kernel panic, then you should be able to resume normal session activity on your Macbook Pro.
However, should the kernel panic return, then you can use an SMC Reset to correct the kernel panic:
-SMC RESET-
The System Management Controller is an integrated circuit (computer chip) that is usually on the logic board of your Mac portable.
It is responsible for power management of the computer. It controls back-lighting, hard disk spin down, sleep and wake, some charging aspects, trackpad control, and some input/output as it relates to the computer sleeping.
Shut down the computer.
• Disconnect the MagSafe power adapter from the computer, if it's connected.
• Remove the battery.
• Press and hold the power button for 5 seconds.
• Release the power button.
• Reconnect the battery and MagSafe power adapter.
• Press the power button to turn on the computer.
Once again, when you are back up to your main desktop, resume your normal session activity.
At this point there should be no further issue a the kernel panic rearing its ugly head once again.
If it does, then you will need to take more intensive steps such as inserting your Mac OS X installation disc and booting up to that disc and running Mac OS X's Disk Utility, to repair the hard drive and permissions of the Mac OS X system you are using.
I will leave you with that procedure, in the event you need to run Disk Utility:
Insert your Mac OS X Startup disk
•Reboot your Mac
•At the Apple Chime, press the C key and hold it until you see a White screen, gray Apple and eventually a Spinning gear.
• Release the C key only after you see the Spinning gear.
•Mac will boot from the start up disk to the Installer environment
• From the Installer Menu bar, click Utilities > Disk Utility and open up Disk Utility application.
• Click on on the hard drive at the top of the window in the left sidebar and
• Select "Repair Disk"
**Let Disk Utilities run this repair the disk until completion
• At the end of this process, reboot your Macbook Pro
Return back to you main desktop and again, resume your normal session activities.
Any more kernel panics after this, you may want to consider taking your Macbook Pro in for service at your local Apple retail store Genius Bar or local Apple authorized service provide in your area.
I hope this information proves helpful for you.
Regards,
-Mactechtrainer
Mar 30, 2011 | Apple Mac Book Pro 15.4" 2.53 Core2Duo 4GB...
Hi My laptop "MacBook Pro" first
First insert the CD you wish to boot to. Then let the mac start up all the way. Go to system preferences, then click startup disk. From there select the drive you wish to boot to. then select restart, and it will restart to that disk or CD.
Jan 28, 2011 | Apple MacBook Pro A1189 17
My macbook pro desktop icons are gone! and the spinning wheel keeps going. Any ideas
Your hard drive might be failing.
If you have the original install discs that came with your computer, insert disc 1 into your computer. Then turn off your computer and then turn it back on again while holding down the Option (alt) key and double click on the CD icon that pops up. Then when the computer boots from the DVD, click on Utilities and the open up the Disk Utility application. Run "Repair Disk" with your internal hard-drive selected. If this program cannot fix your problem, you may need to invest in purchasing a new hard drive and replacing the one in your computer.
Dec 27, 2010 | Apple MacBook Pro Laptop Computer with...
Mac won't boot up. it spins and spins but never finished booting. it started after the mac accidentally lost power after a startup, before it was done booting. how can i bypass this and get to...
Two possible things are wrong either your hard drive has gone or your system has corrupted.
If your system is corrupted put your instal disk in start it up holding down the c key. Once it has started check that the hard drive exists by go to the menu bar and selecting the disk utility. If the hard drive shows it means that it is okay so run the disk utility check drive and then run the repair permissions. Then try restarting, if it works then you are back up and running again. If the drive shows up and you restart and the same thing shows up, you will need to reinstal your system. You do this by starting up with the instal disk holding down the c key and run the instal script. To keep your hard drive contents your will need to use the preserve users instal.
If your hard drive does not show up the hard drive is probably a gonner and you will have to purchase a new hard drive and then instal a fresh system.
Hope this helps
Sep 06, 2010 | Apple MacBook Pro Notebook
My MacBook Pro goes to the grey screen with the
Most likely, you are looking at a corrupt installation of the OS, or a failing hard drive... most likely the latter, unfortunately. Laptop hard drives only seem to last a couple years now, 3-4 if you're really lucky. I would suggest popping in the System Restore Disc (that came with the computer originally) or the OS install disc (in case it has a new version installed than it came with originally) and go to Tools->Disk Utility, and tell it to "repair permissions" and "repair disk", and see if that resolves it. If it happens to, I suggest backing up your data ASAP just in case. More info can be found here on using Disk Utility.
Nov 11, 2009 | Apple MacBook Pro Laptop Computer with...
My macbook wont eject the disk in the disk drive.
Turn on your Macbook while holding touchpad button and hold until cdrom spits out cd.
Sep 04, 2009 | Apple MacBook Mac Notebook
D-Link Dlink DI-514 Air Wireless 2.4 GHz Router (A0177337) Logo
74 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
