Question about Sanyo Televison & Video
My Sanyo HT 30746 keeps turning itself off right after I turn it on.
  • Sanyo Master
  • 19,396 Answers
Hi.
Your Sanyo went in stand by and does not wake up because an internal fault had been detected, and now the TV is in protect mode.
If after the fault the TV went in standby and does not wake up, then the TV has on protect mode after detecting a fault.
When this happens higher voltages are shut down to prevent further damage.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or DVD connected.
If that does not work, and you keep having a led on (sometimes flashing) in front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The led light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1 The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or a broken contact, identified an internal fault and kicked in , starting the standby fault mode.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Regards.
Posted on Nov 22, 2009
Samsung home theatre ht-e6750w keeps turning itself down
If by turning itself down you are referring to the volume I had the same thing happen to my HT-E6730W a few months ago. I believe I did a reset and the problem went away. The only other thing I could think of was to take the batteries out of the remote and see if the problem continued to rule that out.
Jul 02, 2015 | Samsung Audio Players & Recorders
Sanyo tv keeps turning itself off any ideas?
You probably have blown capacitors on the PSB-power supply board. Recaping with new UF caps works 90% of the time. The set turns itself of into a fault protection to keep from damaging more components internally. A few bucks a soldering iron some solder should do the trick.
hope it will help you. -monchi
Oct 17, 2011 | Sanyo Televison & Video
Sanyo PLV 60 HT keeps on overheating even after I cleaned the
hi dear plz check the projectors fan. It is working properly or not
Jan 31, 2010 | Sanyo PLV 60HT Multimedia Projector
My sanyo vpcs1080bl turn itself off when powering on
Maybe the battery is dead. change the right battery
Jun 20, 2009 | Sanyo Xacti VPC-T700 Digital Camera
Keeping the settings permanent
Hello, are you making the changes in the speaker settings section in programming? Thank you, CB
May 24, 2017 | Onkyo HT-S670 System
System turns off by itself
My unit said "protection", "goodbye" so I opened it up and found a capacitor to one of the speakers had blown, right by the fan. It's a 35 cent part and a simple solder job. The hardest part was getting the face plate off the dvd tray so I could get to the circuit board.
Apr 01, 2008 | Samsung HT-WX70 Theater System
No power
It sounds like you have a problem in the set's power supply or high voltage section and the set is protecting itself from turning on. Unfortunately, you'll need to take it to be serviced.
Please let me know if I can be of further assistance to you.
- Jim
Feb 14, 2008 | Sanyo HT32744 32" TV
Televison & Video Logo
173 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
