Question about Hitachi GD 7500 Internal DVD Drive
Reads cd's fine won't read dvds
The drive is reading cd's fine, but not dvd's. When I open My Computer it's recognized as a CD drive not a dvd drive. The only dvd drive that shows is my virtual. I went to hitachi to download lasted driver/firmware but when I try to install I get error message. The NTVDM CPU has encountered an illegal instruction. CS:0dd 1 IP:012d OP:63 65 44 72 69
Any help I'd be stoked
My CD/DVD drive won't read/play DVDs and it won't write DVDs either. It used to do this fine, but it doesn't anymore. It will still play and write CDs, but not DVDs. I have tried EVERYTHING to...
You probably will need to replace the optical drive (CD/DVD drive) in your laptop. Go to Google and search for "Dell Inspirion 6000 CD/DVD drive" to find a replacement.
To be sure it's the CD/DVD drive that's defective and not your operating system software, you could also try to boot from a boot-able DVD disk.
Jun 23, 2011 | Dell Inspiron 6000 Notebook
Hello i have sony AD-7240S cd/dvd drive it can read all cd/dvds but it cant read my burnt cd/dvds plz give me suggestion
there is something wrong with the format of the files that you burnt. its either the format is not recognized by your dvd player or the format is not supposed to be burnt.try reading every details whenever you're burning a file to a cd/dvd. at the same time, check the specifications of your dvd player and find out the formats that it can read or recognize so that you'd know what format should you burn a file into.
Apr 10, 2011 | Computers & Internet
Dvd icon is shown but does not reads CD/DVD
If you have CD-DVD burning software uninstall it and restart the computer.Open this link and click on run now http://support.microsoft.com/kb/929461
Restart computer again and check
Jul 29, 2010 | Samsung SHS223B DVD±RW Burner
Dvd burner drive E:\
Are you absoulutely positive that yours is a dvd burner as well as a cd player?? Not being a wise guy, I am serious, sometimes it can be something simple...Steve
Jun 13, 2009 | Dell (M6790) DVD RW Burner
Can operate with CD ROM's. Won't recognize DVD's.
Sounds like the drive could be going bad. The way the laser reads DVDs vs. CDs is different, that is why you are able to read one, not the other. I had this happen to me, except the opposite. It could read DVDs, not CDs. Had to buy a new one, and all is well.
Apr 22, 2009 | Pacific Digital Mach 16x8x16x Double-Layer...
I can burn cd's but not dvd's
Hello Rfd832,
What I see from the description is that the drive is a combo drive. Combo drives are CD-RW and DVD-ROM drives means
CD-RW = Compact Disk-Read Write
DVD-ROM = Digital Versatile Disk - Read Only Memory
so these drives can read and write CDs but can only read DVDs (Cannot write or burn DVDs)
If you want to be able to burn DVDs then you need to have DVD RW drive (either DVD+RW or DVD-RW)
You said that you are able to burn DVDs on other computer so please check the label on the DVD drive.. it should be DVD-RW/DVD+RW drive
Hope that helps.. :)
Thanks and Regards,
Srinivas
Apr 12, 2009 | HP (dc197x) CD-RW/DVD-ROM Combo Drive
Dvd drive will read/play dvds but will not recognize a cd
go to safemode and try reading CDs in safemode. If your burner still can't read CDs then it's most likely bad. You could get an external usb burner.
Mar 18, 2009 | HP Pavilion dv4000 Notebook
LG GCA-4080N internal drive
It seems that what you have is a combo drive only :(
it only recognize DVD reading. no matter what driver you used. need to buy a dvd writer/ that said can write dvd.
Types of Optical Drives and CD/DVDs
Optical drive type Read from CD/DVD-ROM media Write to CDRW media Write to DVD ±RW/R media Write to DVD +R DL media Write label to LightScribe CD-RW Write to DVD-RAM media DVD-ROM Drive Yes No No No No No DVD and CD-RW Combo Drive Yes Yes No No No No DVD±RW/R and CD-RW Combo Drive with Double- Layer support Yes Yes Yes Yes No Yes LightScribe DVD±RW/R and CD-RW Combo Drive with Double- Layer support Yes Yes Yes Yes Yes Yes Blu-Ray Disc DVD±RW SuperMulti Drive with Double-Layer support Yes Yes* Yes Yes No Yes *Low speed (4X) and high speed (4-12X) are supported. UHS-RW (24X and 32X CD-RW) is not supported.
NOTE: Some of the optical drives listed may not be supported by your computer. The listed drives are not necessarily all of the supported optical drives.
Dec 26, 2008 | LG (GCC4521BBULK) CD-RW/DVD-ROM (Combo)...
My lg GSA-H55N dvd writer is not playing Cds but plays Dvds fine
Try and find the latest drivers for your drive.
Hope this helps! :)
Nov 23, 2008 | LG GSA-H55N DVD-RAM Burner
Cdrom not reading all disk
Not to worry i was also facing problems like this ...just clean the lens with a len cleaner....and see it will start reading after that
Jun 03, 2008 | Dell (5X840) CD-RW/DVD-ROM (Combo) Burner
Hitachi GD 7500 Internal DVD Drive Logo
77 people viewed this question
Top Hitachi Computers & Internet Experts
Ekse
Alun Cox
Marvin
Marvin
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
