Question about Cuisinart DGB-500 Coffee Maker
My coffee tastes terrible. Do I need a new filter and what filter number do I use for the DGB-500 BK cusinart model
Noggin
  • 944 Answers
SOURCE: Suddenly coffee tastes TERRIBLE!!!
First try putting a cycle through with no coffee - see if you have any more luck identifying the taste. If you haven't descaled recently, that could be the cause - scale can hold other materials which can be tasted - run a cycle with 50% white vinegar, then rinse through a couple of times and see what you get - if you need to get rid of any vinegar taste, just run a cycle with a couple of teaspoons of bicarbonate of soda through. The water could still be to blame - even purified, there are certain things that can change that most purifying methods will not remove, such as higher salt levels during summer months etc. Make a cup of coffee without the machine at all, and see if you get the same aftertaste. The machine may not be to blame. Hope this helps, please ask again if you need more info :)
Posted on Sep 10, 2007
SOURCE: Cuisinart DGB-500 Filter basket opens during brewing process
broken basket.
Posted on Jan 04, 2008
  • 125 Answers
SOURCE: Bad tasting coffee
Hello. Usually bad taste is one of 3 things, water quality, coffee quality is changed, or brew temp is different. Try removing all the water, by tilting the unit over the sink, unplug please, so the end where the funnel would go is draining the water into the sink, go slowly. Once all the water is removed, refill it with fresh water until it comes out the spray head/funnel area again, plug back in, heat and test. Now there could still be residue in the tank, and it may require doing this a couple of times to clear fully. Try another coffee, may have just had a bad can/bag/etc..
Last, take the temp of the water coming out of the funnel, should be about 180 deg. F, if not it could be too cool, and needs a thermostat or element. If you need a service provider, go to www.bunnomatic.com and locate a service near you.
Hope that helps, and thank you.
Posted on Apr 11, 2009
  • 1833 Answers
SOURCE: i bought a cusinart dgb
What is the problem you have faced exactly with your coffee machine? If you can't turn it on then check the power cable and your electric outlet and also check that you have plugged it properly. If the machine get turn on but you can't brew a coffee then remove the infuser and thoroughly clean it. Then Repeat the operation using a maximum of 1 measure of ground coffee. May be the holes in the spouts are clogged. Scrape the holes with a needle. Make clean the brewer. And also Descale the machine. If it doesn't solve your problem then you have to repair your brewer.
Posted on Jun 01, 2011
mc1bean
  • 3053 Answers
SOURCE: no matter how much water
Hello, treasuremanI was trying to help you out here. Maybe this will help some? I was going backto some customers that asked questions in the recent past and even fartherback. It appeared that no one answeredsome of them, So, I thought I would take some of my personal time to see if Ican help. Even though this Informational site may not have your exact model orbrand, this site will help you a lot. Here is a site link about everything you want to know about CoffeeMakers and possibly yours, from repair to trouble shooting it. b>http://home.howstuffworks.com/coffee-maker4.htm
Please if this helped you at all, if you can find the time and in your heart torate my help and some kind words written would be appreciated for my free help, I would appreciate it.
Here is also my direct link to my own pages of other areas of my expertise forother problems you might have in Automotive, Appliance, and Electronics. DropIn anytime for my help.
Thanks, Mike
http://beta.fixya.com/users/mc1bean
Posted on Oct 29, 2011
I donated a new Platinum B70 Brewer for use by our church staff. The tap water tastes terrible and ruins the coffee flavor!
and bench top or under bench water filter in the water supply line to the unit will work
best filters to consider are one ceramic ( removes particles to a measurement of less than 1/2 micron and one carbon filter that removes all taste problems
Aug 18, 2017 | Keurig Coffee Makers & Espresso Machines
No matter how much water or beans I put in coffee is week I push the 1-4 cup an leave light on still weak Cuisanart coffee grinder & maker Model # DGB 500 BK
Thanks, Mike
Sep 09, 2011 | Cuisinart DGB-500 Coffee Maker
Will the coffee maker work without the charcoal water filter?
Yes, the coffee maker will still work... the charcoal filter is just there to help make the coffee taste better...with most waters it does not matter...high chlorine content water is where it makes the most difference..
heatman101
Aug 05, 2010 | Cuisinart DGB-600BC 10-Cup Coffee Maker
DGB 500 Grinder
You may try opening the front cover first and removing the filter then after opening the top lid, remove the clear grinder cover and lift the grinder from the rear. After you get it out be sure to clean the motor drive shaft and the bottom of the grinder. then use a trace of vegetable oil to lubricate the motor shaft where is attaches to the grinder.
We are on our second coffee maker and it makes great coffee.
Jan 19, 2009 | Cuisinart DGB-500 Coffee Maker
Won't start
DGB-300 - continuously beeping indicates that something is out of place - either the grind basket isn't exactly in place, the filter basket is loose, the water filter holder is out of place, or the lid of the coffee maker is open.
-Tha Mp3 Doctor
Jun 23, 2008 | Cuisinart DGB-500 Coffee Maker
Beeps constantly
The machine will not run if the covers /for the coffee grinder, the filter basket and the machine itself) are not properly closed.
It will beep and stop running if it is turned on when one of the covers is open or if one is opened before the end of the cycle. The beeping will stop as soon as the cover is closed.
To start the machine again, press the ON button.
These instructions are to a DGB600 but i think it is the same to your model.
May 24, 2008 | Cuisinart DGB-500 Coffee Maker
Cuisnart DGB-500 shuts off before coffee brewing is complete.
I had the same problem. I ran it about 5 times with vinegar / water solution. A lot of hard water deposits (solids) showed up in the filter! The coffee maker now runs all the way to completion!
As a note, I live in an area with extremely hard water.
Apr 11, 2008 | Cuisinart DGB-500 Coffee Maker
Sep 09, 2007 | Cuisinart DGB-600 Coffee Maker
Cuisinart DGB-500 Coffee Maker Logo
57 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
