Hi I have an NEC Split Air Conditioner. Model RIH6867. Power rating - 6.8Kw Cooling Capacity 8.2Kw Heating Capacity. Single Phase for 240Volt environment. I only have the outdoor unit. It is new. But missing the complete indoor assembly unit and remote. Can I substitute other indoor units to make this work. NEC no-longer supports their appliance division. Regards Ash
  • Ash Nov 19, 2009
    Thanks for your reply.
    I sort of gathered they all work under the same principal and use the same copper pipes. However, what I wasn't sure about is how the different electronic boards within the indoor units control the valves and if there are any differences in them.
    Regards
    Ash
  • Ash Nov 19, 2009
    The other problem I have is that I can not find an indoor unit with exactly 6.8KW cooling and 8.2KW heating.
    Also the Amps are slightly varied between the different models.
    Regards
    Ash
  • 905 Answers
Hi Ash,
Off the cuff, I would say no to being able to use any other indoor unit.
But, with a bit of work and research, you might be able to connect 2 systems, even if different manufacturers, together. The compressor / condenser, etc (outdoor unit) doesn't really depend on indoor unit in order to do its job. As long as the cooling capacity are matched between the two, the outdoor unit should function problem free.
Your unit is going to be a bit different though. Your compressor is a variable speed compressor (higher efficiency). The inverter is located inside the outdoor unit, but the controls are located inside the indoor unit. You *might* be able to remove the inverter completely and lose some efficiency. Once you start going down this path, you will quickly find that it would be cheaper to buy another unit altogether, rather than to keep paying for labor to modify, and additional / parts needed. This approach may be worthwhile if you already have an evaporator that is ready to go, and is appropriately matched as far as capacity.
May I suggest that you check with the hotels and motels that are in your area. These have been used in such places in the past, they are quite popular for retrofits where a large window was not in place, or appropriate. Maintenance departments typically keep a few units on hand for spare parts and such. I don't know how popular your model is, but it is worth a shot.
I did find some information that might help:
Spare parts are available here, shipping may be outrageous.
http://aware.awa.com.au/parts/NEC/AC/RIH-6867-OUT/index.html
At the very least, you should be able to get part numbers for what you need.
Posted on Nov 19, 2009
    President:
  • 1,865 Answers
Split A/C systems all work the same. The outside unit can be connected to any inside unit. You'll have to make sure they have similar ratings
Error code e6 what does that mean air conditioner will not start
DeLonghi CF210 Portable Air Conditioner Error code e6 ...
www.fixya.com > ... > DeLonghi CF210 Portable Air Conditioner
DeLonghi CF210 Portable Air Conditioner, error code e6 related issues. Get free help, solutions & advice from top DeLonghi experts.
Error e6 displaying on single split model one - Fixya
www.fixya.com/.../t4492271-error_e6_displaying_single_split_model
Apr 5, 2010 - Question about DeLonghi CF210 Portable Air Conditioner ... then the code error display E6 and the error code is Communication malfunction.
DeLonghi fix e6 error Air Conditioners Questions & Answers ...
www.fixya.com > Forum > Tags > fix e6 error > Air Conditioners
DeLonghi air conditioners fix e6 error related questions and answers. ... DelonghiFX400eco error code I Have the above air con unit 18 months old the cooling ...
DeLonghi CF210 Portable Air Conditioner Error code e6 split
Jan 01, 2016 | DeLonghi Heating & Cooling
The control card is displaying error ch-01
PDF]SERVICE MANUAL R?410A Ductless Split System Air ...
dms.hvacpartners.com/docs/1011/Public/.../42108920400_ICP_26610.p...
421 01 9204 00 1/03/13. SERVICE MANUAL ... Consult local building codes and National Electrical Code. (NEC) for special ..... 18000 (5970-22350). Heating Capacity (Min. - Max). Btu/h. N/A ..... Error Messages Displayed Front Panel. S.
Oct 08, 2015 | LG 18000 BTU Dual Zone Mini-Split Heat...
What is m6x06f2a btu output?
Features
  • Cooling Capacity (BTU) : 6,000 BTU
  • Maximum Cooling Amps : 5.6 Amps
  • Maximum Cooling Watts : 618 Watts
  • Heating Capacity (BTU) : 0 BTU
  • Maximum Heating Amps : 0 Amps
  • Energy Efficiency Rating : 9.7
  • PTAC : No
  • Window Type :Standard
Aug 04, 2015 | Maytag M6Q10F2A Air Conditioner
Wiring diagram for circuit breaker IEC 61009-1 to main supply
Copy following link:
http://waterheatertimer.org/See-inside-main-breaker-box.html
Illustrations include 120Volt single-phase, and split-phase 240Volt..
Mains supply is only split-phase 230volt.
Nov 21, 2012 | Electrical Supplies
I don't have a problem with my product...im trying to find out how many watts do my product use. Model #uamb-036jaz serial #6263f040410617
Brand: RUUD Manufacturer: RHEEM Model Number: UAMB-036J* Condenser Type: air-cooled Condenser Coil Model Number: RCGA-36A2 System Configuration: split-system air conditioner Cooling Capacity: 34,200 BTUHs per hour Efficiency: 12 SEER
10.5 EER Electrical Service: Single-phase Electrical Input: 3,272 watts per hour Voltage: 230 and 208
Jul 01, 2011 | Ruud UAMB Air Conditioner
Good afternoon, I have a Pioneer Air Conditioner with the following specifications: PD Wall mounted split, Model number: WAXO13GBA-L, Power supply: 208-230V/1Ph/60Hz, Input power: 1,300 W, Rated...
You contact the manufacturer and they will refer you to an authorized repair station in your area. Just get a price up front for the part and labor, if any, so you can make a decision regarding the matter.
Mar 21, 2017 | Heating & Cooling
Need to know the tonnage ofCarrier s/s Model #38ARZ008, ser # 1404G20031
Brand: CARRIER Manufacturer: CARRIER CORP SYRACUSE Model Number: 38ARZ008(5/6)0 Condenser Type: air-cooled Coil Model Number: 40RM-008--B5/6GC System Configuration: Split System Air Conditioner Energy Efficiency: 10.6 EER Cooling Capacity: 90,000 BTUs / hour ARI Type Code: RCU-A-CB Electrical Service: Triple-phase Electrical Input: 8,490 watts per hour Voltage: 230 and 208 and 460
12000 btu's per Ton, equals to 7.5 Tons.
Sep 29, 2010 | Carrier 38CKC042 Air Conditioner
I am looking for how many tons of cooling my goodman condensor provides
  • Here's the data you requested:
  • Goodman CKL42AR42 Split System Air Conditioner
  • Type: Split System
  • Cooling Capacity: 40000 BTU/hr (3.3 tons)
  • Energy Efficiency Rating: 9 EER
Mar 19, 2010 | Goodman CKL42AR42 Air Conditioner
Require specifications for an Emailair split level air con model CWS 034A
Capacity which normaly known as Horse Power
or RA rating
The voltage input
Ampere ratings
voltage phase ex. (single phase or three phase)
Type: Split type
since it is split type there are several classification(wall mounted, foor mounted or ceiling mounted)
Oct 31, 2009 | Heating & Cooling
Carrier multi hi wall split a/c
I don't have a diagram, but maybe I can help you. You have 2 compressors, o.k. 2 stage system. A single phase contactor? do you mean a single pole, one side breaks, the other is always hot? Speaking of phases, is this a commercial unit with 3 phase? Also, Each compressor needs a separate contactor to carry the load. What is the question?
Dec 22, 2007 | Carrier 38CKC036 Air Conditioner
Heating & Cooling Logo
55 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
