Question about Samsung CLX 3160fn All-In-One Printer
Fax device I/O error
I have window XP, installed the Samsung CLX-3160 as a network printer with IP address 192.168.1.192. It prints ok. But when I try to fax from my computer by using smarthru, I got Fax device I/O error. Tried several computers, the same error message.
  • 1 more comment
  • Anonymous Mar 09, 2008
    fax devixe i/o error when using smarthro to fax through computer
  • Anonymous Jul 28, 2008
    when turning the printer on an internal error wer/on/off and a fm_list.c 311 ro code
  • Don Amorphus Feb 02, 2009
    What the ****, how to solve this hell ******* ****? What a hell, a ******* thousand and a half and this **** broaks in a funcking month!
Installed samsung scx-4521f multi function printer. can't fax from smarThru program. get message : Fax device I/O error
Posted on Sep 18, 2008
Go to Smarthru by the icon and check the ip adress. Search for your printer in the network. The select your printer an click ok.
This should help
Posted on Mar 26, 2009
    New Friend:
Fax device i/o error Samsung
Go to devices and printers in the Control Panel.
Right Click and choose Printer Properties.
Click on the Ports Tab
With the Network PC port ticked and highlighted click on Configure Port.
Change "spot" from Local printer to Network and click Browse.
Click on Auto Detection and this will find your printer. Select your printer then Close (there is no save button).
You can now print wirelessly again J
Posted on Nov 21, 2012
  • cthobbs586
    cthobbs586 Nov 21, 2012
    Fax device i/o
    error Samsung
    Port.
    Browse.
  • 18 Answers
You have to have it installed as a network printer. I also use smarthru to find the device then scan. I have used the control panel on the printer to find my PC and scan to it from the control panel. It works fine.
Posted on Aug 18, 2008
  • henryher Aug 20, 2008
    vnixx is right about the scanner. SmartThru will scan and copy through the USB only as far as I can tell. But the fax from PC does have an option to fax to Network device. I have not tried it but it probably works.
Installed samsung multi function printer. it will not fax from smarThru icon. Message comes up fax device I/O error.
Same thing I had, OPEN UP the SMartthru from the ICON, goto settings, scan for the network device, Pick the one it finds, and close.
Bada bing it works, stupid programers.. If I didnt know what I was doin, it wouldnt have it working either, But it does work over the network unlike what the dumb guy said.
Posted on Jul 08, 2008
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 70 Answers
Smarthru software operates only with local port-USB. It cannot works when you are using thru network.That's why it shows Fax device I/O error.
Posted on Mar 14, 2008
  • Lawrence Singapore Mar 14, 2008
6ya staff
SOURCE:
Samsung CLX-3180 - Fax device I/O error
Sep 05, 2012 | Samsung Office Equipment & Supplies
I have a new samsung printer all in one clx 3180 fn, i installed her in my pc's through the installation cd and made the printing test over the network (wlan) everyting was ok. then i tried to scan a...
you need to delet the printer software from your computer and install it again, then it should work, if not download the driver's from samsung download page.
Apr 20, 2011 | Samsung CLX-3160 All-In-One Laser Printer
SPL-C ERROR with Samsung CLX-3160 FN when printing from iMac
This can be fixed by stretching out a solenoid spring on the power cord side of the printer. The solenoid acts as a clutch to stop the spinning developer actuator at the right spot. The picture below is from a Samsung CLP-300 but these both use the same Imaging Unit so this should work. It's just a little more involved taking off the top scanner / buttonpad off the CLX-3160.
Open up the right side (power cord side) of the printer (take off top cover, then take off side cover). Then, find a solenoid (little metal square) that touches the white plastic vertical spur gear. Take the spring off the solenoid. Now, put the spring back on - only this time you will attach one anchor point to the middle of the spring as to pre-stretch the spring for more tension.
The problem is that the spring gets weak over time / the cogs round out over time and the solenoid finger is overcome by the spinning cogs, and resulting in selecting the wrong developer.
More pictures of the solenoid on Facebook:
http://www.facebook.com/#!/photo.php?pid=55779771&id=2257206&fbid=10100154259704133
Apr 21, 2010 | Samsung CLX 3160fn All-In-One Printer
Multi-function Samsung CLX-3175 doesn't scan to PC
I had the same issue with Windows 7 64 bit.I managed to solve it by doing the following
1. Locate the scan2pc.exe program in C:\Windows\twain_32\Samsung\CLX3170 2. Right-click/properties - Compatibility tab. 3.Set compatibility to win xp. Set "Run as Administrator"
I also added the scan2pc.exe to the firewall allowed programs (did that for scanmgr.exe as well, but I don't think I needed to).
Works great now!
Good luck!!
Mar 19, 2010 | Samsung CLX-3175FN Color Laser All-in-One...
I have a samsung clx-3160fn printer. All toners are ok, espcecially the black one - BUT when I print black&white doc, it is comign out really faded - as if the black toner is low. BUT it is not!! ...
Go to printer properties and check whether you have selected print in grey mode and also check whether you have selected the economic mode. Rectify the same will solve your problem.
Revert back for more assistance.
Jan 31, 2010 | Samsung CLX 3160fn All-In-One Printer
Vista cannot connect to xp printer
It sounds like your are using your Windows XP computer as the print server, and you are trying to connect your Windows Vista machine to the Windows XP print server. Your Vista machine is trying to download the XP drivers from the Windows XP computer to your Vista machine. This won't work. Windows XP and Vista print drivers are not compatible.
If the printer is truely networked (it has it's own IP address on the network, it has its own ethernet connection). Then instead of trying to map out to this shared printer, add new printer to the Vista machine using Vista drivers for the HP Deskjet 3940. The type of port you would need is a standard TCP/IP port. To get this address, print a settings page from the printer. Look for either a TCP/IP address or IP address on this print out. This is the port address you want to create and then connect to.
May 04, 2009 | HP Computers & Internet
Every application crashes
hi!!!
try to update your printer driver
here samsung
Sep 22, 2008 | Samsung CLX 3160fn All-In-One Printer
Printing from XP to a Brother 7820N as a networked printer
We have multiple 7820s in our office. This would be a configuration problem with your windows XP computer. From the XP computer, open a command prompt and type "ping x.x.x.x" where x.x.x.x is the ip address of the 7820n. Make sure you get four successes. I would then uninstall the brother software and drivers and go to "printers and faxes" in the control panel and manually add the printer.
To manually add a network printer, with it's own print server, on Win XP:
1 Click "Add Printer"
2 Select "Local Printer Attached to this computer"
3 Deselect "Automatically detect and install my Plug and Play printer" then click "Next"
4. Click "Create a new port" and select "Standard TCP/IP" from the drop down. Click "Next". this will open TCP/IP Wizard
5. Type in Printer IP Address next to IP Address (Port name will autopopulate) and click "Next"
6. If wizard finds printer, it will show you "Finish" button. If you get a "Additional Port Information Required" window, something is wrong with your printer or windows xp network configuration.
7. When the TCP Wizard window closes, it will take you back to Add Printer Wizard. Select "Have Disk" and navigate to the \USA\WXP\Addprt directory on your Brother Drivers disc.
8. Select brxpadd.inf and click "Open" then click "OK"
9. Select "Brother MFC 7820 N Printer" from the list and click "Next"
10. Select name of printer, whether you want a default, print test page and DONE!
Jun 12, 2008 | Brother MFC-7820N Printer
Networking a printer on a Netgear Router
Did you cofigure the IP address on the printer?You need to configure the IP address before add printer.
Mar 11, 2008 | Samsung CLX 3160fn All-In-One Printer
Samsung clx-3160 won't print
1) You need to configure the IP address on the printer to get it printed thru network.
2) Scanner Locked, there's a lock underneath the scanner bed,make sure it's fully released.
Feb 25, 2008 | Samsung CLX 3160fn All-In-One Printer
Samsung CLX 3160fn All-In-One Printer Logo
4,565 people viewed this question
Top Samsung Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Tareq Bin Mostaq...
Tareq Bin Mostaq...
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
