Question about Gateway Computers & Internet
My EV 500 monitor shows only 1/3 of the screen. A
My EV 500 monitor shows only 1/3 of the screen. A full picture but only 1/3 size. What to do?
  • 96 Answers
Update the latest driver to your graphics card with the latest it will remove bugs and, or give the proper data to make it function the way you want
Posted on Dec 13, 2009
Explain how the monitor buttons work
Monitor Icon Description of icon function moncont.gif Power - Turns the monitor on or off.
Brightness - Using this button or wheel the user can increase and decrease the brightness on the screen.
Contrast - Using this button or wheel can increase and decrease the amount of contrast on the screen.
Horizontal Size - Allows for the picture on the screen to be stretched to the horizontal edge of the monitor.
Vertical Size - Allows the picture on the screen to be stretched to the vertical edges of the monitor.
Horizontal Position - Allows the picture to move moved horizontally, once in the center the user can then use the Horizontal size to stretch it to have an equal amount of black border on each side.
Vertical Position - Like the Horizontal Position, using this button or wheel the user can move the picture up or down to center the picture more appropriately.
Full Screen - Sets monitor to full screen.
Degauss - This button will degauss the CRT, restoring possible color impurities. After this button has been pressed the degaussing circuit will be activated and then deactivated after a few seconds. Pressing and holding this button for a few seconds may cause your computer monitor to reset all data.
Corner and Trapezoid Correction - Using this button or wheel the user can either round the edges of the picture or move the picture inward like an hour glass or outwards.
Vertical Linearity - Sets the width of the vertical lines.
Moire - Removes or reduces the Moire effect, if any.
OSD Controls - If the monitor contains OSD controls, allows for the OSD menus to be adjusted.
Power Management - Allows the user to define the power management settings through the monitor itself and not the software.
Monitor Status - Displays the current monitor settings such as refresh rate and other settings.
Language - Sets the language on the monitor.
Aug 16, 2014 | Computers & Internet
Tip
Monitor buying tips you should know.
Over the years monitors have transformed from those bulky CRT monitors to square LCD screens to stylish flat wide screen LCD's and now to new stylish extremely thin LED screens. On average every PC user spends at least 5 hours a day looking at the monitor. If the picture is fuzzy and not clear enough then there is a very high possibility that the eyes get damaged.
An older CRT monitor
A wide LCD monitor
A newer ultra flat widescreen LED monitor
Monitor Sizes
There are many different sizes of CRT, square LCD, wide LCD and wide LED monitors available on the market at the moment.
If you want an older CRT screen then sizes can range between 14" to about 20", they use the 4:3 aspect ratio.
If you want an older LCD screen then sizes can range from 15" to 19", they also use the 4:3 aspect ratio.
If you want a newer wide screen LCD then sizes can range from 18.5" to about 27" and even larger. They use the 16:9 if they are full HD or 19:10 if they are not ratio.
If you want a newer wide screen LED then sizes can range from 18.5" to about 27" and even larger. They also use the 16:9 if they are full HD or 19:10 if they are not ratio.
Image quality
The sharpness of the image in a monitor greatly depends on your Graphics card as well as whatever resolution you are running at. Nevertheless the quality of the monitor plays an important role.
Here are some of the tips that you should know before buying a monitor.
1. There are three types of monitors namely CRT, LCD and LED. The monitor that looks like a TV is a CRT monitor. In CRT monitors there is a Cathode Ray Tube that shoots electrons into the screen to create the image. An LCD monitor is smaller in width and consumes less power and is healthier if you are going to be spending large amounts of time at your PC. The LED screen looks the same as an LED monitor and the difference between it and the LCD is that it has a much higher contrast ratio resulting in darker blacks and much lighter whites.
3. A CRT monitor is much heavier than LCD monitor as you can imagine by it's bulky appearance. A LCD monitor is very lightweight and so is a LED monitor.
4. The distance between two adjacent pixels in a monitor is called 'dot pitch'. This is measured in millimeters (mm). Smaller the dot pitch the clearer the picture quality. Usually there are monitors with dot pitch varying between 0.20 mm to 0.27mm. Some manufacturers use diagonal dot pitch while most of them use horizontal dotpitch. The diagonal dot pitch is always longer than the horizontal dot pitch
5. Resolution of a monitor has to be considered with care. Most of the CRT monitors have resolutions of 800×600, 1024×768 and 1280x1024. The square LCD monitors have 1280×1024 and 1600×1200 resolutions. Newer wide screen LCD monitors have resolutions of 1600x1900, 1680x1050 and the Full HD 1920x1090. When the resolution is higher the images and text will appear smaller. But you can see more text and bigger pictures in the monitor with high resolution.
6. Another thing to note is the 'Refresh rate'. This rate is usually 60Hz, 73Hz, 75Hz, 85Hz. Refresh rate of 85Hz means the picture on the monitor is refreshed 85 times within a second.
7. The brightness and contrast can range between a low 5 000:1 to a high 80 000:1 in a LCD monitor and an average of 5 000 000:1 in a LED, yes that's 5 million to 1 with a LED. This just shows how much better a LED monitor is to a LCD.
8. If you are a gamer then the thing you have to look at with LCD monitors and LED monitors is the response time. If it is 16ms then this is a very bad monitor for gaming and you will experience a ghosting effect in most games and if it is 5ms then you will have an average gaming experience. What you want to get is a 2ms response time monitor, with it you will have the best gaming experience with no ghosting what-so-ever.
on Mar 06, 2011 | Computers & Internet
Monitor showing way too dark
While there may be other components bad, your picture tube is most likely worn out. With age and use the electron guns get weak, and the dim screen is the result. There is no cure except to replace the tube, and that's completely uneconomical. A new LCD monitor is less than $100.
Jan 11, 2011 | Gateway EV 910 19" CRT Monitor
Problem with LG 700B
can u tell me alittle more of your issue,,
cos non flat screen would not just run half as its sync to all cant have 1 half without the other,,
can u see the whole screen just very small?
Sep 27, 2009 | LG Studioworks 700S 17" CRT Monitor
My EV 700 screen picture is condenced has one bright clear line in middle screen and two more lines faded,space in between lines
Sounds like a CRT problem but to be sure, hook up another monitor to the computer and if you get the same exact lines then you know its a problem with the video card, if the lines go away then you know its a problem with the monitor.
Jun 09, 2009 | Gateway EV 700 17" CRT Monitor
No showing the full screen. Top + bottom 1 and half inches dark
your system display settings are set to a wide screen setting on desk top right click then properties, right had tab display then set the screen size to a square shape like 1024 x 768.
Feb 16, 2009 | Dell E153FP 15" LCD Monitor
I cannot get my EZ PRO 500 CTX projector to show a full screen picture from an XP or Vista PC. I lose part of the left and bottom.
dous anybody know how mush these r worth,as i have 1 to sell,my e-mail address is cottageinn@live.co.uk its in a case with power lead and remote,its powers on-with picture...simon
Nov 19, 2008 | CTX Optoma EzPro 500 Multimedia Projector
Monitor Menu Settings
if you have hair dryer just give little bit of heat on the panel button and make sure your monitor is complete off. see if it help otherwise give for repairing. bye
Sep 25, 2007 | SAMTRON 55V 15" CRT Monitor
there is in the menu that calls for " RECALL ", press this to go to original setting, and change setting again to your choice, individually.
Sep 25, 2007 | ViewSonic G810 21" SuperClear CRT Monitor
LCD screen
The LCD screen is a 2.5-Inch High-Definition LCD. This 210,000-pixel high-definition semi-transmissive LCD monitor maximizes the advantages of both transmissive and reflective technologies to assure excellent visibility and high picture quality even when viewed in bright outdoor light.
Sep 01, 2005 | Olympus i:robe IR-500 Digital Camera
Computers & Internet Logo
56 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
