Question about Maytag Washing Machines
A unbalanced tub & making a clicking noise , everytime it goes to spin cycle it is unbalanced & I have to readjust the clothes again & again. The tub is leaning to the right at the end
  • 169 Answers
Needs new ballance ring. poss unlevel
Posted on Nov 19, 2009
Unbalanced load at nearly every spins cycle ,move clothes around until it spins
Is it a front load or top load? Do you have the make and model?
Jan 26, 2015 | Washing Machines
What could cause my washer to have a loud noise on the spinning cycle
Clothes are unbalanced need to readjust clothes then close lead.
Jul 24, 2014 | Whirlpool WTW4950XW Washer
Haier hlp23e jolting noise spin
You need to level it again. (the knobs on the bottom of it are threaded so you can adjust them to make them level, it can be time consuming, so it is best to start with the one that is shortest.
Mar 23, 2014 | Haier HLP23E Top Load Washer
GLEH1642DS1 FRONT LOAD STACKABLE WASHER MAKING LOUD THUMPING NOISE IN SPIN CYCLE & SQEALS WHEN i STOP IT
Sounds like you have an unbalanced load. I know this sounds too easy but lots of times this is the issue. If it doesn't help then you could have a bearing issue where the belt goes around a pully under the tub itself. If so you will have to replace the pully itself and perhaps the belt if it's gotten worn too much.
Nov 15, 2013 | Washing Machines
On the spin cycle, it makes a banging noice, rythmic, about 2 per second....only on the spin cycle... can you help???
The spin cycle is used to rid the water by centrifugal force. As the tub spins, the water iis forced out of the clothes. The banging noise comes from the weight of clothes being on one side making the load unbalanced. The machine will absorb some minor unbalancing. If it gets real loud & the machine starts dancing, shut the machine off by raising the lid, when tub stops, rearrange clothes.
Louie Almond
Mar 27, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Ariston front loading washing washing
Believe it or not.....its almost always the cloths ( heavy blankets) that one places inside.
TRY:: In the spin cycle if the load is unbalanced the TUB will rock and make that "loose drum out of alignment" noise. STOP the machine and open the door ( IF IT IS A TOP LOADER ) realign the cloths (heavy or more then one blanket) so that it is EVENLY spaced through out the tub.Start the machine again.If it does it again, stop the machine and REALIGN the cloths (blanket !!) again.
p.s. there is a simpler way of doing it but I don't want you to loose your hand in the process.
Aug 31, 2009 | Ariston Technologies AW125NA 13 lbs. Load...
Spin cycle has a terrible knocking noise. Looking for input on what the issue is and is it minor or major fix?
Hello. If I was nearby I would stop in and check this out for u. If the problem is an unbalanced load of clothes or unusually heavy items like throw rugs. If this is all it is the fix is to readjust the load, and also to take very large bulky items to a laundromat.
That said, it could be a more serious problem along these lines:
If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Jul 16, 2009 | Washing Machines
No spin cycle
dear zoofan.lets see hum.....to agaitate the motor goes one direction.to spin useing the same belt it goes the oposing direction.so when spins lid switch completes curcit to motor then it would spin so if click you hear is the motor protector switch [its like a curcit breaker] kicksout that means you lid switch is working. but could the noise be the timer advancing? timer makes clicking noieses also.then that would put into question your lid switch.but you said it starts again after a few minutes.if thats a sure thing then it ,your motor is involved but a possiable is somthing is between the tubs[thats a visiual inspection]sock,any clothing or if had a nail or somthing of that sort going thru small holes in inner tub then jaming or draging on the outer tub that could stop the tub but most of the time the motor would go and would burn the belt.hope i gave you a few clues,God bless ,tom
Jan 06, 2009 | Frigidaire FWS445RF
SPin CYcle Noise
The drain line is probably clogged. Maybe that a sock or other piece of clothing get between the clothes tub and the outer tub that holds the water. In this case it may then get into the drain hose that's attached to the pump. Remove the hoses from the pump and pull the item out. In case it clean there, check the outer tub port- open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then try to remove the clothing through the port.
Apr 16, 2007 | Kenmore 42722 Top Load Washer
Washing Machines Logo
218 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
