Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
Router will not connect to the internet. Shows local access only. I don't have the installation software.
    President:
  • 2,049 Answers
Make sure the cable between your internet modem and your Belkin router is secure and in the proper ports..
Are all the lights on your internet modem lit up? If not, you have an issue with the internet modem.
Posted on Nov 19, 2009
How do i secure wireless net work its shows local only
Hi if it shows local only means you not connected to the internet and only you can access your network make sure you apply wireless password to make your network secure check the WAN cable which directly connect to your NetGear DG834G Router you can disconnect that directly connected to your laptop and see if you can access the internet should you need any other help please contact me on my weblog http://computernetworksupportindubai.com/
Jul 22, 2011 | NetGear DG834G Router
My wii won't connect to my cisco e10000 and I already checked the security settings !!
you will have to open up your network connections click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark you will need to update or install the driver or it could be firewalled
make sure your modem/routers settings are correct ie:password user name,firewall settings to allow your internet to connect also test the lead/s whether usb or ethernet you might check your modem first to make sure that you are getting a connection
click start control panel administrive tools computer management device manager scroll down network adapters + expand Ethernet driver you might see a yellow question mark? This means you need to update the driver right click you will have options to update driver disable uninstall or select properties general you will have the options to troubleshoot or to update driver rollback or uninstall
a yellow? question mark means you need to install/update driver right click to install driver
last resort ring your ISP internet sevice provider get them to check your modem for internet access online
hope this helps i just read something on the setup of a cisco
Use the Cisco connect software for the initial set up of your new E series router. While running the software for the first time it will ask you to connect the modem to the router. But will not ask you to connect the computer to the router. However it will be better if you connect the computer to the router with an Ethernet cable. Otherwise it will not find the router and you will get the error "we did not find your router". Run the program and at the end it will connect you to the Internet. You don
Jun 26, 2011 | Computers & Internet
After installing belkin wireless g desktop card icon shows not connected but signal icon shows good connection
It would appear that your computer can access the connection to the router, but you have not logged onto the ISP so you don't have internet access.
You need to click on the connection that is available and enter the password/passkey to access the router. All routers should be secured with some kind of password so that only authorized people can access them.
Apr 15, 2011 | Computers & Internet
My internet will not connect. Says the strength is strong, but internet is still unable to connect. We are using the netbook by sylvania. We have the lynxis router and the internet is constantly...
Please check in the Network connection whether the Connection status shows Limited/Local only.
If in case the it shows Limited Only, then follow the steps:
1) Unistall Network Driver and restart then Reinstall the Network Driver.
2) Installed Updated Driver from the Manufacture Site. restart.
3) This should resolve the issue. If the connection status show Connected/ Internet. Then Configure the Wireless connection, by accessing the Router. Check the Router configuration and computer's configuration,.
Nov 25, 2010 | Sylvania G-Netbook
I had 1 modem and router with 4 pc and shared the internet connection. but now i need to add another broadband router so that i can use the internet. how can use another router and share the internet...
  • 1Unplug one of the network connections from your old router.
    Ads by Google
    '; for(i = 0; i '+ '' + google_ads[i].line1 + ' ' + google_ads[i].line2 + ' ' + google_ads[i].line3 + '
    ' + '' + google_ads[i].visible_url + ''; } s += ""; document.write(s); return; } google_ad_channel = '+7733764704+1640266093+5860073694+9911500640+7416705818+8388126455+8941458308+6876289738+7122150828' + xchannels + gchans; google_ad_client = "pub-9543332082073187"; google_ad_output = 'js'; google_ad_type = 'text'; google_feedback = 'on'; google_ad_region = "test"; google_ad_format = '250x250_as'; //-->
  • 2Use this open port to connect the old router to the new routers WAN(wide area network) port. If your old router has an uplink port, use this instead of the last LAN(local area network) port and keep the last LAN port open.
  • 3Connect the computers to the ports on the new router.
  • 4Configure the new router settings to match the old router settings.
  • 5Use IPConfig to check you current IP address
  • 6Use this information to create a static IP on the computers connected to your network.
  • 7Set the Default Gateway to the IP address of the router in which the computer connects.
  • 8Check that all computers can access the internet and "see" each other on the network.
  • Oct 24, 2010 | Computers & Internet
    Windows XP, Vista, & 7, installed citrix client 12.0.3 on each of them. When using direct connect through cable modem, access is allowed and all apps work. When connected to my local router(trendnet...
    Because you can connect outside of your trendnet, its definitely the problem. please allow and direct traffic on port 3389 in your trendnet firewall.
    Aug 27, 2010 | Citrix SonicWALL Internet and...
    Laptop shows no internet access all of a sudden although shows router connected for local access. LED display on internet port of router flickering
    plug a computer into it, launch a browser and access 192.168.1.1 This will get you into the router itself i would reset it to default and then reprogram it
    Apr 01, 2010 | Linksys Wireless-G WRT54G Router
    My apartment receives its internet connection via ethernet from an external router. I had been using the Belkin F5D7231-4 as a wireless router (not configured as an access point) but recently it dropped...
    You don't want to set a static IP address in your wireless router. You'll be connected to the network alright, but the IP address won't be recognized by the primary router. Thus, you'll see you're connected with only local access.
    First and foremost, ensure that your Internet connection is valid. Plug the ethernet cable from the wall directly into your computer and test the connection. If you can't get it to work, then the problem is not on your end. Contact the agency in charge of the external router (e.g. apartment maintenance).
    If your connection is fine hard wired, you may have bad data or a faulty configuration in your wireless router. I suggest doing a complete hard reset (there should be some instructions with your router on how to do it--some have a small flush mounted button that you have to press for a few seconds). Set up your wireless router as if for the first time. This should take care of your problems.
    May 23, 2009 | Computers & Internet
    No internet access with new Linksys wireless PCI Adapter
    Don .bin is a firmware that can upload to the linksys router or any router.
    So it seems that your unable to connect wirelessly using the linksys adapter? The Internet connection before is working properly?
    *I might advise you to reinstall the driver of your wireless adapter using the latest driver that you can download in there support site.
    - Check the Internet connection hardwired to the router if connection works it seems that problem is on the adapter.
    Mar 07, 2009 | Linksys Rangeplus Wireless Pc Adapter
    F5d7230-4 router
    The driver software that you are installing is probably not for vista
    Try to download an updated version for vista
    Dec 02, 2007 | Belkin (F5D7230-4) Router (587009)
    Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
    88 people viewed this question
    Top Belkin Computers & Internet Experts
    Prashant M
    Prashant M
    Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
