Question about Whirlpool Dryers
Drum is noisy when turning and it looks like it is slipping.
    Guru:
  • 1,738 Answers
It is your drum bearing. There is a bearing on the drum, and it is probably woren down.
Posted on Nov 19, 2009
Dryer turns on but dont not turn inside
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
You will have to remove your drum.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
Please rate me
Sep 19, 2010 | GE DBXR463GB Gas Dryer
Loud squeeking belt
Sounds like your problem may be the belt may have slipped off of the motor pulley, or idler arm pulley or noisy drum rollers.
If you have to check/replace your drum belt and if you have a front loading machine.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch or other connections.
Remove the lint filter screws and filter.
Then remove the top of the dryer.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
While you have the drum out you can check the condition of the drum rollers.
Please rate me
Aug 18, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
The drum doesnt seem to turn and makes a VERY LOUD grinding noise. It does seem to be heating up though.
And it sounds like you have noisy drum rollers.
If you have to replace your drum belt and if you have a front loading machine.
Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Good luck,
I hope this helps
Please do not forget to rate me
Thank you
Aug 11, 2010 | GE Dryers
Past few days, dryer got very noisy. Then drum
The noise is coming from a moving part. There are only a few that normally cause a problem. Also the dryer drum not turning freely is what broke your belt. Here is what I would replace. Drum rollers, Drum slides and idler pulley. You can check these parts before you replace them. If the drum rollers don't spin real easy, replace. If the idler pulley does not turn easy, replace. If the drum slides are worn, replace. Your model may be one with a front drum bearing. If it looks worn, replace.
You may be able to take dryer apart, try turning drum. Listen for the noise and notice if the drum is hard to turn. If so, you may be able to determine if the problem is in the front or back of drum. Keep on mind that the noise might have been the belt slipping due to the drum being hard to turn. Either way, when you have it repaired, it should run with the noise. Good luck.
Oct 16, 2009 | Kenmore 400 6943 Dryer
When dryer start button is pushed it hums and whirrs but most of the time it won't start. WHen it does start it seems to overheat.
Sounds like your problem may be a broken belt or a belt that is slipping. ALL WAYS UNPLUG YOU DRYER BEFORE DOING ANY WORK ON IT.
It will turn the drum slowly and cause the blower not to turn up to speed causing an overheat problem. Sometimes the overheat problem is also caused by the thermostat/thermistors being faulty. You would have to remove the back of the dryer to look for the air tube going from the blower to the drum. This is normally where the thermostats/thermistor is located.
First you will need to unplug your dryer from the electric.
While you have the drum out, I would also recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
Good luck,
I hope this helps
Oct 14, 2009 | Maytag Dryers
DRYER IS MAKING A CONSISTENT BANGING NOISE WHEN RUNNING. DRUM IS TURNING AND DRYER DOES DRY OK.
There are several things that can cause a dryer to be noisy. There are a lot of moving parts in a dryer that can cause noises to occur when they get worn. Several parts support the drum, and may make noise or vibrations when worn out. Many times a dryer will squeak just a little bit as it first starts. This should go away in just a few seconds. Make sure nothing is loose inside the drum. Remove the lint trap and look below the lint trap holder for any loose items that may have slipped through the cracks. The blower wheel is always moving and lint is constantly going by it. If it’s noisy, it may have gotten clogged with lint, or it may be worn and need to be replaced. Clean out the area around the blower. If it’s still noisy, replace it.
Many dryers use a center spindle to support the clothes drum. This spindle may be a ball-and-socket support, or it may be a shaft inside a sleeve. When these component bearings get worn out, they may make a squealing or rubbing sound. Replace this bearing when it gets worn out. Many dryers also use plastic glides in the front end of the clothes drum. When these glides are worn out, you may hear a lot of noise. If the glides are worn, replace them as a set.
Some dryers use rollers to support the clothes drum. If these rollers or wheels are worn out, they can be extremely noisy. You ought to replace the whole set at the same time. A belt that has been damaged or frayed may make a thumping or slapping sound as the drum turns.
The gas valve solenoid will make a buzz type of sound as it opens. The valve itself will give a little click as it starts the heat cycle, when ignition begins, and when the burner is turning off. The burner flame itself makes kind of a low-pitched roaring wind sound.
Thanks for using Fixya.
May 28, 2009 | Frigidaire Dryers
Whirpool Thin twin with noisy dryer?
You could have a wore out dryer belt wich could cause the drum to feel lose, Also you could try checking the glides underneath the front of the drum to make sure they did'nt slip out of position. This helps the drum turn with little or no friction.
Mar 11, 2009 | Whirlpool LTE5243D Top Load Stacked...
Whirlpool dryer drum making noise
window.google_render_ad();There are many places & parts that could be causing your Whirlpool dryer to be noisy. To find out what is causing the noises, you need to find out where are the noises coming from.
Start the dryer and let it run for a while and listen to try to pinpoint where in the dryer the noises is coming from. Once you have an idea of the area, you will need to disconnect the dryer from the wall outlet and take the dryer apart.
Below you will find the parts that you need to check when your dryer is noisy.
The drum baffles:
The drum baffles are use to tumble the clothes inside of the drum, in other words, the baffles job is to separate the pieces of laundry as the drum turns.
When the dryer is getting older and if you use the dryer a lot, the drum baffles holding screws will become loose. Loose drum baffles will cause noises. All you need to do, is to open the top panel and tighten the drum baffles holding screws.
The drum support rollers:
These dryers uses four drum support rollers, tow on the front and two on the rear. The job of the drum support rollers is to keep the drum tumbling smooth.
When the grease on one of the rollers dry out, the roller start to make squeaking noises and the roller bearing will start to wear out until the bearing on the roller is gone. When the bearing on the roller is gone, the noise will change from squeaking to a clanking noise.
The blower wheel:
The blower wheel is use to circulate the air inside of the dryer drum. The most common Whirlpool blower noises are cause by something falling inside of the blower housing and hitting the blower when the motor runs.
The Idler pulley:
The Idler pulley is use to apply the necessary tension on the belt. There are two types of idler pulleys, the pulley with the wheel and the pulley with the teflon slide. A bad idler pulley could cause a Whirlpool dryer to be noisy.
The drive motor:
Worn out bearings on the motor will cause the motor to run kind of noisy. When the motor starts making noises, the solution to this problem is to replace the motor.
The belt:
The belt on most dryers is only about1/4 inch wide. These belts work very hard making the drum tumble. When the belt stretch just 1/2 inch more that it supposed to, the belt will start slipping and that could cause your Whirlpool dryer to be noisy.
As you could see, there are a lot of parts that could become noisy in your dryer. When your dryer starts making noises, make sure to check it out before it gets worse.
Feb 09, 2009 | Whirlpool LER4634J Electric Dryer
Hotpoint Aquarius WMA37 - the drum is not turning, even by hand
Remove rear panel of washer, slip the belt off, then try the drum to see if it turns, if it does, then the motor is the problem, if it does not, then the main bearings have siezed, or there is something fast between the inner and outer drum..
If it was noisy on spin prior to this happening, then it is more than likely the main bearings that have siezed.
Plz rate my solution.
Thanks.
THAN
Jan 10, 2009 | Hotpoint Aquarius WD640 Front Load...
Front loader noisey
Hi.
If you remove the belt and turn drum by hand, it should revolve freely and without any noise.
If it is noisy or feels stiff, then you proabably have main drum bearing failure.
Could be expensive to put right
Nov 21, 2008 | Hotpoint Ultima WF860 Front Load Washer
Dryers Logo
41 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
