Question about Mitsubishi WD-52327 52" Rear Projection HDTV-Ready Television
Tv brightness Well i have mitsubishi wd 52327 dlp 52 inch tv, its 2 years old and watching a hight def channel the picture has a light haze to it.I had explain the situation to a authorized mitsubishi repair shop and the said i might be the light engine is going out, what is the light engine on the tv i would like to know.
  • desparado Jul 08, 2008
    Same problem. I replaced lamp in May and now it is fading bad. I am going to take the TV a part and see if I can clean the lenses.
  • 42 Answers
I seriously doubt it is the light engine... I've owned my exact model for 2 years and can tell you as much or more than the average tech. I own my own PC business therefore have an electronics background although there is always something someone else does through trial and error to find a more viable alternative to changing the light engine.
First, unplug the tv, then take the filter out and clean it.. blow air through the TV vent and fans. Next, remove the panel below the panel it pops off. There are 2 big steps that you need to understand what to do in order to not damage the tv... First, the lamp is removed and placed on a hard surface free of water oil dirt and certainly don't lay it on the carpet. take the canned air and blow the fan off and general cleaning area where you can reach. Next part of step is to leave this out and remove the row of screws on the bottom carefully and put them in a dish. remove the surround screws in back from the bottom to the top and across the top and back down the other side. dont' go below the screws around back that are the bottom as you don't need to disassemble the tv, just want to remove the screen for cleaning.
Once removed, there is a plug for the wired display buttons to work and interact and be careful pulling that apart. Now, slightly lift up on the screen on the sides and it should pop off. lay the screen vertically not flat on the floor. Take a dust remover like one swiffer makes that removes all dust. IF the dust is really like a film, well you can lightly spray it with eyeglass cleaner (no amonia) and clean it off with a cotton towel but remember the towel will leave lint and dust. So afterward take off the dust with the swiffer dust removing duster.
I wouldn't remove this if you aren't mechanically inclined. However, I want you to also look at the lamp as they do dim after time but it should be okay. Anyway look for darker areas in the lamp. If so replace the lamp AFTER you try the tv first to see if it is better.
I got dust in my tv the first time when workers turned on the tv while they were tiling my living room corner and sucked in dust. Since then I've performed similar cleaning on multitudes of different brands, all with similar results that you will agree is outstanding or at least 80% better.
bob
Posted on Jan 24, 2008
The light engine is that part that displays the picture on the screen. its like a filmprojector. if you need the complete LE, you run in about 1200-1600 dollars.Mitsubishi DLP's are known for collecting great amounts of dust, so try to clean the filters first and remove all the dust you can find.be careful,do not use a vaccuum as they can damage the electronics and the fans.....
Posted on Jan 11, 2008
Tv turns on works for awhile then shuts down
it seems cooling problem check if fan is working or not
and check the english user guide
http://www.manuals365.com/swf/mitsubishi/wd-62327.html?page=50
Mar 17, 2015 | Mitsubishi Wd-52327 52" 1080i Hd Dlp...
I have to change the lamp on my mitsubishi dlp tv. where is the lamp located?
Here is a link to the owners manual for lamp cartridge replacement. Specifically go to page 65 for instructions. Good Luck : )
http://support.mitsubishi-tv.com/files/oguide/WD-52327.pdf
Jul 26, 2011 | Mitsubishi WD-52327 52" Rear Projection...
Our Mitsubishi WD 52525 goes to blue screen and shuts off.
It sounds like you TV is overheating and the video is suffering and the lamp is overheating as well. Also, if your TV is over 2-3 years old, the mirrors (behind and below the big front screen) desperately need to be cleaned. Clean all filters and fans as well. (Look on side and behind the unit). Is the TV in a "hot" environment and/or dirty environment? DLP TV's are NOT sealed units. They need to be cleaned every few years to work well to have a good, clear, bright picture.
Jun 24, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Picture getting darker over the years
It could be your Light Engine. However, I would first check a few things:
1. Make sure your Low Power/Lamp settings are adjusted so that they meet your brightness needs.
2. Make sure you used a Mitsubishi original lamp, as generics get chewed through fast and hard.
3. Try another lamp; sometimes you can get a bad one in the bunch.
All those things don't work, consider a Light Engine ($400 + for parts; $300+ for labor)
Mar 11, 2009 | Mitsubishi WD-73827 73" HDTV DLP TV
Buzzing noise from Mitsubishi DLP WD-52327 after replacing bulb
Did your replace lamp come on the screen or did you lose picture? Just because the LED indicator suggest replace lamp it doesn't mean it needs it. If your pix was dull or loss of brightness then replace it, if not then just reset your lamp timer, check your owners manual for instructions.
Feb 14, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Mitsubishi 57" DLP. Replaced bulb, now picture is hazy.
Cleaning th mirror and lense will remove the haze. This oldel is much older that 2 years though.
Jan 24, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Dull almost Foggy picture.
you need to take the screws out from around the screen in the back, on edges, go to the front and take the screws out from the bottom of the screen, should be 4 or 6 in the front, pick up on the screen and lift off, only about 8 pounds, now clean the little mirror in front of the projector, and clean the dust off the projector lence, that will solve it, iv had to do this on about 50 of thease tv's
Jan 08, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Tv brightness
I just bought an e 62525 on craigslist for $300 dollars. The guy had it in his garage because of a degraded picture... white out haze and virtually no black ... I surfed for similar issues most referring to the light engine. However; going back to basics. I removed the front panel assembly (approximately 16 screws including the center panel surrounding the card/rca ports in the front). The main mirror was spotless (in itself missleading) but the projection lense and the smaller mirror were frosted over with 3+ years of fine dust. I cleaned them with a simple cloth. I also noted that the foam insert surrounding the lense had gaps due to age which allowed excessive light sepage (the white out problem). I repositioned the foam as best I could. Then simply stuffed a black cloth over the foam but firmly arround the lense (keeping the foam intact as well). This blocked "all" light sepage. Bottom line is that I now have a picture quality that is flat out incredible! This is one bad mutha (shut yo mouth) tv. P.S. I'm just an average guy with an electric screw driver.
Nov 26, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-52327 Picture flickers and goes blue
In your case I've seen this and it was a electrical issue between the DLP fan and board. The tv could have a problem with the digital tuner and not kicking a code due to low voltage ... it isn't expensive to fix, just hard to diagnose.
Do you smoke? The fans suck in smoke and it gets tar build up on the connections and that causes this in some cases too.
Dec 28, 2007 | Mitsubishi WD-52327 52" Rear Projection...
Mitsubishi WD-52327 52" Rear Projection HDTV-Ready Television Logo
337 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
