Question about Maytag MAH2400A Front Load Washer
How do I disconnect the wiring connector from the motor of a MAH2400AWW Washer?
    Guru:
  • 1,738 Answers
It should be a plug that you can pull or they should be individual alligator clippers.
Posted on Nov 19, 2009
My windshield wipers on my 2000 Pontiac Montana won't stop as soon as I turn it on they start going I have tried turning it off of course but they just keep going
The switch is bad or the wiper motor cover ,electronics !
  1. Turn the ignition switch to RUN.
  2. Turn the wiper switch to OFF.
  3. Disconnect the wiper/washer switch connector C201.
Do the wipers park? yes or no ?
if yes Replace the wiper/washer switch. Refer to Multifunction, Turn Signal, and Hazard Switch Replacement - On Vehicle .
if no
Measure the voltage from connector C201 (vehicle side), terminal E2, to ground with a DMM.
Does the voltage measure greater than the specified value?
1.0 V yes or no ?
Replace the wiper motor cover. Refer to Wiper Motor Cover Replacement .
Did you complete the replacement?
Go to Step 9
6
  1. Reconnect the wiper/washer switch connector C201.
  2. Disconnect the wiper motor connector.
  3. Measure the voltage from the wiper motor connector, terminal D, to ground with a digital voltmeter.
1.0 V
Go to Step 8
Go to Step 7
7
Go to Step 9
8
Repair the short to voltage in CKT 113. Refer to Wiring Repairs in Wiring Systems.
Did you complete the repair?
Go to Step 9
9
Operate the system in order to verify the repair.
Did you correct the condition?
System OK
Go to Wiper/Washer System Check
if yes
Apr 20, 2015 | 2000 Pontiac Montana
How to repair nd code on a maytag mah2400aww washer
Remove the back panel (2 screws). On the bottom tray is the water discharge pump. Clear any obstructions.
Nov 14, 2012 | Maytag MAH2400AWW: Compact Front Load...
Where can I purchase a Y connector for a Maytag washer model#MAH2400AWW
I would guess that your local hardware shop should have them- they are quite common (the Y connector!)
Cheers,
John C
Feb 26, 2011 | Maytag Washing Machines
Windshield wiper moter went out i need to change it out. how do i change it?
  1. Disconnect the negative battery cable.
  2. Remove both wiper arm and blade assemblies.
  3. Remove the cowl grille attaching screws and lift the cowl grille slightly.
  4. Disconnect the washer nozzle hose and remove the cowl grille assembly.
  5. Remove the wiper linkage clip from the motor output arm.
  6. Disconnect the wiper motor's wiring connector.
  7. Remove the wiper motor's three attaching screws and remove the motor. To install:
  8. Install the motor and attach the three attaching screws. Tighten to 60-85 inch lbs.
  9. Connect wiper motor's wiring connector.
  10. Install wiper linkage clip to the motor's output arm.
  11. Connect the washer nozzle hose and install the cowl assembly and attaching screws.
  12. Install both wiper arm assemblies.
  13. Connect the negative battery cable.
Installing the wiper arm connecting clip.
Feb 25, 2011 | 1992 Ford F250
How to install a front blower motor in a 96 ford explorer
Blower Motor - REMOVAL & INSTALLATION
(see Figures 1 and 2)
Fig. 1: Exploded view of the blower motor mounting
Fig. 2: Exploded view of the blower motor and wheel (fan) assembly
Without Air Conditioning
  2. Remove the air cleaner or air inlet duct, as necessary.
  3. If necessary, Remove the speed control module and the washer fluid reservoir.
Fig. 3: To remove the blower motor, first disconnect the electrical wire harness plug...
Fig. 4: ...then remove the blower motor cooling tube from the motor
  1. Disconnect the wire harness connector from the blower motor by pushing down on the connector tabs and pulling the connector off of the motor.
  2. Disconnect the blower motor cooling tube at the blower motor.
Fig. 5: Remove the blower motor attaching screws and the washer fluid reservoir...
Fig. 6: ...then slide the blower motor from the housing. Take care to not damage the blower wheel (arrow)
  1. Remove the 2 screws attaching the blower motor and wheel to the heater blower assembly.
  2. Holding the cooling tube aside, pull the blower motor and wheel from the heater blower assembly and remove it from the vehicle.
  3. Remove the blower wheel push-nut and/or clamp from the motor shaft and pull the blower wheel from the motor shaft.
To install:
  1. Install the blower wheel on the blower motor shaft.
  2. Install the hub clamp and/or push-nut.
  3. Holding the cooling tube aside, position the blower motor and wheel on the heater blower assembly and install the 2 attaching screws.
  4. Connect the blower motor cooling tube and the wire harness connector.
  5. Install the vacuum reservoir on the hoses with the 1 screws.
  6. If removed, install the speed control module and the washer fluid reservoir.
  7. Install the air cleaner or air inlet duct, as necessary.
  8. Connect the negative battery cable and check the system for proper operation.
With Air Conditioning
  2. In the engine compartment, disconnect the wire harness from the motor by pushing down on the tab while pulling the connection off at the motor.
  3. Remove the air cleaner or air inlet duct, as necessary.
  4. If necessary, remove the solenoid box cover retaining bolts and the solenoid box cover.
  5. Disconnect the blower motor cooling tube from the blower motor.
  6. Remove the blower motor mounting plate attaching screws and remove the motor and wheel assembly from the evaporator assembly blower motor housing.
  7. Remove the blower motor hub clamp from the motor shaft and pull the blower wheel from the shaft.
To install:
  1. Install the blower motor wheel on the blower motor shaft and install a new hub clamp.
  2. Install a new motor mounting seal on the blower housing before installing the blower motor.
  3. Position the blower motor and wheel assembly in the blower housing and install the attaching screws.
  4. Connect the blower motor cooling tube.
  5. Connect the electrical wire harness hard shell connector to the blower motor by pushing into place.
  6. If removed, position the solenoid box cover into place and install the 2 retaining screws.
  8. Connect the negative battery cable and check the blower motor in all speeds for proper operation.
Hope this help (remember comment and rated this).
Apr 23, 2010 | 1996 Ford Explorer
The Maytag repairman says my model number is MAH2400AWW. You tell me: No manuals found for mah2400aww manuals. What now?
Check for yourself, pull the washer out, and check the back. model numbers/serial numbers are normally tagged on the back.
Dec 31, 2009 | Maytag MAH2400A Front Load Washer
Wiper/Washer Motor
You may have bought a constant wiper motor, rather than one with intermittent settings. It happens.
Aug 06, 2008 | 1984 Chevrolet K1500
Maytag MAH2400A Front Load Washer Logo
105 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
