I get "NO SIGNAL" when hooking laptop to TV.It worked fine before....mounted the unti to the wal...and no go. HELP!
  • 11,361 Answers
Try hooking up you laptop to PC monitor to see if you get the siganl OK first.
Posted on Nov 19, 2009
No input signal on monitor-not connected to tv-computer works fine except for the no input signal
no input or signal means that the monitor is not receiving any signal from the CPU and if the power light is amber then and the cpu works fine then there could be a problem with the cable connecting the CPU and the monitor ...check the cable.
Mar 03, 2014 | Dell Computers & Internet
We want to hook our small Magnavox tv to a rabbit ear antennae to get only local stations. How to do this?
Unless this a new TV with ATSC (digital) tuning built in, you will need a digital adapter for off-the-air reception. Older TV sets have analog tuners, and analog broadcasting ended in June 2009. Wal-Mart and Radio Shack carry the adapters, as do other retailers. Your antenna connects to the adapter, and the adapter sends the converted signal to the TV on channel 3 or 4.
With digital broadcasting, a strong signal is necessary. Unlike the analog days, when a weak signal just meant a fuzzy picture, a weak digital signal will cause pixellation (blockiness) or freezing of the picture, or may not even be detected by the tuner. Depending on how far you are from the station's transmitter, you may find that rabbit-ears may not work too well. You may need an amplified antenna or even one outside to get best performance.
Aug 07, 2011 | Televison & Video
When I hook my tv up to cable I get no signal, if I just hook it up with antenna it works fine. How do I get my tv to work with my cable cord? Would be nice to view cable channels instead of just 3...
nialbert,
It sounds like you are hooking the cable to the wrong input (digital instead of analog) or you do not have an analog input. If you do not have an analog input you could run the cable through a VCR to convert the signal to a separate audio/video signal and send it to the TV via an auxillary input. Without the model number I can't give you much more help.
Thanks for using FixYa and for the great rating.
hardrocko
May 09, 2011 | Televison & Video
My Samsung LN-T4069F momentarily shuts off and restarts frequently. The shut down is very short. Is this a firmware issue?
No,this problems it is the tv Tuner signal board itself have issues.Tv intermittently shutdown and restart wright back and tv work fine as nothing wrong wright?Yes.This problems it is the tv Tuner signal board itself have ICS chips grounding issues problems.These ICS chips on the tv Tuner signal board are surfaces mounted soldering works and are not on sale indivitually ICS to the customers,even if they do,it impossible to do surfaces mounted ICS chips parts work without a 1200 degree celsius convaer belt style wave soldering machine any how.The tv still work fine wright,just used it.When it shutdown for good and don't restart it wright back again.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv Tuner signal board for the replacement.
Apr 03, 2011 | Samsung LNT4069F TV
I bought a new antanea 3 ft fiberglass with mirror mount when hooked to radio needle swings all the way to the red and i dont transmit or receive but when hooked back to old antenae works fine old antenae...
Mirror mounts need alot of Ground to tune correctly. Most mirrors don't ground to the door good enough, not to mention the reflection of the radio signal off the cab. Be sure it's grounded good and the nylon insulator is place.
Jan 14, 2011 | Cobra 29 LTD CB Radio
Toshiba 46HM95 wont display 720p from dtv antenna other tv works
lets start with the easiest first.does your tv in the menu option offer an input output source like 720p or 480p?on my set i can change to any format.maybe yours does too.let me know and we go from there.
Mar 04, 2010 | Toshiba 42H81 42" Rear Projection...
HDMi ( no signal, not supported) doesn't work with Dmr-Ez47v
Any HDMI cable manufactured in the last couple of years should all be HDMI 1.1 compliant, your problem is most likely the logic board in the TV itself or the HDMI connector on the logic board has a bad connection..
Have you tried hooking-up a standard DB15 VGA cable to the AKAI TV and your laptop?
If this works your problem is in the TV and will most likely have to be repaired to receive the HDMI signal since your Panasonic DVR and your laptop are not recognized by the HDMI input on the TV.
Ren
Jun 03, 2009 | Akai LCT2785TA 27 in. LCD Television
How can I hook the 5610 to the TV to use as a monitor?
Use a S-Video cable. You can pick one up at Wal-mart.
Make sure your tv has S-video if not check to see if laptop has optical connection and tv also. Cables can be bought at Wal- Mart.
Jan 17, 2009 | Acer Aspire 5610-4648 Notebook
Televison & Video Logo
52 people viewed this question
Top Televison & Video Experts
Electro Med Services...
