Question about Whirlpool GEW9250 Electric Dryer
Whirlpool Dryer. Heating core has 220v feed, but will not heat,
Heating core has 220v feed, but will not heat, is the core broken somewhere?
  • theistad279 Nov 19, 2009
    No it is clear, if there was a fault (blockage) the board would not feed the heating core power? The core has power, 120 per side.
    Guru:
  • 1,738 Answers
Check to see if your vent is being blocked by lint.
Posted on Nov 19, 2009
My dryer is working, but not heating what can I do?
assuming you have checked the outlet for 220v, it could be either your thermal fuse or the heating element itself.  if you have power and thermal fuse is good, odds are the heating element is open. you can check both the thermal fuse and heating element with an ohm meter, AFTER YOU UNPLUG IT.
Aug 04, 2010 | Whirlpool LER4634J Electric Dryer
Whirpool dryer not heating at all
http://www.repairclinic.com/SSPartDetail.aspx?s=t-LER4634J-%3d%3di2986&PartID=2986
this is the thermal fuse. jump it out (take back panel off and look for it) if the heaters come on the replace fuse. make sure you have 220v going to machine
http://www.repairclinic.com/SSPartDetail.aspx?s=t-LER4634J-%3d%3di2438&PartID=2438
this next part are the heating elements use a meter and check if there is 220v going to it if it is replace heater
Mar 27, 2010 | Whirlpool LER4634J Electric Dryer
Whirlpool Duet Dryer not heating
FIRST YOU SHOULD CHECK YOUR BREAKERS MAKE SURE BOTH ARE ON. YOU NEED 110V TO RUN THE MOTOR BUT 220V TO HEAT.IF THAT IS FINE IT MAY BE A SENSOR OR A ELEMENT.
Jan 15, 2010 | Whirlpool GEW9250 Electric Dryer
Dryer not heating at all. What is the common
heat unit , 3-4 thermostats .
but you have to open the unit and do not do any thing under power!!! its 220v
you need volt meter.
Jan 02, 2010 | Whirlpool LEN2000PW Dryer
LER4634EQ2 whirlpool electric dryer. heating element,thermal cut-off, and high limit are all getting continuity, but heating element still will not heat up.
I know this might sound stupid but try this. Find your fuse box, locate the breaker that runs your dryer. Flip it off and then back on. If i'm correct, it will work. Everything on your dryer works off of one leg of the 220v. The other leg goes to the other side of the element. If you have a meter. check for 220v at the plug. Everything you listed is what makes the dryer heat other than the thermostats. Check the cycling thermostats like you did the other pieces. They look like the thermal cut off. They have two wires and they are round.
Oct 09, 2009 | Whirlpool LER4634J Electric Dryer
My electric dryer works but no heat is coming out
First check he power coming in you ned 220v if one leg of the power is missing you will still feed 110v which will allow the motor to work but not heat the next step is to remove the back panel un plug the unit and test the thermal fuse on the upper left side of the heating element enclouser if this ok then check for a broken element
Jan 08, 2009 | Roper REX4634KQ Electric Dryer
It wont heat up
Check to make sure that both legs of the 220V feed are presnt. The motor will run on only one leg. Otherwise, on that model, check the thermal overloads mounted on the heater box, and also check the heating element for continuity.
Dec 11, 2008 | Kenmore 65924 Electric Dryer
Dryer won't heat
It could be a defective thermostat or heating element(In most of the cases it is the heating element).Open the service panel and check with a multi-meter for 115/220V on the heating element tags. If you can read 115/220V on its tags, it should be replaced. In case you can't read 115/220v on its tags, you should replace the thermostat. Good luck!
Sep 02, 2007 | Frigidaire FEQ1442ES Electric Dryer
Whirlpool GEW9250 Electric Dryer Logo
95 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
