Question about Western Digital 500GB My Book Pro-External 500 GB Hard Drive
My iomega external hard drive light doesn't come on and my pc doesn't recognize it. I bounced the usb cable by accident and it came loose while i was listening to music from it. When i reconnected the cable, nothing happened. What can i do to fix it
    President:
  • 1,015 Answers
When you disconnected the hard drive by pulling the USB cable from the computer without using the remove hardware feature it will cause the computer to not recognize the drive. You should be able to power down the drive and then re-boot the computer. After the computer has restarted then reconnect and power up the drive and windows should detect it again. Some of you files on the drive might have been corrupted when this happened so I would go into my computer and run check disk to repair any errors on the drive. If you reboot the computer and the drive still does not respond then you may have caused damage to the drive. You could then try dis-assembling the case for the hard drive and installing it into the computer and see if it works. If it works in the computer then the external hard drive's power supply is defective if it does not the the drive is damaged.
Posted on Nov 19, 2009
My Iomega LDHD250U 250 GB USB External Hard Drive's Power and Usb ports WILLNOT CONNECT!!!!!!! Please help ive been trying to figure out why all day.
Dear Friend, Your I-Omega case might be bad or the controller inside that connects everything. I suggest you to get: http://www.walmart.com/ip/Apricorn-Universal-Hard-Drive-Adapter/10811435. and pulled your hard drive enclosure apart, then removed your hard drive and connect with the external adapter. Usually comes with a SATA or IDE connector for data and power adapter. After connecting everything plug into your PC and it should be able to recognize.
Good Luck#
Jan 13, 2014 | Iomega (33215) 250 GB Hard Drive
Windows 7 driver for160GB eGo USB 2.0 Portable Hard Drive?
According to the Iomega Support web site you do not need additional drivers for using your Iomega eGo drive with Windows 7 unless you have a USB 3.0 device.
See this Iomega document on what you should do if your drive is not detected on Windows 7
Jan 14, 2012 | Iomega 33914 Storage 160gb Ego Silver...
I am running windows vista 32 bit operating system and it is not recognizing my iomega external hard drive
1.check the cable of external hard drive
2. Check the usb port. "Connet external hd to the back pannel of your pc"
Sep 22, 2011 | Computers & Internet
Computer doesn't see iomega
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
if this fails to fix the problem
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps you
Aug 26, 2011 | Iomega eGo Portable Hard drive 500 GB ...
My sony asnd laptop will no longer recognize the external hard drive
Check it in another pc. If it's the same then the Iomega has died, junk it and get a new one.
Jul 03, 2011 | Iomega 1TB Prestige External USB 2.0 Hard...
I have a white light on my iomega external harddrive. My computer does not recognize it. Is my data recoverable?
There is a chance that the only thing that isn't working on the external hard drive is the actual controller of the enclosure. What you could try doing is opening up the external hard drive to get at the actual drive that's inside. Go online and look for something called an IDE to USB adapter. They are usually relativly cheap, 10-20 bucks. This will plug into the back of the hard drive and then to the computer with a usb cable. See if the drive is readable. or if you have another open SATA port in your desktop computer, just try connecting it as a secondary hard drive. See if it will read it.
Mar 04, 2011 | Iomega 1TB Desktop USB 2.0 Hard Drive
Hard drive not recognized
1. your hard drive may have come to what is call "end of life" cycle
2. You didn't designate if you have a internal / or USB drive.
3. If this is an IDE ( internal Drive) then you will have to enter the PC cabinet to check.
4. IF this is a USB drive some time the electronic controller board is malfunctioning and will not transfer data from the processor on the data board to the USB cable.
5. If it is USB the usb cable it self is damaged due to strain at the strain relief.
6.The PC Mother board may have lost it's ability to recognize the hard drive.
Apr 15, 2010 | Iomega HDD External Desktop (32660) 80 GB...
Vista stops recognizing external hard drive
This doesn't sound like an OS issue. This appears to be more an issue of the connection to the hard drive. The USB cable likely isn't the culprit, nor the laptop USB inputs. If the drive was ever dropped or the cable gets removed and reattached often to the actual enclosure, you might be looking at a bad port on the enclosure. This isnt a lost cause. You can always buy a hard drive enclosure from newegg and move the drive from the IOMEGA to the new enclosure. You can get a new enclosure for $15. Just because the USB port is bad, it doesnt mean the data is gone and the hard drive cant be used.
Aug 26, 2009 | Iomega 33089 250 GB Hard Drive
Iomega external not visible
Unfortunately, Windows isn't the most efficient operating system when it comes to it's "Plug 'n Play" abilities. In my experience, external hard drives can be particularly sensitive when it comes to unplugging the data cable while navigating the drive. I've had two external drives lose all data because of that flaw in the NTFS file system. The MFT exists on every drive with NTFS storage method. If that becomes corrupt, it can render the drive useless.
The drive may have power, but that quiet beeping you hear is an indication that the reader head is stuck to the platter and may be grinding into it. There is a myth (may or may not be true) that says if you put the drive in your freezer for a few minutes, take it out, drop it from 6 inches onto a hard surface, it may knock the head loose and make the drive work again.
I tried that method, and it made the situation worse for me, but it may work for you. I would resort to that option only if nothing else fixes it.
Aug 08, 2009 | Iomega CORP EGO PRTBL HD 160GB-HS USB 2.0...
Computer doesn' t recognize iomega eGo portable
a windows update may have run and killed the drivers...try rolling the system back to before the problem started, then if updates run again..and set them to download but dont install..install them yourself..run updates and see if the problem re-appears.
Jul 24, 2009 | Computers & Internet
Open Questions:
See all Western Digital 500GB My Book Pro-External 500 GB Questions
Western Digital 500GB My Book Pro-External 500 GB Hard Drive Logo
1,495 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
