Question about Mintek LCD TV Progressive Scan DVD Player
Hi bought a tv with stuck dvd i was able to take out dvd
I took out dvd but tv still in dvd mode can't play tv with out dvd i have plain screen
  • 10 more comments
  • milkman42 Jan 11, 2008
    hooked up s video same result
    unpluged tv for a while same result tryed another dvd only plays intro over and over just like before cannot get tv just tv to play
    how would i program if i can't get to tv screen only dvd intro no tv at all
    i am sorry it is a mintek dtv-265-d
    no warranty need repair know any one else who can help
    no way i can fix can't even buy parts i tryed thinking i could replace dvd could not find guess i will try local repairman
    tryed it no help but thank you
  • milkman42 Jan 12, 2008
    hi saw what probaly was battery but it is wired in not simple to remove i thank you for trying but it is time to spend or throw away some money that what i get for trying to get a deal cheap
    where would you buy find a main board mintek wouldn't even talk to me at the number i called they gave a warehouse number they said leave message no one called back
  • milkman42 Jan 13, 2008
    i wonder who mintek buys their parts from there are a few makers and a lot of sellers of tv's
  • milkman42 Jan 14, 2008
    HG POWER dtv260a hgp-dsc 220 atv
  • milkman42 Jan 16, 2008
    hi i found the main board from mintek but they won't sell it to me at less not if i tell them the truth they will only sell to sevice tech. so guess why i am telling you this . if you could help me you need to call 1 800 838 3315 they will send you information in the mean time you can tell me how to get you the money if it helps my number is 336 375 1967
  • 2,427 Answers
Unplug it for a bit and plug it back in,,
If that dont help connect something using one of the other input connectors..
Posted on Jan 11, 2008
  • 15 more comments
  • Rishi Roshan Ali Jan 11, 2008
    What is your brand and model tv ?
    Did you try programming your channels again ?
    DO YOU HAVE WARRENTY ON THAT MACHINE ?????? I HOPE YOU DO CAUSE APPARENTLY ITS DEFECTIVE
    http://www.avsforum.com/avs-vb/printthre...
    EVERYONE SEEMS TO BE HAVING PROBLEMS WITH IT...
    CALL THE MANUFACTURE OR LOG ON TO THEIR SITE TO SEE IF A FIRMEARE UPDATE IS AVAILABLE.. IF ONE IS FOLLOW THE INSTRUCTIONS TO UPDATE IT...
    READ THE LAST 3 POST HERE
    http://www.avsforum.com/avs-vb/archive/i...
    It apperas its the internal controll IC and it needs to be returned t mintek To be fixed if you got warrenty.. If not A local technician might be able to change it.. but more than likely you eill have to send it to minitek with or without warrenty.. READ THE ABOVE LINKS THERE ARE TONS MORE I CAME ACROSS BUT THOSE WERE THE MOST DESCRIPTIVE
    Do you wish to attempt your self or would you be taking it to a technician ?
    To Repair this item you will need to purchase a Main board since the component isnt sold seperately.. You can order one from the mintek eighter from their web page or by phone.. There is a posibility it may have a distributor close to where you live.. Once you get it, simply replace your main board with the purchased one... I am looking for an alternate solution ..
    CONTACT INFO
    WEB PAGE - http://www.mintekdigital.com
    Phone (866) 709-9500
    YOU CAN ALSO GET CONSUMER SUPPORT VIA THEM
    TRY PRESS FLASHBACK THEN OSD TWICE
    I will still look for more information for you. And i will look for a refribished board as well or even a substitue controll component.
    Ok LETS TRY THIS
    UNPLUG YOUR SET..
    1.) remove the back panel from your set,
    2.) on the mainboard there should be a battery, remove it,,
    3.) press and hold the power button for 5 seconds,, this it to discharge any remaining eletricity..
    That should reset the board (hopefully)
    Replace your battery and turn it on...
    keep fingers crossed..
  • Rishi Roshan Ali Jan 12, 2008
    well u cam just snip or unsolder the wires, besides if this works you'll save the money :) if it doesnt, well it wasnt working any way,, give it a shot..
    unfortunately you can only get it from them it looks like,, i have been tryong to find one and as well a refribished one with no luck. A buddy of mine suggested that you can speak to a local technician and have hime take a look at it first and see if he knows what could work.. i think that you should do that cause meybe he knbow a substuite for the controll ic (thats the bad part you got)...
    KEPP NAGGING THGEM THEY WILL CALL BACK,,, most companys need a good nag to get things done.
  • Rishi Roshan Ali Jan 15, 2008
    Thats going to be hard to get,, my suggestion is speak to a technician and have hime take a look at it, he will be in a better position to suggest a replacement, a quick fix or a substitute...
    I made a few calls and sufred quite a bit and came up with nada... Look at the time convergence when calling mintek..
    but my best bet is that you will find a substitute faster then a original replacement..
  • Rishi Roshan Ali Jan 17, 2008
    wow,, I really soory sir, but i wont be able to help with this as i am not a certified technician, I just happen to know quite a lot,,
    There aint any distributors close to me eighter as i live in trinidad in the caribbean,, I'm guesing here you will wind up buying a main board..I will post a message in the fourm requesting any information anyone ,might have,, .. I'll do that now, but i think you should prepare yourself to get an entire main board,, I suggest you consult a technician and see if there are any substitutes you can use.. But Let me post it in the forum and see if anyone here can help..
  • Rishi Roshan Ali Jan 18, 2008
    hey any luck ?
Brand new tv with built in DVD player when you insert a DVD, it just pops right back out and will not play the disc
Hello there,
I believe you need to switch the TV to the DVD input mode before inserting a disc. There should be a button on the remote or the TV labelled INPUT or SOURCE. Try pressing this repeatedly until "DVD" is shown on the screen or use the UP/DOWN arrows keys on the remote to select DVD from the input list, then press OK / SELECT / ENTER to choose DVD mode. You should then be able to insert a disc and play it.
I need to check some details for this TV and will get back to you shortly. If the TV really wont accept any disc, then you've bought a lemon and the TV needs to be returned to the store for replacement asap. I will post back with more details below in a few minutes.
Regards,
BElectric
Mar 08, 2011 | Sylvania LD190SS1 19 in LCD TV
Dvd player makes humming sound while playing disc's
Hello ray sanders ,
But still the dvd plays right ??
Mar 31, 2008 | Televison & Video
Will not change from dvd to tv mode
i had the same problem if fixed it rather simply buy using a base ball bat
Mar 15, 2009 | Mintek DTV-263 26 in. LCD Television
Lightning mcqueen tv and dvd set-up, won't play, have direct tv hook-up
i guess there a built in dvd player on the set and it could play most DVD format.
but if you wish to use another dvd player
hook up the dvd on the tv
video output (DVD) to video input (TV)
audio output to audio input
the find the auxiliary button from either the tv or dvd
Oct 30, 2008 | Disney DTD1363-CAR 13" TV/DVD
GoVideo DVD combo
Hi - I can record a dvd from the tv and can play it back but when I try to play a store purchased dvd it ejects the dvd and on the tv screen it says unknown disk, please, check disk again.
Aug 19, 2008 | GoVideo Go Video DVD/VCR Combo
I cannot switch my TV mode to video mode
Hi, all you have to do is go past Channel 2 and the screen on t.v. will say Line that is where you will watch all your DVD movies...
Good Luck as I had the same problem when I first hooked up the dvd player to the t.v. , I thought I was going crazy , turned out it was simple... Enjoy ...
Mar 30, 2008 | Broksonic CTVG-5463GVC 19" TV
New dvd/vhs player but old tv
The easiest thing to do would be get a new TV plain and simple sounds as if you could use one n e ways. But first make sure you are hooked up through coaxal to the tv that will allow everything to run on channel 3. Let me know your current hookup.
Dec 24, 2007 | Televison & Video
Can't Change Inputs on TV
make sure that your remote is on the tv cotrle mode rather than the dvd control mode
Nov 10, 2007 | Mintek DTV-323-D TV
Playing back widescreen problem
The TV itself uses the CTC203 chassis and is not capable of switching between normal and widescreen. This is an issue with your DVD player and not a problem with the TV.
Jul 16, 2006 | RCA F27442 27" TV
Mintek LCD TV Progressive Scan DVD Player Logo
133 people viewed this question
Top Mintek Televison & Video Experts
Jaime Hernandez
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
