Question about Philips MMS171 Computer Speakers
I just re-assemble my computer and speakers and my speakers is not working now. I am not sure if I have left a plug out. Should something be plugged into the 'Audio In" slot?
    Guru:
  • 597 Answers
Audio in is an auxillary imput. Your speakers should be plugged into audio out. Check the power supply to your speakers. Enter Control Panel > System> and Device manager and make sure your audio drivers are working. Also enter Control Panel > Sound and Audio Devices and check the box that says "Place volume icon in the taskbar then open the volume control and make sure none of them are muted and that your volume levels are high. You can then click on the sounds tab and choose one of the sounds and hit the test button to check your speakers. Hope this helps. If all else fails check your speakers on someone else's computer.
Posted on Nov 19, 2009
Looking for old Logitech S-100 driver
These are analog speakers and do not need a driver. First, make sure they're plugged into the speaker/headphone jack and not the microphone jack. Second, make sure the computer's sound output is enabled and set the headphone/speaker jack. Third, verify that the sound output is working by plugging in a headphone set or a different pair of speakers. If the computer sound checks out, the speaker cable is bad or the power supply is not working.
Nov 14, 2017 | Dell Computers & Internet
No sound to speakers
This is pretty easy to troubleshoot. First plug something else into the speakers to make sure they work. (cd player, phone, gameboy ect.). If the speakers don't come on make sure they are getting power. There should be a light on the speakers to varify they are getting power. If the speakers do work when you plugged them into something else, plug them back into the computer and make sure you are plugging them in the right portal. A common mistake is plugging them into the mic jack. Look for a small pair of head phones next to the jack on the back of the computer. Plug them in and go to your volume control on the bottom right of your computer screen. Turn that up. This should fix you problem...if not, you may have an issue with your computer.
Feb 24, 2012 | Insignia Audio Players & Recorders
I do not have any volume in the headphones i dont know how to turn them on or something please help me on how i can hear stuff like youtube videos or something.
Did they ever work or are you trying them on a new computer? They don't need switching on you just plug the plug into the audio out of your sound card or motherboard, make sure the mute button isn't selected on the inline remote. Play an mp3 on your computer, make sure the volume on your computer is turned up, plug in another known working set of headphones or active speakers make sure you can hear the music, then plug out those speakers and then plug in the headphones. Do they work when you try that?
Jan 13, 2011 | Microsoft LifeChat™ LX-3000 Headset
My left speaker doesn't work but my right speaker does. The cord to the left speaker is plugged in all the way.
Open the "Volume Control" applet & make sure the "Balance" setting is set in the middle of the scale. This way sound will go out through both speakers.
Nov 09, 2009 | Altec Lansing MX5020 Computer Speakers
There's always a bzzz sound coming out when plugged in.
if there's buzzing coming out, there's probably a rip in the actual speakers. Something is torn on the inside thus the weird buzzing noise.
Unless it was a zzzzzzzzz...... noise then there's probably some sort of interference. Possibly cellphone close by, or some other magnetic thing to create that annoying sound.
Apr 21, 2009 | Creative Labs SBS-260 Computer Speakers
Only one computer speaker recieving a signal
Most probably there is a problem in the cable or plug.
Feb 06, 2009 | Boston Acoustics BA735 Computer Speakers
Left Speaker Stopped Working
I think I had a similar problem. My speakers were brand new and after a while I lost my front left and rear left speaker. I'm not sure about you guys but after fiddling around with the settings it worked after I changed the "S/PDIFoutput sample rate" from 48 to 96 khz. I have no clue what I did, but it worked for me. I am running logitech something or rather speakers with VIA HD audio deck drivers
Apr 24, 2008 | Altec Lansing VS4121 Speaker
Altec Lansing ada885
Same issue showed up for me today very randomly...
HD comes on and off for no reason and sound cuts in and out. This fix worked for me:
1.Disconnect the left speaker from the sub woofer.
2.Take the 4 screws out on the bottom of the left speaker. (They are under the rubber matting you can just poke holes through it)
3. Remove the bottom plastic assembly from the speaker
4. Cut the 4 wires to the headset chip. Careful not to cut any others to the speakers themselves!
5. Unscrew and remove headset plug chip
6. Reassemble and plug left speaker back into sub woofer.
No more HD issues =)
Apr 04, 2008 | Altec Lansing ADA 885 Computer Speakers
Philips MMS171 Computer Speakers Logo
155 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
