I often have trouble with my verbatim 160GB beeping insanely and refusing to communicate with my computer (a Dell PC). This sometimes happens first thing, on startup (but not always) and sometimes when I try to save a file to it after the computer has been up and running for awhile and I have already saved documents without any problems. I often have to disconnect and reconnect the external drive and ''baby'' it to get it to work properly. The verbatim drive is much too new to be having this problem. What could be causing it?
  • 358 Answers
From what I can deduce here, it seems that you the hard drive probably has a bad sector on it.
Or there is a problem with the read/write head inside the hard drive.
In this case, what I would advise you to do is, unscrew the hard drive case and remove the Hard disk from the case, connect it directly to a system, not externally or through USB this time around, then get a software called NTFS DOS Professional. It is a software that works like magic when it comes to hard drive repairs.
If you know any other hard drive utility, apart from this, you can also use it. I just recommend this personally because that is what I use.
Insert it into your PC, start up your CD-ROM and let your system boot from CD-ROM.
It works through DOS, and it should be able to help you with it.
If this does not solve the problem, then I'm afraid you might need to replace the hard drive.
And if it repairs it, I would suggest that you just retrieve all your valuable files from it and don't fully rely on the hard drive again because of the hardware error it has developed. Just keep using it as a second.
If you cannot do this by yourself, just get a very good technician to do it for you instead.
Kindly keep me posted about the problem.
Hope it helps.
Goodluck.
Posted on Nov 23, 2009
Testimonial: "Thanks. I am pretty sure I need to simply replace the hard drive. I have been disconnecting it from the computer improperly."
Dell XPS PC Desktops Beep 2 short beeps then turns off
Here is a link to your computer's service manual:
ftp://ftp.dell.com/Manuals/all-products/esuprt_desktop/esuprt_xps_desktop/xps-400_Service%20Manual_en-us.pdf
There is a section on Advanced trouble shooting which details Beep codes and LED diagnostic codes.
Feb 13, 2013 | Dell XPS Computers & Internet
Optiplex 330, fails to POST and locks
When your computer emits beeps when you power on the computer, it's usually means that you have a memory issue. Try re-seating the memory modules and power on the computer. If you have more the one module, insert one at a time and power on the computer.
Aug 28, 2012 | Dell Optiplex 330 Desktop Computer Pentium...
Optiplex 330 beeps 6 times, no display
It could be that either the graphics card or the memory modules may need to be re-seated. Those would be the first things to try.
May 25, 2012 | Dell Optiplex 330 Desktop Computer Pentium...
My Verbatim model #47512 1tb makes this beeping sound every time i connect it to my computer why?
That beeping signals a failure to communicate between the disk and the motherboard of the pc - the disk is defective. You have a slim chance of recovering what's on it by removing the actual disk from the external case and plugging it in the a desktop.
Jun 09, 2011 | Verbatim 1TB USB2.0 HDD USB 2.0 Hard Drive
Unable to safely eject
Just completely "shutdown" your computer, and then disconnect the USB cable. Then, you should be able to manually "eject".
Apr 17, 2010 | Verbatim 160GB USB FireLite: The "drive...
I have an Acer Aspire (and thats as much as I know) that makes a constant beeping sound ... so fast that I cannot even try to detinguish individual beeps to count them. Sometimes this sound does not happen...
Cardinal Rule 1
Dont use ur expensive computer for Games, go to a galeriya
Cardinal Rule 2
Beeping while playing games is a part of the computer's operation...or it can be part of that game.
Some times ur accessories (like ur printer/USB device/mouse etc) is not connected properly...
if the sound is from the PC's speaker then it can be disabled but u will also not get the games sound.
but if it's from your PC's external speaker then u have to live with it or u can mute ur speakers.
Dec 17, 2009 | Acer Aspire T135 PC Desktop
Verbatim 160GB Hard Drive won't boot.
Try it on another PC or on a powered USB hub: maybe it's not getting enough power to run.
If it still doesn't work, and you don't hear the drive's spin-up noise, the electronics may be damaged, the internal disk disconnected or the internal power connection faulty.
If you hear the spin-up whirring and then a series of repeated whirrs and clacks, ending after about 30 seconds - one minute, the disk might be damaged. It still might be recoverable if extracted from the case and connected directly to an appropriate hard disk port (a 3.5 to 2.5 adapter might be necessary), but when things go this far, the chances aren't too good.
Oct 27, 2009 | Verbatim Computers & Internet
I hve a Verbatim USB Portable Hard Drive with 160gb/go. Suddenly I notice the blue light on the unit is blinking, and my K drive (Verbatim) is no longer showing on my computer. What does this mean?...
usualy it means that it has an error,try checking that the cables to the drive are connected properly if there all fine try shutting the usb drive off and turing it back on after 3 min.
you should turn your PC off also and restart it.
if that does not work you need to post more information about your PC and periferal devices.
Jul 18, 2009 | Verbatim 160GB USB FireLite: The "drive...
Need drivers
Below is the link for the FireLite 160GB portable HD. Drivers are only needed for win98. 2000/xp/vista are plug and play. The manuals are included at this link.
http://www.verbatim.com/support/support.cfm?part_number=firelite+160gb+usb&x=56&y=11
Additionally, there could be a problem with power supply. A switch is on the back...USB or EXT. EXT is for an external supply. (http://www.verbatim.com/products/detail.cfm?product_id=38819801-1143-3415-5FE3682C49A8E37F&cat_id=3883B708-1143-3415-5FB9F3C74069A098) USB is naturally for a USB cable. Clicking might indicate low power when using USB. Switch to the external adapter or get a USB cable with two connectors for the computer (the extral cable draws more power),
good luck.
Jul 10, 2009 | Verbatim 160GB USB FireLite: The "drive...
Verbatim external hardrive not showing up on computer?
A Hard disk making noise, does not sound too good. if it was waorking before on both PC's & not having issues then it has to be with the unit. try on a nother computer. if its the same thing i suggest you look for that warranty card of yours.
Jun 09, 2009 | Verbatim 160GB USB FireLite: The "drive...
Open Questions:
Computers & Internet Logo
167 people viewed this question
David Payne
David Payne
