Question about Polaroid i1035 Digital Camera
Camera turns off after i turn it on
I turn on the camera and it starts to focus then it turns back off
    Problem Solver:
  • 7 Answers
Connect to a proper A/C power source, If it works then, your batteries may not be fully charged.
Posted on Dec 09, 2009
2 Suggested Answers
SOURCE: Camera won't work
I had the SAME problem with mine, and I found out that if you hold down the menu button until it resets--it is completely fine!
Posted on May 28, 2008
Fixing a seized AF motor
One theory on this is that the camera's software or settings may somehow be corrupted, so you should go through the process of resetting the camera to its original factory settings. If that does not clear up the problem, try another AF lens and conform whether the problem is the lens or the camera body. If the camera is not focusing another lens, then you may need to clean the contacts or look for some sort of damage.
If it turns out that it is the lens, the best solution is to send it to Tamron for service and see what they can do about it.
If you cannot send it to Tamron, you ought to see whether it is something as simple as some sort of internal dust or dirt collection blocking the mechanical switches and functions of the lens.
Start with making sure that you have a fully charged battery for the camera or AC power adapter for the camera. You do not want any of the problems with the camera to be related to having too little voltage available.
Make sure that the camera's power switch is switched off. You do not need to have the battery or adapter connected just yet.
Next, with the lens off of the camera, switch back and forth several times, firmly, between AF and MF and switch the vibration compensation off and on a few times. Of course, do not drop the lens. Also, unless you need the zoom ring locked, you may want to make sure that the zoom ring lock is fully off. While you are doing this, or after switching back and forth, check the electrical contacts on the lens and the camera body. If anything looks even a little less than shiny, clean the contacts.
With the camera's power still switched off, put the lens back on the camera.
Either put the battery in the camera or connect the AC adapter.
Set the lens to AF with vibration compensation off.
Switch the camera's power on.
Try getting the camera to automatically focus on something. If it works, turn the camera's power off, then switch vibration compensation on, then turn the camera's power on and try again. It may be fixed, at this point, which means that you can ignore the rest. Otherwise:
Turn the camera's power off again and switch to manual focus. Turn the camera's power back on and rotate the lens's focus ring (gently) all of the way through the focal range two or three times. Try taking one or two pictures, just to be sure that everything is working in manual. Turn the camera's power off and switch the vibration compensation, then turn the camera's power back on. Gently rotate the focus ring all of the way through the focal range two or three time, and then take two or three pictures to verify that everything is still working in manual.
After that, turn the camera's power off and switch back to AF with vibration compensation off. Turn the camera's power back on. Try to get the camera to automatically focus on something. If it works, then turn the camera's power off and switch vibration compensation back on again. The turn the camera's power on and try to get it to automatically focus on something.
If all of this works, than you should be okay with it as it is. You may still want to send the lens in to Tamron to get it serviced, in case the problem was some sort of lint or dirt getting caught up in the gears or servo that moves the lens through the focal range.
If it does not work, you could try to force the lens to re-engage the autofocus servo. It will probably void your warranty, if you still have one, so you are better off send it in to Tamron for service, first, before trying it. Also, as the manual and common sense would indicate, if you try to force the lens to adjust its focus ring while it is switched to AF, you could easily break the mechanism in the lens.
With that being said, some people claim that they got their lenses to return to proper autofocus by leaving the lens switched to AF and trying to rotate the focus ring manually. One person says not to "force" it, his just took a "firm push". I have not tried this, so I do not have advice on how much force may work or how much will damage the plastic bearings, gears and teeth inside the lens.
May 04, 2014 | Nikon D60 Digital Camera
I turn on the camera and it starts to focus in and focus out making a noise and then appears ''lens error''..
The gears in the lens housing is grinding because of grit build up, it must be taken apart and cleaned in order to get it back to proper operational standards.
Feb 06, 2011 | Cameras
System Error (Focus)
The systems control board has detected a problem with the auto focus lens, the focus is controlled by a tiny motor that has jammed or there is a mechanical issue with the camera lens. It will require a technician that is highly skilled to deal with the situation, but the repair cost would probably not be justified.
Jan 12, 2011 | Panasonic DMC-FX37 Digital Camera
My camera wont focus/ the lens wont close when i turn it off
i think its seen better days it will be cheeper to dump it and buy a new one sorry!
Oct 20, 2009 | Cameras
I turn on my samsung s1060 its out of focus, beeps and turns off
samsung 8.1 camera when it turns off it keeps going back to italian language and take blurry pics. olz help
Jul 19, 2009 | Pentax Optio E40 Digital Camera
Olympus C-765 does not focus
Dear Benjamin,
I also own an olympus c765 and was wondering how to use the manual focus option when I came across your post. Actually I have been wondering whether manual focus is of any use in an olympus c765 because the manual does not talk anything about it.
However, I just found out that there is a way of activating/deactivating manual focus. Here it goes:
1. Turn the camera on
2. Switch to any mode - portrait/landscape etc
3. Press and hold the 'OK' button on the centre for a second until you see a MF/AF option on the screen
4. Switch to MF and focus on any subject by pressing the up/down keys.
Most likely, your camera has been turned to Manual Focus option, which is why it is not focussing any more. Follow the steps above and turn it back to Auto Focus option and let me know if your problem gets solved.
Regards
Aug 30, 2008 | Olympus Camedia C-765 Digital Camera
Will not focus in AF, Will not take picture
Try switching the macro off, if it is on. The macro is for close-up shots. When my mom uses her camera with the macro on, it gets really out-of-focus. I look like a flower.
Aug 18, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Focus error show up and can't take any pictures
Had "FOCUS ERROR" appear on my Finepix S9500. The lens seemed to be stuck at the extremity of focus range. I resorted to hitting the camera on a table while turning it off (because this is when it sounded as though the focus motor was trying to move the lens back). Guess what? It worked!!!!!
Aug 11, 2008 | Cameras
Camera won't work
sounds like a problem with the ccd, email me at rmorgan780@excite.com, may be able to repair for you, Bob
Apr 08, 2008 | Olympus FE-230 Digital Camera
FOCUS ERROR
I also had this problem. When starting the focus error alert came. Trying to move the focus button also triggered this. When I turned it off, the lens did not pull back.After being close to trowing it away, I used a little bit more force than before and turned the lens manually. I heard a click, and than it worked again. PS: Follow this tip on your own risk.....
Mar 11, 2008 | Fuji FinePix F410 Digital Camera
Polaroid i1035 Digital Camera Logo
98 people viewed this question
Top Polaroid Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
