Question about Jensen XA2150 Car Audio Amplifier
Kenwood kac-7202 amp
I have a kenwood kac-7202 amp and don't know exactly how many watts it is.would anybody know?
  • 631 Answers
150/ch into 4 ohms
230/ch into 2 ohms
Spec Sheet
Posted on Jan 11, 2008
Kenwoood kac-7202 redlight/no output
you blew the output Ic's (amps one or more ) you can fix this by replacing the output IC's
Jan 29, 2014 | Kenwood KAC-7202 Car Audio Amplifier
Will it kill my battery? I want to install this amp and a 12 inch subwoofer but im scared it might kill my battery.
nope you good for up to 1000 watts RMS anything above that you will need battery and alternator up grad
Apr 01, 2010 | Kenwood KAC-7202 Car Audio Amplifier
Where do i connect the power control wire to ? I have a kenwood amp kac 7202, I'm connecting it to a stock cd receiver in toyota corolla 2004
Hello sophnettliss,
Most stock receivers do not have a dedicated amp remote lead and your 2004 Corolla is no exception.
The amp remote can be connected to any switched and fused 12V + source including the OEM receiver accessory wire which is the gray wire in your receiver harness.
Hope this helps.
Oct 02, 2009 | Kenwood KAC-7202 Car Audio Amplifier
Keep popping fuse
you got short in the curcuit
Apr 03, 2009 | Kenwood KAC-7202 Car Audio Amplifier
KAC-7202 will not put out sound. Put in other amp works.
When you switch on the amp did the main amp ic produce heat. If does not change the main amp ic.
Feb 13, 2009 | Kenwood KAC-7202 Car Audio Amplifier
Check the zener diodes over by the fuses, where the 2 chokes or load coils are. TThere are 3 or 4 Of the diodes, they are zener diodes. I had the same problem and found it to be one bad zener diode. Check my solution out on the 7202, same thing.
Sep 17, 2008 | Kenwood KAC-7202 Car Audio Amplifier
Kenwood KAC-7202 wont turn on
I have found the problem to my Kenwood KAC-7202. The amps fan was the only thing that would come on thats it. So I started checkin zener diodes cause all transistors checked out fine. So I remember readinf about a guy that had same problem and took it to a shop and they said it was some diodes. Well, thats what I was thinkin or the transformer. It turned out that 1 zener diode was no good, diode D9 1ss133. I took a zener out of an old vcr I use for parts and put it in and the fan came on as usual then the red light. Then I hooked my mp3 player to the rca input and hooked up some speakers and it works great. Hope this helps you other guys with the same problem. Check your zener diodes with a digital volt meter, if you get any measurement other than the reverse impedance which will read between 600 and 1200 ohms some lower or higher and then reverse the leads on your meter and if you get any reading it's no good and the reading will be 0-50 cause mine read 047 ohms.
Feb 09, 2008 | Kenwood KAC-7202 Car Audio Amplifier
Jensen XA2150 Car Audio Amplifier Logo
178 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
