Question about Air Tools & Compressors
I broke the brush holding mount. Can I get a replacement, with new brushes?
  • 530 Answers
This has been unanswered for a while so I don't know if your still looking.
Most brush holders are pretty similar and with a little bit of filing and or sanding most brushes can be made to fit. Try a electrical supply shop or a electrical motor re builders shop for parts. Even automotive shops can have a wide variety of holders and brushes. I also included some links that might help. Tell them what you have and maybe they can match you up with a replacement. If not they may be able to point you in the right direction.
The first two are compressor parts suppliers the third is the old stand-by Graingers.
Good luck and I hope this helps.
If not please let me know and I'll try until we get it right.
http://www.mastertoolrepair.com/
http://www.compressorpartsstore.com/
http://www.grainger.com/Grainger/wwg/start.shtml
Posted on Dec 21, 2009
My oreck xl21 won't pull itself.
You need to rotate your brush or replace the brush. Lay your Oreck down, unplugged with the base plate facing up. Remove the 5 screws that hold the plate on and remove the plate. Look at the bearing blocks at each end of the brush, what you are going to be3 looking for are a series of "hash" marks on the black plastic mount. If you see several, rotate the block until you only see one mark at each end and reinstall the brush and belt and that should take care of your issue. If you only see one mark, you need a new brush roller. Hope this helps!
Apr 19, 2014 | Oreck Vacuums
Belt replace panasonic vac
Is it an upright? On mine it's very simple.
Unplug vacuum and lay it on floor so that you are looking at the rotating brush. Remove screws that attach the cowling. Remove the cowling. You will then see the rotating brush ends. One end will have the belt, or what's left of on the brush wheel. You will also see the motor shaft. The belt goes between the shaft and the brush wheel. Carefully remove the brush by holding both ends and pulling straight out. Place the new belt on the brush wheel and replace the brush. With the belt on the brush wheel, stretch it to fit on the motor shaft. Rotate the brush to make sure the belt is riding correctly at both ends. Replace cowling and screws.
Nov 29, 2011 | Vacuums
I have a 1999 3,8L ford mustang my tester indecates the alt is overcharging,but the batt light is coming on but it goes off! is there anything i can do to besides replace the alt?
Your alternator-mounted voltage regulator has failed. Luckily, your voltage regulator is
replaceable separately from the alternator (most voltage regulators are integral to the alternator,
and cannot be separately serviced).
Note: this works for 3.8L cobra alternators/voltage regulators only - in the 4.6L model, the
voltage regulator is an integral component of the alternator.
1999 Ford Mustang Cobra -3.8L engine
3.8L Engines
1. Disconnect the negative battery cable.
2. Remove 4 Torx® head screws holding the voltage regulator to the alternator rear housing. Remove the regulator, with the brush and terminal holder attached.
Fig. 1. The regulator and brush/terminal holder are mounted on the backside of the alternator
Fig. 2. The regulator and brush/terminal holder are secured by 4 Torx® head machine screws
Fig. 3. Hold the regulator while removing the screws to prevent the regulator from dropping out and damaging the brushes
3. Hold the regulator in one hand and pry off the cap covering the A terminal screw head with a small prybar.
4. Remove 2 Torx® head screws retaining the regulator to the brush holder. Separate the regulator from the brush holder.
Fig. 4. Slide the regulator out-the brushes will move out of the holder
Fig. 5. The brush and terminal holder can be separated from the regulator once it is removed from the alternator
To install:
1. Install the brush holder on the regulator with 2 retaining screws. Tighten the screws to 25-35 inch lbs. (2.8-4.0 Nm).
2. Install the cap on the head of the A terminal screw.
3. Depress the brushes into the holder and hold the brushes in position by inserting a standard size paper clip, or equivalent tool, through both the location hole in the regulator and through the holes in the brushes.
Fig. 6. When installing the regulator, press the brushes back into the housing
Fig. 7. Use a thin piece of soft material, like this plastic wire tie, to hold the brushes in position while replacing the regulator, or use a paper clip inserted in the hole
4. Install the regulator/brush holder assembly and remove the paper clip. Install the attaching screws and tighten to 20-30 inch lbs. (2.3-3.4 Nm).
5. Connect the negative battery cable.
Jul 07, 2011 | 1999 Ford Mustang Cobra
The belt for the maain vaccume broke off and now with the new belt the roller will not work.
It sounds like your roller brush itself might be bad. Try holding the roller brush holding just the end caps with your finger tips, and spinning the roller. Does the roller spin freely? If no, this indicates that your roller brush's bearings have melted together. This is a common problem for Bissell vacuums, as they use cheaper plastic bearing caps. The roller brush is not covered under the warranty either.
When this part goes bad, this causes the belt to break almost immediately. If you tried replacing the belt, and it broke immediately, your roller brush has gone bad.
Here's a link to the Bissell LiftOff Revolution rollerbrush on our site;
Bissell Roller Brush for Lift Off Bagless
Please leave me some feedback, or rate my solution helpful if this helped you fix your problem. Thanks so much,
Chris Jones
GoVacuum.com
Jan 07, 2011 | Bissell LiftOff Revolution Pet Vac 37602...
THE ROLLER BRUSH WILL NOT TURN. I PUT ON A NEW BELT AND IT BROKE IMMEDIATELY. THE ROD THAT HOLDS THE BELT IS MOVING BUT THE BRUSH IS NOT MOVING.
Apparently something is binding the brush, keeping it from turning. Remove any string, hair, etc., that is wrapped around the brush. Removing the brush is the easiest way to do this, then cut the material through at one point.
While the brush is out, check the ends for signs of damage that may cause the brush to bind. Also, check the area the brush connects to.
Reattach the brush and try to spin it. If it spins freely, put your vacuum back together, with another belt, and try again.
If this doesn't work, I suggest a new/different vacuum.
Oct 25, 2010 | Bissell Vacuum - Momentum Cyclonic 1 ea...
Charging system not working have already put in a brand new alternator and new battery
There is a fusible link in the connection between the alternator and the positive battery cable connector.
On the 1997 it is a 175 Amp Mega Fuse mounted on the outside of the high voltage fuse box located on the drivers's side in the engine compartment. After replacing the battery and the Alternator, it turned out to be a $4.99 fuse that was keeping the alternator current from reaching the battery.
The alternator cable bolts on to one end of the fuse, and the positive battery cable bolts on to the other end. You can test it inline without removing it by checking for continuity across the two bolts. An open circuit indicates that the fuse is blown and needs to be replaced.
If the fuse is blown (which means you have an open circuit), the battery light in the dash should be on.
The car will start normally if the battery has enough of a charge, but it will eventually die when the battery is too depleted to keep the car running, because the alternator can't take over if the current doesn't make it across the blown fuse.
If the battery is dead, it will start with a jump start, but it will die shortly after you remove the jumper cables for the same reason.
This is one of those problems that you might not think of right away, and it will drive you out of your mind. ALWAYS check this fuse before replacing a battery or an alternator on a mid to late '90s Model Thunderbird. You will save time, money, and you won't pull out your hair.
Aug 17, 2010 | 1994 Ford Thunderbird
My brush will not turn on my Bissell 6393 upright bagless vacuum... what is wrong? The belt broke and I replaced it twice... I now have 6 more replacements but the brush still won't rotate. Do I have to...
This type of plastic brush roll fails pretty frequently. Hair and other debis gets jammed in the end caps. The hair and debris gets hot which in turn tends to melt the plastic end caps. Remove your brush roll, hold the ends with your fingers and try to spin the brush roll. If it does not spin freely then it is probably damaged or clogged up. If it's not damaged beyond repair you may be able to unscrew the end caps and clean the debris out. If you can't unscrew the end caps then they may already be meted shut. Bissell part number for your brush roll is B2032305.
May 17, 2010 | Vacuums
The beater brush wont spin because the brush roll is always in the off position. Moving the carpet/hard switch doesn't turn it on.
Hello :
Try this please :
Switch the carpet/bare floor dial back & forth 5 times, ending on carpet. Tilt the handle back as if to vacuum upright & lay the vacuum on its side so it is resting on the side opposite the carpet/bare floor dial. Turn the vacuum on.
Or Maybe the belt is broke. You will have to replace the belt before the roller can spin. You must have run over something in the carpeting like string or whatever to have it break. Happens all the time. Get several replacement belts to keep as spares while you're at it as nothing is worse then having to vacuum and no spare belts.
Try this also please :
Things You'll Need: Phillips head #2 screwdriver Replacement belt for your vacuum model Spray lubricant, such as silicone spray or teflon lube.
1: Unplug the vacuum. Never work on an electrical appliance when it is plugged into an electrical outlet.
2: Turn the vacuum over and locate the plastic or metal plate that covers the rotating brush. Remove this plate.
Note: This plate is typically attached by a small number of Phillips head screws or by levers that turn and lock the plate in place. In either case, removing this plate is a simple task.
3:Identify the vacuum's rotating brush. This brush should have a black rubber belt wrapped around it, and stretched around the metal shaft of an electrical motor mounted somewhere toward the back of the vacuum.
4:Verify that the brush will rotate freely. Examine both ends of the brush to ensure that no threads, string, yarn, etc. have become wrapped around the ends and thus inhibited a free rotation.If there is foreign debris, remove the brush by sliding it up, away from the bottom of the vacuum. Remove the debris
5:Lubricate both ends of the rotating brush with the spray lubricant. Replace the brush into the grooves which hold it in place
Replace the existing belt on the brush assembly, or replace a broken belt with a new vacuum belt.
6:Verify that the brushes now turn freely when back in place and that the motor shaft turns as the brush rotor turns.
PLEASE DON'T FORGET TO RATE !
Apr 22, 2010 | Hoover U6630-900 WindTunnel Bagless...
Bosch wfr2460
hi Many universal motor malfunctions are caused by wearing down of the carbon brushes, the soft blocks of carbon that complete the electrical contact to the motor's commutator. When these brushes become worn, the motor will spark, and electrical contact may be incomplete.try this
Step 1: To sight-check the carbon brushes, remove the screws that hold the brushes and brush springs into the brush holders at the sides of the commutator. The screws will pop out of the screw holes; turn the motor over to tap out the brushes. The ends of the brushes should be curved to fit the commutator; if they're worn down, new brushes are needed.
Step 2: To check carbon brushes with a continuity tester, remove the motor lead wires from the circuit. Tag the wires as you disconnect them so that you'll be able to reconnect them properly. Hook the tester clip to one motor lead and touch the probe to the other lead; the tester should light or buzz. Slowly rotate the motor shaft, keeping the tester in position. If the tester doesn't light or buzz, or if it flickers or stutters when you turn the motor shaft, the brushes should be replaced. If the springs behind the brushes are damaged, they should be replaced as well.
Step 3: Replace worn carbon brushes and damaged springs with new ones made specifically for the motor. The model information (number and make) is stamped on a metal plate fastened to the motor, or embossed on the metal housing of the motor. If you can't find the model information, take the worn brushes and springs with you to an appliance-parts store to make sure you get the right kind. Insert the new springs and brushes in the brush holders, replace the brush assemblies, and secure the new brushes with the mounting screws that held the old brushes.
Sep 13, 2008 | Bosch Axxis+ WFR 2460 Front Load Washer
Air Tools & Compressors Logo
75 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
