Question about HP PSC 950 All-In-One InkJet Printer
CHANGED COLOR CARTRIDGE AS I HAVE MANY TIMES BEFORE. NOT WORKING. MESSAGE IS THAT THIS CARTRIDGE WAS NOT INSTALLED CORRECTLY. HAVE TRIED EVERYTHING - HELP PLEASE ! thanks
  • 979 Answers
Good day sir/ma'am, hi, the reason why the printed sends the mesaage "cartridge not installed correctly" mean that it cannot get ink from those cartridges due to dirt and dust, or the ink on the cradle dried out, you may need to clean the cradle, the part were it houses the ink cartridges, since dried ink is solluble to water, use warm water to clean the cartridge. you can remove the cradle or use a dipstick with cloth wrap around and dip it to the dried ink. If the dried ink has soften enough you can place again your cartridge and test print again, do this several times to get the ink flow again. Carefull not to moisten the electronics part of your printer. thats it.
Posted on Nov 19, 2009
How do I fix e07
I assume you have a Canon copier based on the E007 error code. The Fuser fixing film is torn and the Fixing film assembly or the entire fuser should be replaced. Very common issue.......You cannot reset that code without first replacing the part causing the code.
Dec 03, 2014 | Office Equipment & Supplies
Everytime I change the cyan cartridge I get a message that cartridge is missing or damaged. In the past I've tried everything from the solution center and manual and problem has gone away even though I...
Make sure that the cartridges sit in the correct slots. Match the shape and color of the icon on the cartridge with the slot that has the same shape and color icon.
Press down on any cartridges that you find sticking up. They should snap down into place.
If a cartridge does not snap into place, you might need to readjust the cartridge tab.
Remove the catridge and gently bend the tab away from the cartridge. Be careful not to bend the tab too much
Reinstall the cartridge into its appropriate slot until it snaps into place and seats firmly in the slot.
Check if the issue was resolved
If not, make sure that the carriage latch is closed. The latch is located athe right side of the inks. Its the color blue latch beside the black cartridge.
If its still giving the same error message. Try cleaning the electrical contacts of the cartridges.
IF this did not resolve your issue, process a repair for the printer.
Apr 23, 2011 | HP Officejet 6500 Wireless All-in-One...
I have replaced both of the ink cartridge's in my Canon Pixma MP250 and now whenever I print anything in color, it comes out very light and the color has no depth to it. I made sure the cartridge's were...
Did you use Canon cartridges or generic ones? Sometimes if you do not use brand specific cartridges the printer will realize this and not print correctly. Also after you changed the cartridges did you calibrate the printer? If not, try calibrating 3 times and see if this corrects the problem. If not, it could be the cartridges...
Mar 16, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
Epson rx680
one ink cartridge is out of ink but...
when we try to replace one of the color ink cartridges we get this error message:
ink cartridges cannot be recognized. make sure ink cartridges are installed correctly - how do I get the printer to recognize my full ink cartridge?
Sep 18, 2009 | Epson Stylus RX680 Color All-in-One InkJet...
Changed ink cartridge now it won't work
Try removing the black and see if the error is still there. If it goes away the black is bad, if it stays you got a defective new color cartridge.
Jul 01, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Trying to insert new black printer cartridge
your printer will not operate with the 'color' cartridge missing you will have to install a color cartridge.
May 19, 2009 | HP OfficeJet J4580 All-In-One Laser...
The printer doesn't recognize the new original HP color cartridge
There is a small spring that holds the ink cartridge in the ink holder. You will see it stick out from the right hand side of the ink holder where the ink cartridge slides in. If that spring isn't being held to the ink holder by two plastic tabs, (I.E. the plastic tabs are broken) the printer will never recognize the cartridge. If the printer is still under warranty I would contact HP or an authorized repair center for HP. Both the black and color ink holder has this spring. I know of no way to repair this kind of breakage.
Jan 08, 2009 | HP OfficeJet 7310 All-In-One InkJet...
I just installed a new black ink. The error message keeps on saying wrong color cartridge installed. I replaced with the correct one for my officejet v40. Black 15.
did you try changing the color cartridge too? I had problems with ink cartridges that were not HP cartridges.( not made by HP but some other co.)
Dec 05, 2008 | HP OfficeJet V40 All-In-One InkJet Printer
Wrong cartridge?
Doubled check the cartridge numbers and that they match what is on the printer. If no match get correct ones.
Oct 24, 2008 | HP PSC 1410v All-in-One Printer
HP PSC 950 All-In-One InkJet Printer Logo
109 people viewed this question
Seeker5211
Seeker5211
