If it's electric and you do not have the knowledge to be working with 220 vac power I would suggest you call a repair person to come and look at it. It can be a tripped breaker, check you breaker box and shut off the drier breaker and than turn it back on making sure both sides lock on. Other than that, you can have a bad heater element or a bad timer. The most common would be a bad heating element. The element is normally found either behind the drum or down below the drum area and can be accessed by removing the lower front panel. Gain access to the element or open the dryer door and start the dryer by holding down the door switch and push the start button. If it is behind the drum you should see it glowing by looking inside the drum as it's running. The same is true for the element that is underneath the drum...remove the panel and start the dryer, you should see a glow from the element box. If you do not see a glow, unplug the dryer and check the element for a burned connection or break in the element wire. If you have a gas dryer, check that the supply is on, check that the dryer is plugged in and if so equipped check that the pilot light is lit. If the dryer has electronic ignition, you should hear a clicking noise when you first start it up. No noise, no ignition! If the pilot light is out follow your instruction book and relight the pilot or call your gas company for help!
Does the drum spin when you shut the door and start the dryer if so it wouldn't be a bad door switch. 1st. thing I would check would be the igniter with front kick panel off dryer it's located at the bottom right hand outer side of drum in the burner duct. here's how you check it with door shut start dryer and look for a orange glow from the igniter if no glow it's a bad igniter if it's not the igniter it could be a thermostat or a flame switch check these things if need more help I'll be glad to help.
An electric Neptune clothes dryer, like most electric clothes dryers, has two circuit breakers: one for the drum and another for the heating element. Both breakers need to be in the "on" position for it to run properly. Go to your main circuit box. Reset both of the dryer's circuit breakers to the "on" position. If one of the breakers trips again, there's a problem with the dryer component that it operates. Contact a dryer repair technician to evaluate the machine's condition. The lid switch is a small latch located on the interior of the door frame on your Neptune clothes dryer. It keeps the door securely shut when the dryer's on to prevent injury should you open the door and reach inside while it's turning. If the lid switch becomes damaged, the dryer won't turn on even though its lights might work. Run your finger over the lid switch and listen for a clicking sound. If you don't hear a sound when the latch is compressed, it's faulty and needs to be swapped out.
The thermal cut-off is a heat-sensitive safety feature on a Neptune clothes dryer that shuts off the heating element if the dryer overheats. After it activates, it can't be reset; you must replace it. Until it's replaced, your dryer might only partially function, so while its lights might turn on, the dryer might not spin or heat. Don't exchange an old thermal cut-off for a new one until you first determine what promoted it to trip, otherwise your dryer likely will overheat again.
your dryer may have a spark igniter or a hot wire igniter .. those go bad after so many hours .. if you look in where the flame usually is .. as your start the dryer, you should see a small glowing wire if its a hot wire igniter .. or you should hear clicking and see sparks if its a spark igniter .. if you dont see/hear either then thats likely your problem .... both of those parts are available from washer/dryer parts distributors or GE parts on the internet .. but you have to know the make and model number of your dryer .. you should find that on a tag inside the door or on the back. .. if it actually ignites but quickly shuts off then you probably have a clogged exhaust hose or lint filter chamber .. it reqires a large unrestricted air flow thru the machine. if that is blocked then a sensor shuts off the gas in just a few seconds . . i am assuming that the drum is turning .. if not then thats a whole different problem ..
when you try to start it again do you hear a humming comeing from the motor? can you jump start it by turning the drum while holding the start button? If you say yes to these questions you have a bad motor.
